BF/SF Mid Control
Discussion in 'Amp Central Station' started by schmee, Jun 4, 2018.
  1. schmee
    schmee Friend of Leo's
    Jun 2, 2003
    There's a 6.8 k resister on the bass pot. That's the mid control right? If I want less mids do I raise that value or lower it?
    I could do the "add mid pot" mod, but dont really think I need to.
  2. slider313
    slider313 Tele-Afflicted Silver Supporter
    Jan 6, 2011
    NC
    You would lower the value, to say 4.7k.
  3. codamedia
    codamedia Friend of Leo's
    Apr 4, 2009
    Western Canada
    Well.... you could lower the resistor value but there is another method that keeps the amp from being modded.
    Raise the "bass & treble" controls... then turn down a little if needed. That scoops the mids even more.
    More often than that players will actually reverse that procedure for more mids. They lower the bass and treble to 2 or 3, then turn up.
    Wally and JD0x0 like this.
  4. schmee
    Jun 2, 2003
    That's an interesting thought. Last night I had the treble on 6 and the bass on 4. 6 on the treble is reaching my threshold for highs though. Close to my usual spot.
    It's a little BF Deluxe non reverb.... it's just the most beautiful tone for leads there is. Every time I pull it out, at some point in the night my jaw is just on the floor! Amazingly it will take any of the 3 OD's I have fine, or be fine plug and play if I can play loud enough.
    But there are times when I would like to scoop a bit more when I'm chording or comping... Maybe I could make a foot switch to change values on the fly! Too long leads I suppose! Need a relay.........
  5. clintj
    clintj Friend of Leo's
    Apr 4, 2015
    Idaho
  6. DavidP
    DavidP Friend of Leo's
    Mar 16, 2003
    Vancouver, BC
    I strongly recommend the 'mid pot' -- it fits perfectly in the ext. speaker jack hole on the rear, and is easily reversed!
    Mike Eskimo likes this.
  7. dan40
    dan40 Tele-Afflicted Silver Supporter
    Aug 19, 2015
    Richmond Va
    I like to use a small 3-way switch on that resistor. One position is stock 6.8k, middle position lifts the ground for a big gain boost and the last position usually has a 15k or so for a bit of a bump in the mids.
  8. E5RSY
    E5RSY Poster Extraordinaire
    Mar 5, 2009
    Georgetown, TX
    What are we talking about? Princeton Reverb? Deluxe Reverb?
  9. jonrpick
    jonrpick Friend of Leo's
    Mar 17, 2014
    Marietta, GA
    I agree about an EQ pedal. Simple, no mods involved.
  10. DavidP
    Mar 16, 2003
    Vancouver, BC
    Mid control works well on both...
  11. LudwigvonBirk
    LudwigvonBirk Tele-Holic
    640
    Aug 26, 2017
    Madison
    I have monkeyed around with installing a bigger mid resistor and a smaller resistor, and a pot (rigged to be 6.8k on zero on the dial). I have also done a bunch of monkeying around with eq and preamp settings of the signal before it hits the amp at all.
    Amps that I have tried variants of this on are BJrs, PRs, a DR, and a 5e3. With single coil and hb guitars including jazz-riggs with monster flatwounds.
    Of course to each his own, go wild. In no case in my world have I found the need for a bigger mid-scoop than what a 6.8k gives (* a smaller value would dump more mids out, I believe, please chime in if you disagree). In the pot scenario, if/when I need it cranking the mid pot up gives me back a surprisingly nice bunch of volume, useful at times..
    .yet the dialed-out value sounds best to me most of the time
    That said though, I have been able to get some cool fat jazz tones with pressence mods (primarily with a pot) but also with an eq before it hits that amp.
    My current rig which is quite nice (but I'm still chasing my dream tone) is:
    Ibanez A73 stock
    Tomastik flatwounds, 12s
    Baggs Para EQ
    Hoffman-circuit PR with pine cab, Allen T020 OT, no carbon comps
    Weber 12F50 (new one, might be a slightly off name)
    Tubes from GC and wherever (I have a collection of the mofos from doing this and that, but afaict no NOS or truly premium stuff).
    Wally likes this.
  12. DavidP
    Mar 16, 2003
    Vancouver, BC
    Hmm, the 'big gain boost' sounds intriguing!! ...now if I made that mid pot a 'no-load' that should also lift the ground -- I think its worth opening up a pot and cutting that carbon trace to see what happens!
  13. radiocaster
    radiocaster Friend of Leo's
    Aug 18, 2015
    europe
    You could also put in a trim pot.
  14. schmee
    Jun 2, 2003
    I have one, I don't find it the same as the amp controls though. But it can help. I use mine mostly for balancing the room/venue differences. To my ears, there's a difference in WHERE the tone adjustment is in the circuit. ie: adjusting your guitar tone result is different than adjusting your amp tone.
    Done it many times, but usually find I leave it in one spot anyway
    This is my BF Deluxe non rev but it can be any amp really. But for some reason, although I totally love the amp, it seems more middy than my BFDR or other SF/BF amps. I need to get it opened up and see what caps etc are actually in it, maybe something oddball in there that I wasnt aware of! To me it sounds a bit more like a Brown Deluxe in the mids. Haven't had it open for a couple years I think.
  15. schmee
    Jun 2, 2003
    So... the bottom line is LOWER resistor value = less mids... right?
  16. LudwigvonBirk
    640
    Aug 26, 2017
    Madison
    Right!
  17. Mike Eskimo
    Mike Eskimo Doctor of Teleocity Ad Free Member
    Nov 9, 2008
    Detroit
    On the mid pot that was in my NR Princeton, default/stock setting was 4 so, below that - even more scooped.
  18. schmee
    Jun 2, 2003
    I think I will just move a bit down and give it a try. Dont need a lot.
  19. corliss1
    Sep 13, 2008
    Lansing, MI
    lower value resistor allows more of the mids an easier path to ground = less mids.
    If anything, I add mids to my Fenders :D
    jonrpick likes this.
  20. schmee
    Jun 2, 2003
    Just thought I'd update for those interested:
    I put in a switch that allows the stock mid resistor 6.8k and a 5.1k I had. In the music room, it's pretty hard to tell much difference frankly. But I'm leaving it in and will do a gig this weekend and see what it sounds like live in the mix.
    King Fan and Mr Ridesglide like this.
