Bridge Match for Neck Seymour Duncan SH-2N
Discussion in 'Just Pickups' started by davidguilbault, Jun 7, 2013.
  1. davidguilbault
    davidguilbault Tele-Meister
    114
    Apr 16, 2012
    Seattle
    Hi folks.
    I have a used Mexican Telecaster (Partscaster). It has a Seymour Duncan SH-2N humbucker as the neck pickup and an unmarked single coil as the bridge pickup.
    So, which Seymour Duncan pup (single-coil size) in the bridge would be a good match for the SH-2N in the neck? (The guitar is routed for single-coil in bridge.)
    I play rhythm guitar and like a warm, dark sound. The neck is solid Honduran rosewood. I don't know the body wood.
    Thanks very much for your time and consideration.
    Hope all is well with you and yours.
    Cheers for now.
    David.
  2. elelpe
    elelpe Tele-Afflicted
    May 1, 2008
    SEA
    That would be a JD. A2Pro would work too but you need to do a lil bit height adjustment.
  3. KyAnne
    KyAnne Tele-Holic
    898
    Oct 8, 2011
    Swamps of Louisiana
    SD l'il 59 humbucker drops right in the bridge slot. Can be warm and or very potent. Gets rid of that ice pick twang.
  4. davidguilbault
    114
    Apr 16, 2012
    Seattle
    Thanks folks. The recommendations seem to be one of these three:
    Little '59 Humbucker (ST59-1B)
    Alnico II Pro Lead for Tele (APTL-1)
    Jerry Donahue Tele Lead (APTL-3JD)
    Which would be the most versatile? What say you all?
    Cheers for now. David.
