Brazilian walnut tele build got a question
Discussion in 'Tele Home Depot' started by playforfun, Dec 18, 2013.
  1. playforfun
    playforfun Tele-Holic
    661
    Feb 25, 2013
    Luna Louisiana
    My friend an tech is going to build my dream guitar. I've always wanted a rosewood telecaster but have never been able to find one. He is going to make a 2 piece body from some rosewood he's had for years. The wood is 1 1/2 in thick. What is the normal thickness of a tele body an does it matter? Thanks for any input or suggestions on this project. We will start after Christmas. The only thing I'm pretty sure of at this point is that I will use a 1970 bridge an pick up from another tele I have.
  2. playforfun
    661
    Feb 25, 2013
    Luna Louisiana
    Ok just found the spec's for a normal tele build. Looks like mine is gonna be thinner.
  3. PumpJockey
    PumpJockey Friend of Leo's Ad Free Member
    Oct 12, 2010
    New Joisey
    Thinner will be better for this one. Rosewood can be heavy. You may need to go with smaller pots in order to fit in a shallower control cavity.
    Good luck!
  4. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    I have done several thinner Tele bodies.
    CTS pots will fit no problem. The issue is the depth needed for the switch.
    The bottom floor of the control route will be about 1/8" to 3/16" thick.
    Mount the switch in the control plate.
    Bend the bottom terminals on the switch straight out, 90 degrees.
    Set the plate on the top of the body and mark the bottom of the switch on the outside of the body.
    Set your router to that depth.
    If the body is any thinner than 1.4" and you will have to use a SG type switch.
  5. playforfun
    661
    Feb 25, 2013
    Luna Louisiana
    Thanks for the info. I'll post progress but is gonna be slow.
  6. RogerC
    RogerC Poster Extraordinaire Vendor Member
    Mar 30, 2011
    Oklamerica
    Just about every tele I've built has been 1 1/2" thick. I've even made one thinner, but I had to use a different switch because the standard tele switch was too deep.
  7. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    I prefer then thinner...
  8. playforfun
    661
    Feb 25, 2013
    Luna Louisiana
    Ok has anybody ever held a rosewood tele? I stopped by tech's shop today an held what will become the body of my rosewood tele. It's beautiful an weighs a ton. I generally like a tele to be a plank of wood but really think I'm gonna ask him to contour the body for weight relief. Just the belly cut but this is still gonna be heavy. Here's what I have so far.
  9. playforfun
    661
    Feb 25, 2013
    Luna Louisiana
    Thanks for the thread now I have a lot to think about. I was planning on keeping it solid. The wood was given to me by the tech an he is doing the build at no charge so I'm gonna let him guide me. He is open to suggestions but that may be asking too much. That is one of the best looking guitars I've ever seen. Mr Rutters is a very talented builder!!
  10. playforfun
    661
    Feb 25, 2013
    Luna Louisiana
    Ok after research discovered this is not rosewood but Brazilian walnut or IPE. Anyway still excited about this build just don't want to be misleading. I'll continue to post my progress.
  11. gagidlof
    gagidlof Tele-Holic
    972
    Jun 3, 2009
    Marysville, WA
    Wow, an Ipe guitar, that is going to be heavy. I love Ipe, it rings like a bell, bright and almost bone like. I've used it for fingerboards before never had a piece big enough for a body. I'd seriously consider making it chambered, and I'll bet it'll be beautiful.
  12. Barncaster
    Barncaster Poster Extraordinaire
    Ipe is beautiful. I took a chance one day and bought a $40 Tele-ish homebrew body painted in thick gooey orange sparkly stuff off eBay. Nothing against sparkly stuff when done right but this stuff was shoveled on. After stripping it I found beautifully grained Ipe was waiting underneath. Now this guitars weight could embarrass an LP but she is beautiful and the two Firebird style pups now in there are very happy. Chambering is a good idea!
    Rob
