Bolt - new model proto build
Discussion in 'Tele Home Depot' started by preeb, Apr 17, 2014.
  1. RickyRicardo
    RickyRicardo Friend of Leo's
    Mar 27, 2012
    Calgary, Alberta
    Yippee! Another guitar or two from Gil to drool over...
  2. Bentley
    Bentley Friend of Leo's
    Jul 25, 2012
    Kelowna B.C, Canada
    cool. I'm jealous of your vast collection of wood. I wonder how much your stash is worth...
  3. mlp-mx6
    mlp-mx6 Tele-Holic
    717
    Jan 20, 2008
    Atlanta
    Fantastic, Gil! I look forward to what I'll learn here.
    A couple things:
    The name - Carvin already has a guitar line called Bolt
    http://www.carvinguitars.com/catalog/guitars/bolt
    The neck join - anything fancy like Anderson's A-wedgie coming? Or will it be a more "standard" flat tenon joint?
    Michael
  4. Jupiter
    Jun 22, 2010
    Osaka, Japan
    Yes, I'm really excited to see your neck join solution. Fender's standard heel/pocket design has never been very comfortable for me and my little hands.
  5. supersonic1414
    supersonic1414 Tele-Meister
    127
    Jun 17, 2009
    dallas, tx
    Gil is a virtuoso. So proud to own several of his builds. See a Bolt in my future.
  6. preeb
    preeb Poster Extraordinaire Vendor Member
    Sep 10, 2008
    Sonoran Desert
    Neck is made of figured hard maple and can either have a BRRW or a maple board.
    In case of a maple board I will use the same neck blank for both neck and board which is also the case for this proto.
    Template printed..
    cut
    and very carefully smoothed keeping the neck edges 100% flat.
    Tuner holes and mounting screw holes are drilled and the two index pin holes are drilled as well in the headstock and neck heel
    1 1/4" maple stock with nice birdseye figuring..
    cut
    and sliced open to separate the fingerboard from the neck.
    I will later reverse the two parts to get a stronger and more stable neck.
    I make sure the board is 100% straight as it should be.
    Those maple blanks were air dried and gradually thicknessed for 5 years!!
    Both parts are trued and thicknessed in the drum sander
    Nice and flat..
    Notice that I haven't trimmed the blank prior to slicing it. The reason for that is to prevent the cutting from splitting the clean surfaced trimmed edge.
    both parts should measure a little over 1"
    I sliced the board off of the back of the neck and I now flip it to the front.
    Using a flipped split maple gives a much more stable neck because the natural tendency to move in a certain direction is now balanced by the reversal.
    Neck part is spiral trimmed
    tuner holes.. etc..
    I add a 3/16" channel to the bottom of the neck template
    Shim the heel end by 1/8" to get a deeper truss-rod channel in the heel area and rout a straight (Yes.. 50's Gibson type straight..) rod channel on the pin router
    Rod is heated
    Bent
    Pressed and hardened in cold oil
    I cut the excess off like this to create the anchor (same as the Bone truss rod)
    I use the excess part of the rod in the channel and hide glue a short fillet over it.
    Like that
    As the glue sets, the short rod ( used as gluing spacer ) is removed and a 3/4" diameter shallow cut is made with a spot facer
    like this
    and followed by a 3/8" spot facer
    like that
    I now test the drilling depth with the spoke wheel TR nut.
    It should come in contact with both the bottom of the drill and the 3/4" brass spacer.
    This way the pressure is spread across a larger area preventing excessive wood compression that can lead to neck issues down the road.
    The truss rod is deeped in bee's wax and pushed into the slot
    Long fillet part is hide glued and lightly clamped
    The Bolt truss-rod is running from the nut to the end of the heel and will affect the entire playing area of the neck (unlike the traditional F designs where the compression is about 1" away from both ends)
  7. preeb
    Sep 10, 2008
    Sonoran Desert
    As the wood cures I sand the bottom of the neck flat
    and remove the little part of the brass spacer under the heel
    Another last trip to the drum sander to shave the fillet and true the neck surface
    The sanding is a little coarse and I need to scrape the neck and board surfaces before gluing in order to get a seamless glue line
    320 hide glue is used for the fingerboard joint and it gels in about 10 seconds... so I have to heat the neck to get a few extra seconds before it is clamped
    Sorry, but no photos while gluing.. but here's the monster sandwich clamp
    All the glue is squeezed out by quickly tightening the clamp
    and inspecting the glue line through the squeezed glue (it acts as a magnifier) making sure it's void free.
    It will need to cure for at least 24 hours in a hot room to make sure all the moisture is out before releasing it from the jig.
    Shabbat Shalom.
  8. MatthewDickin
    MatthewDickin Tele-Afflicted
    Amazing - this is going to be fantastic.
    Gil, looking down my list of subscribed threads on TDPRI, they are all your builds. This one is no exception - can't wait to see how this turns out.
  9. Doubletriode
    Doubletriode Tele-Meister
    192
    Mar 23, 2008
    Geneva,Switzerland
    Hugh!!! That's a torture machine!!! :p
    I am not sure that I understood this correctly...
    When you say :"Shim the heel end by 1/8" to get a deeper truss-rod channel in the heel area and rout a straight (Yes.. 50's Gibson type straight..) rod channel on the pin router", you mean the truss rod channel is straight (no curved bottom) but closer to the fingerboard by 1/8" on the heel side?
    I am really happy that you started a new thread: a lot more to learn and enjoy for all of us.
    Thanks Gil!
  10. preeb
    Sep 10, 2008
    Sonoran Desert
    A straight channel with the rod being closer to the board on the nut side and deeper on the heel side.
  11. Doubletriode
    192
    Mar 23, 2008
    Geneva,Switzerland
    :confused: Ohhh... I had it the other way around...
    Thanks Gil!
    :oops:
  12. '59_Standard
    '59_Standard Tele-Holic
    851
    Jan 27, 2010
    Worldwide
    Hence the brass washer being over the edge! - Duh. I thought you'd drilled it wrong for a 'mo, there. :lol:
  13. preeb
    Sep 10, 2008
    Sonoran Desert
    It would still work fine the other way around... but the neck tapers toward the nut and it's better to follow it in case someone wants a thinner neck.
  14. preeb
    Sep 10, 2008
    Sonoran Desert
    Haha... no.. I measure 10 times, draw it 20 times and only then cut (-;
    I prefer a larger spacer to spread the truss-rod pressure as much as possible.
  15. cleanheadsteve
    cleanheadsteve TDPRI Member
    95
    Mar 4, 2010
    Arkansas
    Ton of great info here. Pics are super. Thanks again
  16. RickyRicardo
    Mar 27, 2012
    Calgary, Alberta
    I don't know if they are related but a guy named Wayne Bolt built Bolt Guitars back in the early 90's or something.
    http://betweenthesounds.com/bolt-guitars-brochure/
    I hope that isn't going to be a problem for you Gil.
  17. Doubletriode
    192
    Mar 23, 2008
    Geneva,Switzerland
    I am sure Gil has chosen the name as an homage to a jamaican guy named Husain who is lightning fast!!!
    :D
  18. LightninMike
    LightninMike Tele-Holic
    586
    Nov 30, 2010
    Perrysburg, Ohio
    Your attention to detail is always wonderful. The documentation....the thought behind the action...
    Thank You
  19. Greg M
    Greg M Tele-Holic
    896
    Sep 4, 2003
    Virginia
    Great guitar design Gil. Love the "sandwich clamp" too. I'll have to make one of those soon. :idea:
  20. preeb
    Sep 10, 2008
    Sonoran Desert
    Ahh... busted..
