Join TDPRI Today
blade neck pickup mount no pickguard. ideas?
Discussion in 'Tele Home Depot' started by hick 67, Mar 12, 2013.
  1. hick 67
    hick 67 TDPRI Member
    45
    Nov 15, 2010
    western colorado
    I have a Lollar charlie christan blade pickup that i want to use in the neck position of my first build. It is a double-f hole thinline style and i was going to mount all the controls through the wood les paul style and not use a pickguard. I have shaped my body, and have the template attached with standard tele PU route shapes. I cut my chambers with a jig saw and have glued on the top cap (with f holes already cut) and was going to glue on the back cap, with an access panel, when i was done with the top routes and drilling control holes.
    What are some ideas for mounting this PU? I was thinking of gently taking off the laminate top plate for the PU, and routing a shallow channel that fits the body of the PU tight for the top 3/8" and then opens up for the wires, and mounting it from the back, then re attaching the laminate PU top on the top of the guitar after it was installed. I figure i could have a second access panel in the back that would let me get to it. However I think it would be a pain to build a chamber though that would allow me to mount it and not crowd the wires etc.
    Or maybe i should route out a regular neck PU cavity and then build a plate out of something like laminate or maybe light steel that would have an opening that matches the shape of the top piece?
    Any advice would be greatly appreciated, especially for builders that have done pickguard-less builds before.
  2. clsatt
    clsatt Tele-Afflicted
    Mar 14, 2009
    virginia
    65 views and no takers.... I'll give it a go. One option that I think could create a really clean finished look-- would be inserting the pickup from the neck pocket.:eek: hear me out. If you use a key hole bit to widen the space for the bottom bobbin and remove the back of the neck pocket, the pickup could be slid in and then the neck could be mounted and as long as the pickup is close to the neck (or touching) there would be no gap to be seen.
    Just a thought.
  3. I_build_my_own
    Mar 9, 2012
    New York
    Personally I'd go with this but I am a bit :rolleyes: conservative.
  5. clsatt
    Mar 14, 2009
    virginia
    Like a pickup ring... I thought about that but where's the drama!
    A
    Or
    B
  6. hick 67
    45
    Nov 15, 2010
    western colorado
    clsatt, i like your option A. I found a sheet of BWB binding that i could salvage a piece from. I have plenty of drama in my life already.
    How do i cut the inside slot for the blade? I do not think my bearing bevel-cut router bit could do something that small.
  7. Rednecktele
    Rednecktele TDPRI Member
    48
    Feb 14, 2013
    Sacramento CA
    working the ring
    Hi, perhaps drill short on the ends, Dremel with rotary cutter, and file to fit?
    I'm sure there ARE better ways tho.....
    Mike
  8. jefrs
    jefrs Doctor of Teleocity
    Nov 20, 2007
    Newbury, England
    I have fitted pickups with no pickguard from the back but you are too close to the neck for that.
    Screw into the wood, like a body mount tele neck pickup but that needs a wider rout and shows the screws. Watch the screw length doesn't come out the back of the guitar, measure twice, screws can easily be cut.
    I like the mount ring. Cool!
  9. clsatt
    Mar 14, 2009
    virginia
    For the interior of the ring I would do what rednecktele is suggesting. Give yourself two lines on the back of your material for lining up your centers and then get a good tracing of the top bobbin.
    As for the bevel. Make a template in the shape you want your ring to be. Then you'll have plenty of material for the bearing to ride on.
    Good luck! Can't wait to see it when you finish it.
