Build Deluxe Reverb using PC board from Ebay
Discussion in 'Shock Brother's DIY Amps' started by drlizardo, Aug 19, 2016.
  1. drlizardo
    drlizardo Tele-Meister
    Central Illinois
    Has anyone built a deluxe reverb using the electronics from a reissue on ebay? There are several loaded boards removed from reissues where people decided to handwire instead. Is this a cheap alternative possibly? There's still a lot of work to do fabricating a chassis and cabinet but that's doable for pretty cheap.
    Any thoughts?
  2. zook
    zook Friend of Leo's
    Cochise, AZ
    Don't bother. It would be just as easy to build it the old way with a chassis kit.
  3. Tele wacker
    Tele wacker Tele-Holic
    Wichita is nice.
    I agree that a turret board is better than the PC. Those PCB things are junk.
  4. drlizardo
    Central Illinois
    I was thinking more about saving money. I guess it would probably be close
  5. Badside
    Badside Tele-Meister
    Montreal, Qc, Canada
    The board is often the least expensive part of a build. You'd still need transformers, a chassis, tubes, a reverb pan, etc
  6. corliss1
    Lansing, MI
    Yup - a fancy board with turrets and decent parts will probably about what you could buy a ripped out reissue for, or find one of the decent board kits that match the older style. If you're gonna try and make it nice you really won't save much getting the boards.
  7. Modern Saint
    Modern Saint Tele-Meister
    So Cal
    If you are going to spend the time to build an amp that used a turret board, don't short cut with a PC board. You will end up changing it out in the future anyway.
    Teleguy61 likes this.
  8. robrob
    United States
    I agree, you can buy a populated turret board for close to the money of one of those PCB pulls. Why pay all the money for a cab, speaker, chassis and transformers just to stuff it with a PCB?
  9. drlizardo
    Central Illinois
    I wouldn't pay money for a cab or chassis or tubes, but I think you're probably right. I have no idea what a loaded turret board costs
  10. corliss1
    Lansing, MI
  11. CordovaNate
    CordovaNate TDPRI Member
    Memphis
    I came to the same conclusion as the guys here who know, albeit after the fact. I bought the PRRI PCB ($55). I decided to keep a track of the cost and between MojoTone, HoffmanAmps, Amazon and eBay, its into me for $492.67 and I still have maybe $25 for stuff I got wrong/missed earlier, like the L12A jack for the external speaker.
    All sittin in a box, haven't even started yet.
    But, I'm not kicking myself over it. I'll enjoy working on it and if it winds up on a tech's bench, ehhh, they need work too.
  12. CordovaNate
    Memphis
    Ohh, first post.
    Hi, my name is Nate, live in the Memphis area, recently retired
  13. boredguy6060
    boredguy6060 Friend of Leo's
    Sou Cal
    Hello Nate, and welcome
  14. Mart the Hat
    Mart the Hat Tele-Meister
    Edinburgh, Scotland
    I find that with my amp builds, making and populating the eyelet board is not where most of the time and expense go - that part is relatively cheap and quick to do. So whatever time or money savings you might make building around a PCB don't seem worth it compared to the additional satisfaction of having the whole thing hand-built.
  15. robrob
    United States
    ^That's the key. The circuit board is easy and inexpensive. All the work is connecting everything to the tubes and pots. All the expense is in the cab, speaker, tubes and transformers. You'll seriously regret building an amp and sticking a freakin' PCB in it.
    Cordovanate, sink that $55 and build a proper circuit board. Your amp's resale value will jump much more than $55 with an eyelet or turret board and your owner's pride will spike too.
  16. drlizardo
    Central Illinois
    Thanks Nate and welcome. I built a tweed deluxe a year or two ago and had a good time doing it. It was all hand wired with a homemade cabinet. It's a lot of fun and I hope yours goes well. You came to the right place for guidance
  17. Bill Moore
    Bill Moore Tele-Holic Silver Supporter
    Silver City, New Mexico
    I used a Watts turret board for my "Twin" build, very nice!
    When I decided to build a DR, I also built my turret board. I had a Weber AB763 board for a template, really easy to do.
  18. CordovaNate
    Memphis
    I think you are probably right robrob. I'll need to track down a list of components for the turret board, and I think I saw one at HoffmanAmps. I'm looking for an AA1164 build list right???
  19. robrob
    United States
    Hoffman will sell you the board and/or components and he'll solder the board if you like. He's a good dude.
    The Deluxe Reverb is an AB763 design and the Reissue is an AB763 on a PCB. Most of us believe the AB763 is the pinnacle of Fender design.
    More info on the DR and AB763: https://robrobinette.com/How_The_AB763_Deluxe_Reverb_Works.htm
    Signal path:
    songtalk likes this.
  20. CordovaNate
    Memphis
    Thanks robrob. Everything already purchased, i.e. transformers, chassis, etc., are predicated on the Princeton Reverb Re-Issue. I'd best stick with that. I did find a parts list at Hoffman Amps and may compare it to what I already have to see how much more $$$ I'm looking at for hand wired vs pcb.
