Boothill 5e3 No Sound
Discussion in 'Shock Brother's DIY Amps' started by Paul Strat, May 13, 2018.
  1. D'tar
    D'tar Tele-Afflicted
    Jan 11, 2013
    WNY
    The OT secondary should not matter if it is only two wires and negative feedback loop not in the circuit. I always use black for ground and the green for signal.
    What OT are you using?
  2. Paul Strat
    Paul Strat Tele-Meister
    109
    Apr 7, 2017
    Muscle Shoals, AL
    ClassicTone
  3. D'tar
    Jan 11, 2013
    WNY
    Should havea pn on it like 40-18022 or similar
  4. Paul Strat
    109
    Apr 7, 2017
    Muscle Shoals, AL
  5. corliss1
    corliss1 Friend of Leo's
    Sep 13, 2008
    Lansing, MI
    D'tar likes this.
  6. Paul Strat
    109
    Apr 7, 2017
    Muscle Shoals, AL
    87387BF1-392A-4377-8C2E-0781EC9F5E5B.jpeg Jacks look right?
    D'tar likes this.
  7. D'tar
    Jan 11, 2013
    WNY
  8. corliss1
    Sep 13, 2008
    Lansing, MI
    Sure does.
    If this were my amp I would go through and do all the wire adjusting/shortening you wanted to do first, then continue on with troubleshooting. That way you'll be checking each wire and component as you guy and you may fix it during that process.
    If you want to get it running, I'd highly recommend now is the time for signal tracing.
  9. Paul Strat
    109
    Apr 7, 2017
    Muscle Shoals, AL
    Sounds like a good plan.
  10. Paul Strat
    109
    Apr 7, 2017
    Muscle Shoals, AL
    Now have heavily distorted low volume guitar sound and a loud steady hum.
  11. corliss1
    Sep 13, 2008
    Lansing, MI
    What did you change?
    It now sounds like there may be multiple issues going on.
  12. D'tar
    Jan 11, 2013
    WNY
    Rewired the output/speaker jacks
  13. corliss1
    Sep 13, 2008
    Lansing, MI
    In the previous picture, are you making sure to plug into the left most jack?
  14. Paul Strat
    109
    Apr 7, 2017
    Muscle Shoals, AL
    Appears to be the ground wire on the speaker jack. be right back
  15. Paul Strat
    109
    Apr 7, 2017
    Muscle Shoals, AL
    Everything is good except for a slight hum. Found the source of it.....naturally on the bottom side of the turret board
    Will fix later
    Many thanks for all the help!!!!
  16. Paul Strat
    109
    Apr 7, 2017
    Muscle Shoals, AL
    Well she’s back to no sound.
    For some reason have 118v on pin 8 of v2
  17. D'tar
    Jan 11, 2013
    WNY
    maybe trim this pinched wire and start back at post #14, rinse,repeat.
    and this.....
  18. Preacher
    Preacher Friend of Leo's
    Apr 17, 2007
    Big D
    Paul it sounds like you have a cold solder joint somewhere. It makes contact and you are good, heats up and then moves a bit and no contact. Check continuity and reflow the joints, I actually have a magnifying glass that I look at the joints with. It helps to see if the edges really grabbed to the component or if they are riding on the top.
    SacDAve likes this.
  19. Paul Strat
    109
    Apr 7, 2017
    Muscle Shoals, AL
    After a fresh start this morning I realized that after shortening and rerouting some leads and cleaning up some joints, I had connected v2 leads from pins 7&8 backwards. Sound is good now. Still have a hum that increases and decreases with volume control.
