Bone Voyage
Discussion in 'Tele Home Depot' started by preeb, Dec 10, 2014.
  1. preeb
    preeb Poster Extraordinaire Vendor Member
    Sep 10, 2008
    Sonoran Desert
    Celluloid Nitrate is a dangerous material and normally can not be shipped overseas. You'd better not drop your cigarette on that binding (-;
    The modern plastic imitations look so bad that nobody wants to use them..
  2. preeb
    Sep 10, 2008
    Sonoran Desert
    You're welcome Brett.
    Thank you!
  3. preeb
    Sep 10, 2008
    Sonoran Desert
    Thanks guys!
  4. preeb
    Sep 10, 2008
    Sonoran Desert
    I love it too. The board looks sweet.
  5. preeb
    Sep 10, 2008
    Sonoran Desert
    Thanks Nick. The acoustic model will have an option for a floating low profile neck PU. The electric models will have 1 or 2 AirGap PU's through the top.
    Thanks for that book suggestion. Ordered!
  6. preeb
    Sep 10, 2008
    Sonoran Desert
    Body joints are perfect. Guess I'll be using the simple clamping method in the future.
    Excess maple overlays are roughly trimmed
    Like the other Bone models the back body corner is smoothed but on the Bone Voyage the binding get in the way so it will be done a little differently and the binding will need to take a round turn. Marked
    roughed
    and chiseled
    Just for reference I inserted the neck.. the 3 ledges will be smoothed nicely at final sanding in a few days.
    Before I cut the binding channels there's one more thing to do. Neck fillet is sawed and sanded flat
    board is centered over the neck and I pencil its outline over the body just to verify the board's edge is exactly aligned with the cutaway.
    It is.. we're good to go.
    While I'm at it I also inspect the fitting between the neck and the body
    a little spoiler.. (-;
  7. preeb
    Sep 10, 2008
    Sonoran Desert
    I cut the binding channels free hand on my dome jig
    two quick passes do the job
    A little BooBoo...
    I thought I had the locator pin drilled within the binding section but I missed by a tiny bit.
    Will fix it later..
    rounded corner is done with a chissel as my channel cutter will not reach it..
    I bound the body with all 3 strips at the same time and use acetone as glue.
    But... If I could only do them in the correct order... LOL
    I noticed something looked strange... I switched the black and the white strips.
    Here we go again..
    and the back
  8. Barnaby
    Barnaby TDPRI Member
    46
    Jun 16, 2011
    Tokyo
    Off topic, but is that a Tissot T-Touch you're wearing? I love those things, but my wife would never let me buy one. The compass on them is perhaps the single coolest thing I've ever seen on a watch! :D
  9. jipp
    jipp Friend of Leo's
    impressive. that rosewood sure is pretty.. yet the traditionalist still want boring no figure rosewood slabs.. never will understand that. but its all good.. great thing about wood. it has so much variation between every piece even pieces in the same tree. its all pretty. but ill take trippy looking grain, personal preference. :D
    i like how you floated the top. lot easier than iv seen others do it. keep up the great work.
    chris.
  10. preeb
    Sep 10, 2008
    Sonoran Desert
    Truss rod pulled out of its channel and removed. I now cut the TR nut stepped access hole
    like this
    Rod is bee waxed and inserted back
    That's the nut.
    Slicing the tenon to align with the board line I marked
    like that
    Nut is mounted and the rod is tested to extreme to make sure it's anchored and functioning will
    This is how it will look relative to the board
    Headstock TR plug is hide glued. In case the rod will ever need service or replacement (highly unlikely.. but still) it will be easy to steam the plug and pull the rod out.
    Lunch!
  11. preeb
    Sep 10, 2008
    Sonoran Desert
    Yeah. I destroyed my Omega Speadmaster Moon Watch with the magnetic field of the PU charger and I need to ship it for service. Guess the astronauts didn't encounter strong magnetic storms in the outer rim of the galaxy back in the 60's (-;
    This Tissot doesn't care.. it's a rigid piece of technology.
  12. preeb
    Sep 10, 2008
    Sonoran Desert
    Actually.. many ask me for highly figured BRRW boards.
    I use rift or flat cut figured boards on the Bone line and QS for thraditional replicas..etc..
  13. jipp
    oh, well thats cool. iv seen lots who like the other because original fenders came like such.. its all good. i like figure that's for sure..
    chris.
  14. D'tar
    D'tar Tele-Afflicted
    Jan 11, 2013
    WNY
    Good morning,(here at least)
    Speaking of lunch..... Any chance of getting a sandwich Gil. It's been a while since a good sandwich!
    Brett
  15. Scooby Snax
    Scooby Snax Friend of Leo's Silver Supporter
    Apr 26, 2009
    Toronto
    I'm thinkin' Montreal Smoked Meat on Rye... Schwartz's anyone?
  16. emoney
    emoney Tele-Afflicted
    You do such great work, Preeb. I'm also looking forward to see how these integrated
    braces work out.
  17. preeb
    Sep 10, 2008
    Sonoran Desert
    I don't do that any more.
  18. preeb
    Sep 10, 2008
    Sonoran Desert
    Neck is sanded flat and tapered
    Fingerboard's bottom is scraped flat and sanded with 80 grit for better adhesion.
    Neck is heated
    Board is hide glued
    Holly veneer will be used on the HS face
    Cut
    Mother of Pearl logo inlay
    Filler is hide glue mixed with lamp black powder.
    I heat it up
    and let it set over the inlay
    Headstock center line penciled
    bottom of the veneer is sanded flat. Even though it's not fully dry yet it's solid enough to be glued. It will dry over night and sink but I can refill it tomorrow.
    Veneer is hide glued
    No sandwich this evening.. it's Hanuka!!!
    Today we light the first candle (out of 8) and eat a Sufgania (Jewish Doughnut)
    Like this (-;
  19. preeb
    Sep 10, 2008
    Sonoran Desert
    Thanks. Me too. The tap tone is great and the top is pretty solid in the center so I guess it's not bad (-;
  20. jipp
    ooo them treats look good. i wish you a great holiday. ill admit im ignorant of your traditions and all but i can wish you all the best and even more success and good health for you and your family for 2015 too.
    long live rock. :)
    chris.
