Bridge string spacing question
Discussion in 'Tele-Technical' started by Skippy38, Dec 3, 2012.
  1. Skippy38
    Skippy38 TDPRI Member
    7
    Dec 3, 2012
    Melbourne, FL
    Ok, I am new to the forum. I recently got the opportunity to buy a very nice 2008 Lite Ash MIM Telecaster in natural finish. I love the look and feel, but have a question. The bridge string spacing is currently 2 3/16, which puts the high and low E strings fairly close to the edge of the fretboard. My old mexican strats had 2 1/16 so this was never a problem. Is this the correct spacing for this guitar? The guy before me put graphtech saddles on it so they are not original. Any help would be greatly appreciated.
  2. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    IDK if that is correct for that model, but it is certainly pretty wide. Look at the string through holes, and see if the strings are lining up as the come out of the holes and over the saddles.
    Another option would be to install a vintage style bridge with threaded steel saddles. That way you can line the strings up in the grooves of the threads to make your own custom bridge spacing.
  3. Skippy38
    7
    Dec 3, 2012
    Melbourne, FL
    Thanks. I think that I am going to take the strings and saddles off and take some careful measurements to see what I am working with. This is my first real Tele, I have been a strat man thus far.
  4. Skippy38
    7
    Dec 3, 2012
    Melbourne, FL
    It appears that this bridge: FENDER Bridge for MIM Telecaster / Mexican Tele 0053354000 is what is supposed to be on there. Can anyone tell me what the string spacing is for this bridge?
  5. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Dec 19, 2011
    Merseyside UK
    Fender p/n 0053354000 plate measures 3.932" x 3.148" x .097" thick. E to E 2.222". Manufactured by Ping in Taiwan.
    The often quoted figure for string spacing is 2 3/16" or 2.1875" so it's pretty close.
    The Graphtech Tele saddles also should give you an E to e of 2 3/16"
  6. Skippy38
    7
    Dec 3, 2012
    Melbourne, FL
    Thanks Tux. A call to Fender regarding part number 0053354000 got an answer of 2 1/16 string spacing for that bridge which is what I am looking for. I guess that I will know in a few days if it fixes my problem.
  7. jefrs
    jefrs Doctor of Teleocity
    Nov 20, 2007
    Newbury, England
    The strings must pass over the centre of their bridge pickup poles.
    - the important spacing.
    I have had Graphtech saddles on a strat, imo they sounded like they were made of hardened chewing gum (on the bedpost overnight). No great loss.
    Brass, steel or aluminium.
  8. Skippy38
    7
    Dec 3, 2012
    Melbourne, FL
    I agree. The graphtech saddles sounded kind of dead and are going to be no big loss. As it turns out what I thought was a stock 2008 Lite Ash Special Edition is really a 2008 neck on a 2010 body. You just cant trust craigslist people these days.....
  9. gsh1968
    gsh1968 Tele-Holic
    834
    Jun 16, 2008
    London UK
    Not sure why they told you that as it is 2 1/8". The US std bridge is 2 1/16".
  10. mtjo62
    mtjo62 Tele-Holic
    693
    Jul 17, 2008
    StatesVegas, NC
    Graphtech makes saddles for both 2 1/16 and 2 3/16 spacing. Previous owner may have used wider saddles to open up the spacing or just ordered the wrong ones.
  11. NewPort
    NewPort Tele-Meister
    256
    Nov 22, 2012
    Nye Beach, Oregon
    I got that MIM bridge off of ebay to replace a Chinese modern style bridge. The string spacing E-e is 2 1/8 inch or 54mm (that is center to center) . The saddles it came with are 10.8mm wide. All-in-all, very nice fitting bridge and covered all the warts from the chinese bridge I had originally.
  12. Tuxedo Poly
    Dec 19, 2011
    Merseyside UK
    The Gotoh GTC 201 and 202 bridges are also 54mm with 10.8mm saddles and, imho, better than the Fender Pings
  13. Skippy38
    7
    Dec 3, 2012
    Melbourne, FL
    Thanks Tux. Since now it seems that I have a partscaster instead of an original Tele, I am not afraid to experiment a little with it. If the Ping bridge does not work out I am going with the Gotoh.
  14. Vizcaster
    Vizcaster Friend of Leo's
    Sep 15, 2007
    Glen Head, NY
    I'm not sure I'd look at it that way. The important spacing is where the strings can be properly aligned with the neck. In an ideal world the strings would pass over the centers of the polepieces, but they don't. You'll still have a signal from the pickup if the string is a little off the polepiece, but you won't if the string slips off the edge of the frets.
  15. NewPort
    256
    Nov 22, 2012
    Nye Beach, Oregon
    I took a look at the Graphtech saddles and you are correct, 2 1/16 or 2 3/16 string spacing.
    The Modern bridge that came on my tele had the 2 1/8 spacing for the string holes and the saddle mount holes, but the saddles that came with it were the narrower ones (10.5mm) which worked but tended to leave spaces between the saddles. I like the fit of the saddles that came with the Ping bridge, no space between the saddles but not over sized that causes them to splay-out. As far as I know this would be the same for the Gotoh or Ping bridge, I believe the Gotoh is chromed brass where the Ping is chromed steel. I haven't made a side by side comparison but the Gotoh is generally preferred.
  16. jefrs
    Nov 20, 2007
    Newbury, England
    You do get a poor signal (weak note) if the string is off centre on the poles.
    If they go over the centre of the pole, chances are they will go up the neck correctly. Pickups come with different pole spacing too.
    Best way to check alignment on neck, as used for initial positioning of the bridge plate, is to use string on 1st and 6th down to the tail.
    It is also possible to adjust the neck angle up or down, there is enough wiggle room to do this.
  17. Skippy38
    7
    Dec 3, 2012
    Melbourne, FL
    OK, so I got the bridge today and it is exactly the same spacing as the old one. I guess that I am stuck with this spacing, although it just doesnt look or feel quite right.
  18. jefrs
    Nov 20, 2007
    Newbury, England
    Oh dear. But they do come in different spacing.
    52.5mm spacing Fender http://www.axesrus.co.uk/Modern-Fender-Telecaster-Bridge-p/099-0807-200.htm
    http://www.axesrus.co.uk/Modern-Telecaster-Bridge-s/1898.htm
    52mm spacing http://www.axesrus.co.uk/Axesrus-Modern-Telecaster-Bridge-Modern-Saddles-p/axetele-mod.htm
    54mm spacing "import"
    http://www.axesrus.co.uk/Modern-Import-Telecaster-Bridge-Humbucker-p/bt004.htm
    http://www.axesrus.co.uk/Modern-Import-Telecaster-Bridge-Vintage-Saddles-p/bt002-cr.htm
  19. NewPort
    256
    Nov 22, 2012
    Nye Beach, Oregon
    One thing we failed to do was have you post a picture of what you have. Maybe what you have is an aesthetics problem. Anyhow as Jefrs posted there are many options.
  20. nadzab
    nadzab Friend of Leo's
    Mar 23, 2009
    New England
    +1. IME, polepiece spacing is less important than it seems like it would be.
