Bourbon Barrel Staves for body
Discussion in 'Tele Home Depot' started by Brockuza, Jun 17, 2019.
  1. Brockuza
    Brockuza TDPRI Member
    California
    Hi all
    Not sure if this is the right thread to post to, so if anyone thinks I should repost elsewhere, please let me know.
    Anyway. I have a chance to pick up some retired bourbon barrels from a local brewery, and I was thinking about using them for a body. I know the top/bottom of the barrels are relatively flat, but they don’t provide a lot of wood to work with, so my next option would be to use the staves. However, the curve of the staves is the real issue I’m dealing with. Would anyone have a suggestion on how to straighten the staves out? Would I get them damp and then clamp them to a flat surface? Or would I have to plane them down pretty thin to make that work (not opposed to this because I could use it as a top for a semi-hollow)?
    Thanks
  2. guitarbuilder
    From what I've seen, staves used to be steam bent. If these are made that way, then I guess it's possible to reverse the process through heat/steam and clamps. I probably would just go buy some oak myself but it's all about the journey :). If you planed them down flat, you could theoretically make some kind of a top to be glued to a base material. Since they would be fatter in the middle, you'd lose a lot of stave to end up with a uniform width I would think. Maybe an epoxy fill in the spaces like these guys do with tables these days could be another option.
  3. maxvintage
    maxvintage Friend of Leo's
    Arlington, VA
    Yes you could try bending them but that's a tough slog. You'd still have to do a lot of planing. Depending on the size of the barrel and the degree of the curve I'd think about just planing them down to a thin top.
    I think somebody here made a bourbon or wine barrel guitar a few years back
  4. Dennyf
    Dennyf Tele-Afflicted
    Charlotte, NC
    Just buy one of these.
    LeftFinger likes this.
  5. old wrench
    old wrench Tele-Holic
    corner of walk and don't walk
    Many moons ago, I made some end tables out of retired bourbon barrels.
    As I recall, the "heads" or ends of the barrels were about 20" in diameter.
    I think I'd look at using the heads instead of the staves ;).
    Best Regards,
    Geo.
    Steveinthesticks and LeftFinger like this.
  6. Brockuza
    California
    Yeah you’re right, I think the tops will definitely be the best option. I’d hate to waste the staves, but the wife has some ideas for reclaimed wood decorations around the house, so maybe I can put those to good use there.
    I appreciate the quick replies!
  7. trapdoor2
    trapdoor2 Tele-Holic Gold Supporter
    Nawth Alabama
  8. old wrench
    Back when I made those tables (mid 1970's), I purchased the barrels from a lumber yard that had bought a bunch of them. The barrels sold for under $10 bucks each, but that was still a considerable amount of money.
    But on the other hand, they were about as pretty as a wooden barrel can be :).
    They were single use barrels and beautifully made; all nice clear oak and in pristine shape, not a speck of rust on the hoops, either.
    Now a days, from what I understand, there is a secondary market for the used barrels with vintners who put up there wine in them.
    I'll tell you one thing to be prepared for though, a big blast 101 proof aroma when you cut through the barrel ;).
    The barrels I used had their insides fire-charred, too.
    Sounds like a fun project :).
    Best Regards,
    Geo.
  9. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Look up BigDGuitars and Justin Johnson on youtube. The one builds and the other plays a couple of whiskey barrel Teles.
    I'd take the approach to cut the bent staves into thinner but flat pieces and glue them to get thickness and width, or just an oak cap and pine body.
    You can also look up Wallace guitars in Detroit for how they are building with old house lumber.
  10. Freeman Keller
    Freeman Keller Tele-Afflicted
    Archtop
    Barncaster, Zepfan and LeftFinger like this.
  11. LeftFinger
    LeftFinger Tele-Afflicted
    Saskatchewan
    More like Hoop top
  12. LuckyJinx
    LuckyJinx TDPRI Member
    Portsmouth, Shire of Hamp
    These guys are using wine barrels for their guitars, maybe you can hunt around their website for clues (or just ask them):
    http://www.paolettiguitars.com/our-story/
    Sent from my FRD-L09 using Tapatalk
  13. Splodgeness
    Splodgeness TDPRI Member
    Coventry, England
    Just thinking laterally ( literally :) ) here..... Could you glue them up sort of sideways... like (((((( ?
    Might make for an interesting pattern on the guitar top?
    Norrin Radd likes this.
  14. Flakey
    Flakey Friend of Leo's
    The Land of 10,000 Lakes
  15. Hatfield92
    Hatfield92 Tele-Meister
    Largo, Florida, USA
    That’s a minor inconvenience compared to the Wild Turkey and Heaven Hill fires.
    God, I miss bourbon country at times.
