Build #3, the c...bass!
Discussion in 'Tele Home Depot' started by zorgzorg2, Nov 12, 2017.
  1. epizootics
    epizootics Tele-Meister
    102
    Feb 11, 2017
    Lyon, France
    Kudos for the Camembert shot...We seem to export this one all over the world! Mind you, it's actually OK for an industrial Camembert.
    Looking really nice, that walnut is gorgeous. Is that all Swedish timber? Most of the walnut I work with in France in my cabinet-repairing workshop tends to have much less visible growth rings...
    zorgzorg2 likes this.
  2. hemingway
    Mar 14, 2012
    London, UK
    That's some nice wood
  3. zorgzorg2
    zorgzorg2 Tele-Meister Silver Supporter
    153
    Feb 27, 2008
    Norrköping, Sweden
    Thanks! I'm actually French, moved to Sweden about 10 years ago, so I know my camembert the real good one is hard to find and expensive here.
    About the walnut, it's American, as most of the timber they sell in my wood shop. (I wonder...) And walnut is difficult to grow here, it's a bit cold
    So I'm going the camembert way on this bass, called the Camembass! I will use stripes from the wooden box to fill the fret slots (it's going to be fretless).
  4. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    Great build, Martin! The bracelet is beautiful! How did you cut and smooth it out?
    And I’m more of a Brie man when it comes to soft-ripened basses. :lol::lol:
    I’m impressed with your resolve, working in your “roofless workshop” in Sweden, in the winter time, and it’s really looking good.
  5. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    Thanks Rick!
    The bracelet was cut out with a large drill bit, the kind you use to make holes for wall sockets. (like this one https://goo.gl/images/mDfVqw)
    I had two sizes, 70 and 80 mm, so I just drilled two concentric holes. From there on, it was just sanding. Applied some avocado oil for the finish, and voilà
    Brie can be good too of course, just make sure to choose the runny ones...
    About the shop, well it's not that cold yet, still around the water freezing point so it's fine. As they say here, there is no bad weather, just bad clothes. And, to be honest, I do have a space in the house where I'm aloud to work as long as no dust is generated. So eg routing with a vacuum cleaner attached to the router is tolerated by hq outdoor activities include sanding by hand, (the random orbital sander is also vacuum compatible) sawing, and everything smelly, like finishing with chemicals (hence my recent tests with shellac, more on that later).
  6. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    I got a little time to work on the neck this afternoon, so I routed the truss rod groove.
    Next is cutting/routing the neck, starting with the fretboard...
    LowThudd and John Nicholas like this.
  7. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    Finalised the truss rod groove with chisels, and cut the neck to shape... One step at the time... 1514934997960.jpg 1514935005248.jpg
    LowThudd likes this.
  8. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    By the way, a couple of thickness questions: how thick should the headstock be? And what thickness should the heel, respectively the neck at the nut, be? (that is without the fretboard) Atm it is 22mm which should be enough, right?
  9. Peltogyne
    Peltogyne Tele-Afflicted
    Oct 29, 2012
    Northern California
    I just ran my calipers over a number of headstocks and got .55 to .645 of an inch. So you're well over that. If the tuner you use has a screw on bushing it will have a range limit for thickness.
  10. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    Thanks. So I'm a bit thick atm
  11. Peltogyne
    Oct 29, 2012
    Northern California
    You could recess the bushings/washers to the thickness you need. It's a slick look and may lower the strings enough to reduce the need for string trees.
  12. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    I've angled the neck at 11 degrees, which I thought means I don't need string trees?
    But nice idea with the recess. I still have to slim the headstock a bit though, I don't want to have a neck dive problem...
  13. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    So today I got a bit done on different necks, including the one at hand. First I made a copy of the neck template:
    Using my home made router sled
    Then taped the headstock template to the headstock using double sided tape and used my router with sled to copy the shape to the headstock 1515020232640.jpg
    As you can see, cherry burns easily!
    Putting the neck in a stable position for routing isn't easy with an angled neck, how do you guys do that? I hade be creative... 1515020337939.jpg
    Next will be routing the neck sides and thicknessing. Planning on 21mm for the heel (neck pocket is 17mm deep) and 14mm for the nut, or is that too thin?
    Freekmagnet likes this.
  14. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    So today, I routed the neck edges to the template, and it seems to fit 1515084597436.jpg
    I went on and tried putting fret slot fillers (still with the camembert box). Trying different methods, It looks like using my regular fret saw and sanding the camembert wood a little thinner works best (lowest on last picture)
    Freekmagnet and MDent77 like this.
  15. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    Finished the day with sawing the fret slots and filling them. The wood of the camembert box is now all used .
    And here a side by side comparison with a bit of the same board with some shellac on it. 1515109335738.jpg
  16. Peltogyne
    Oct 29, 2012
    Northern California
    Yes, I'm not paying close enough attention. :)
  17. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    I got some time today to work some more on this project, and went on to radius the fretless fretboard (fingerboard?). I was considering building a router jig for that, but putting a router on such a thin piece of wood scared me, so my cowardice led me to do it by hand. Took an hour, sanded to 240 grit, and it looks good
    papaschtroumpf and oheare like this.
  18. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    Thicknessed the neck today: 1515447112664.jpg
    Leaving wood for the volute
    And then went on to glue the neck. No pics of that, phone was out of power. I will take one before I remove the clamps.
  19. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    À propos gluing the fretboard, I put all the clamps I had there, but I'm still unhappy with the applied pressure not being even. But iirc, I saw here someone using som kind of long elastic band and wound it around the neck and fretboard. Anyone got a clue on what material that is, and I get it? Thanks!
  20. zorgzorg2
    153
    Feb 27, 2008
    Norrköping, Sweden
    So here is the pic: 1515532316489.jpg
    Now I got a problem, obviously I missed that the fb was no really flat on the bottom, so I have a little space all along both sides of the neck about half a millimetre. Most of it has glue in it but there are some gaps, so it's not really nice to look at.
    So some questions I have now: will the neck still be structurally stable? It looks like it is from me pulling on the fb, but what do you guys say? If it is, next question is how to I mask this? I was considering making a little groove at the limit between the fb and the neck, and maybe fill it with something (wood dust? Pigments?)
    Any idea?
    Help...
    Martin
