Blues Deluxe Does Not Break Over
Discussion in 'Amp Central Station' started by Owensv, Apr 20, 2017.
  1. Owensv
    Owensv TDPRI Member
    45
    Dec 22, 2012
    Canton, OH
    For all you Blues Deluxe owners- have any of you had problems getting the amp to go into overdrive? Mine refuses. I mean I've hit it wide open on the pickups (tele vintage pups wired in series), on the drive channel, with drive on 12 and the master up so loud it hurt... lots of unmusical noise ensued, but no growl or grit. I've seen YouTube videos where this amp distorts so nicely, but mine won't. My tubes are all new. Any helpful suggestions from experience are much appreciated.
  2. Silverface
    Mar 2, 2003
    Lawndale CA
    It sounds like the output tubes are biased cold, or are weak, or the phase inverter is weak, or a preamp tubes, or a coupling cap is the problem, or a bypass cap, orit's a speaker problem...no way to tell without checking it out. I recommend taking it to a tech.
    Wally likes this.
  3. rburd2
    rburd2 Tele-Afflicted
    Sep 13, 2016
    Georgia, US
    I mean, yeah, go get it checked out....but if the way it's running now isn't potentially damaging to the amp, then you might have an insane clean headroom amp there.
  4. Silverface
    Mar 2, 2003
    Lawndale CA
    A Blues Deluxe that doesn't have component problems isn't inherently "cleaner" than another. It's a matter of tubes, bias, and possibly other components. Unless something is actually wrong and needs to be repaired/replaced they all can be adjusted for less headroom.
  5. Route67
    Route67 Tele-Meister
    368
    Jan 14, 2017
    My guess is the high volume clean is due to the new, "hard", heavy duty output tubes. Original amp design aimed for high fidelity with minimal distortion. Hot bias + "soft" cheap tubes will make it break up at volume.
  6. JD0x0
    JD0x0 Poster Extraordinaire
    Feb 22, 2009
    New York
    I dont buy it... Turning up the 'Drive' doesn't push the output tubes into OD. It pushes the preamp stages, which should be distorting. The power tube bias shouldn't really have any effect on 'drive' controls since they typically control preamp gain. The 'Drive' channel gets its distortion from the preamp primarily. Output tube bias would explain, possibly, why it's staying clean when you crank the master volume, which is generally what will push the output section into overdrive.
    If the 'Drive' channel is not breaking up, something in the preamp is likely malfunctioning. What are your tonestack settings?
    Wally likes this.
  7. clintj
    clintj Friend of Leo's
    Apr 4, 2015
    Idaho
    Tech time. With a multichannel amp like that, you need experience checking relay positions, tracing signal, and a signal generator + scope are a must to see what the issue is.
    In the meantime, you could swap in a set of spare tubes and see if it comes back to life. You'll need them eventually, anyway. It's just good practice for owners of tube amps to have replacements, since they seem to go south at the most inconvenient time possible.
  8. Owensv
    Owensv TDPRI Member
    45
    Dec 22, 2012
    Canton, OH
    JD0x0 - That squares with all my tests. I'm getting the preamp tubes checked out later today. The tone stack is stock, 25k, 1M, and 25k as I recall, for treble, bass, mid. I painstakingly verified proper relay function, so I know the circuits are switching properly. I just wondered if anybody else out there has had a similar problem, of if I just happened to get the one lucky amp. Thanks
  9. hs0504
    hs0504 TDPRI Member
    30
    Mar 24, 2011
    Holland
    I have the some 'problem'. But I have a 12AY7 tube in V1. Maybe that's why I don't get distortion in channel 2.
