Boss SD1 help.
Discussion in 'Burnt Fingers DIY Effects' started by leonard d rock, Apr 19, 2019.
  1. leonard d rock
    leonard d rock Tele-Afflicted
    Malaybalay,Bukidnon, Phil
    my boss Sd1 has suddenly developed a crackling noise when on. i tested the pedal already on the board, alone, with power supply and battery, changed cables etc all the possibilities and it still has that cracking sound.
    any ideas where to start fixing?
    thanks
    ldr
  2. sirbergersworth
    sirbergersworth Tele-Meister
    St. Louis, MO
    Crackling sound only when you play? What about with no cable plugged into the input of pedal but pedal plugged into amp?
    leonard d rock likes this.
  3. tubejockey
    tubejockey Tele-Meister
    the bozone
    Start by cleaning the pots and jacks with DeOxit. Did you ever by chance plug in a reverse polarity adaptor or put in a battery backwards? This can cause opamps to develop a hissy noise.
    leonard d rock and Charlodius like this.
  4. leonard d rock
    my power supply is a one spot which has a set polarity switch. i dont know how you can put a battery backwards.
    ill try the 1 cable tho.
  5. sirbergersworth
    St. Louis, MO
    Do you have any digital pedals in the one-spot daisy chain with the overdrive?
  6. leonard d rock
    no. my chain is just sd1, OCD or Ds1 Boss Ch1 and Dd3.
  7. brokenbones
    brokenbones Tele-Meister
    Indy
    If you're sure you've isolated the problem to inside of the pedal, I would take out the circuit board and start to lightly tap around solder connections. Use a chopstick or the eraser on a pencil.
  8. leonard d rock
    solved the problem. one of the wires had broken from its spot so i just resoldered it and no more problem. thanks all
    zippofan and sirbergersworth like this.
