Bulb limiter bulbs
Discussion in 'Shock Brother's DIY Amps' started by maninsuitcase, Jun 17, 2019.
  1. maninsuitcase
    maninsuitcase TDPRI Member
    Herts, UK
    I'm intending to start off my first amp build by building a bulb limiter, safety first and all that.
    Standard incandescent bulbs are pretty scarce round here now, amazon/eBay seems the only real option.
    I can however get some Halogen based ones, still not cheap but I can get them in the shop over the road. They come in a range of wattages from 30-100ish (these are the rated W not the "equivalent").
    Is there any issue with Halogen bulbs in a limiter? From a pure limiting point I cant see any issue but I remember them being rather temperamental and I wonder if they might not last very long?
    If I do source some standard bulbs, is the bulb life in a limiter okay or do I need to get a reasonable number of spares?
  2. bblumentritt
    bblumentritt Tele-Afflicted Platinum Supporter
    Austin, Texas
    The light bulb current limiter is designed around an incandescent bulb.
    Here's a suggestion to use 12V automotive bulbs.
    Old Deaf Roadie likes this.
  3. Old Deaf Roadie
    Old Deaf Roadie Tele-Holic
    Oregon
    Digital networking for model train control. I preside over a bunch of AV over ethernet systems, and never would have considered this is even a thing, considering my train diorama as a kid was controlled by a rheostat.
  4. maninsuitcase
    Herts, UK
    Would a 12V bulb not blow the instant it saw mains voltage? Well unless you series up about 20 of them.
  5. VintageSG
    Yorkshire
    Quartz halogen lamps can be very temperamental if they're not used at close to their rated voltage and current. Under driving them shortens their life considerably. Their characteristics can be a bit on the odd side too, plus they get hella hot and dazzly ( technical terms ).
    Have a look in the cupboard under the stairs to see if you kept your old incandescents when you upgraded to LED.
    I kept some 25, 40, 60 + 100W because I figured they'd come in useful someday. My wife thinks I'm a packrat, and she's not wrong ( She never is! )
    Try an automotive tool supplier. Toughened incandescents are/were used in inspection lamps and they may still have stock.
  6. maninsuitcase
    Herts, UK
    I may have one of those actually.
    I know I don't have any as when we moved the house was all CFL and I binned all of them for LED. I'll have a rummage at my dads though, he may well have a few.
  7. Teleterr
    Teleterr Friend of Leo's
    Lewes De.
    How about oven bulbs ?
  8. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    have you checked an internet search for incandescent bulbs in your area? I live in Holland, and they are becoming difficult to find at normal consumer shops. But right at the end of my street is a specialty lamp shop, and they still have everything available. Of course the prices are a bit higher, because yesterday's regular 100W bulb is now a 'specialty item'. Bur you only need one or two.
  9. muscmp
    muscmp Tele-Afflicted
    california
    i found mine at walmart.
    play music!
  10. Whatizitman
    Whatizitman Tele-Afflicted
    WV
  11. 20strings
    20strings TDPRI Member Silver Supporter
    Dallas, TX
    Yeah, in the States you can find them at Home Depot, etc. still. Not so much in Europe. You might be able to find some of the 'decorative' incandescent bulbs that look like old school bulbs though.
  12. dan40
    dan40 Tele-Afflicted Silver Supporter
    Richmond Va
    Check for "rough service" or "shock resistant" bulbs at the automotive or hardware store. They can still be found here in the US for use in work lights and droplights.
    6stringcowboy likes this.
