Build 8: Paisley Tele
Discussion in 'Tele Home Depot' started by Manny012, Sep 13, 2018.
  1. Manny012
    Manny012 Tele-Meister
    212
    Dec 8, 2015
    Sydney, Australia
    Hey 2 blue
    The wood glue hardens to a malt colour and this gives it a slight antique,/off white opacity. But it kind of suits the pattern. I'm going to do black sides and a slight black hand rubbed burst..not too dark... more smokey.
    2blue2 likes this.
  2. samuelmorrissey
    samuelmorrissey Tele-Meister
    154
    May 12, 2017
    Dublin, Ireland, Earth
    Sounds good. I've seen numerous tutorial / how-to videos on these type of builds and everyone seems to trim the fabric / material to the edge of the body before sealing. Interesting method, will definitely take it on board!
    I'm getting a vinyl type material. Not sure how that will work with a sealer before trimming, I'm sure your fabric absorbed some of it to secure it to the body even further, that probably won't happen with mine
  3. netgear69
    netgear69 Tele-Afflicted
    Dec 21, 2012
    england
    Material needs a lot of clear coat to bury the edges if you put the material flush with the edges it will be impossible and messy trying to bury them edges
    Fender got around that issue by leaving about a 3mm gap of wood around the edge
    As for using vinyl unless it is a cloth based vinyl it will shrink once any clear coat hits it
    tvvoodoo likes this.
  4. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    Hi netgear
    Yeah I'm. rounding the edges taking a little cloth away from them and leaving the edges exposed rounded timber. They'll be stained with a hand rubbed Burst.
  5. jmoore65
    jmoore65 Tele-Meister
    263
    Sep 27, 2007
    Oz
    Are you anticipating having to fill near the fabric edges? I mean, to disguise where the fabric ends?
  6. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    That's a good question I'll see how it winds up before I decide. If there is a definite edge it may look OK to leave as is. But further levelling is a possibility if warranted.
  7. netgear69
    Dec 21, 2012
    england
    If you are putting a burst around the edge 2 part car body filler will hide them edges put it on around the edges in stages it dries rapidly then sand it flush to the fabric
    saves having to use large amounts of clear coat which no doubt runs everywhere when trying to flood a finish level
    Manny012 likes this.
  8. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    Well I passed the router over the edges with 6 coats of hardened sealer. The result was better than expected. There was a tiny Ridge where the material met the cut but a couple of light passes with 120 grit and blended those into the wood. She's as level as can be and won't be a problem. The key here was the glue I applied plenty and spent alot of time smoothing out the surface until it was flat and stuck down. She bonded very tight.
    IMAG1589.jpg IMAG1588.jpg .
  9. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    Continued on neck design today
  10. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    Test fit and started neck shaping.
    First I shape the head and heel. Transitions, before shaving away the bulk of the neck.
    Old Tele Hack and VintageGearMan like this.
  11. jmoore65
    263
    Sep 27, 2007
    Oz
    IMG_0253.JPG Very interesting to follow this thread.
    Here is my material ready to go.
  12. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    Polished the fretboard to 12000 micromesh and installed frets
    PingGuo likes this.
  13. robt57
    robt57 Telefied Ad Free Member
    Feb 29, 2004
    Portland, OR
    Lets get a thread started for your build, I did my cloth laminate a long while back. Popped on a Lite Ash Fender Tele neck with MOP fret markers cause it looks right to me. Mine is on a 1-9/16 Poplar body I made from scratch nice light guitar for my aging back. ;)
    Love these what I call Burton-ish styled Teles.
  14. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    Agreed...lets get a thread going.
  15. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    Neck carve time. Roughed it out with sander, then scraped and filed to profile. 22mm at 1st, and 23mm at 12th. I might shave a touch off.
  16. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
  17. Totally_Tod
    Totally_Tod Tele-Meister
    166
    Jul 23, 2018
    Los Angeles, Ca
  18. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    Cavities done.
    Test fit
    Urshurak776 likes this.
  19. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Oct 23, 2011
    Lynchburg Tennessee
    Its looking good!!
  20. Manny012
    212
    Dec 8, 2015
    Sydney, Australia
    Time for some hand rubbed antique/aged burst. I started with black Japan, and feathered a little mahogany through the edges to give than aged/burnt/stain.
    Macrogats and VintageGearMan like this.
