better sound bypassing the d-g stringtree
Discussion in 'Squier Tele Forum' started by rodeoclown, Sep 30, 2018.
  1. rodeoclown
    rodeoclown TDPRI Member
    22
    Sep 30, 2018
    My Indonesian squire is perfect in every way except the d-g string tree w off by about 1/8", both strings appeared as having a boomerang shape on the head stock. After a couple years of simply ignoring the issue, I restrung bypassing it and now have a much better sounding guitar. I will now remove the string tree and replace without the upper portion that guides the strings leaving only the screw and collar.
  2. bgmacaw
    bgmacaw Tele-Afflicted
    Feb 11, 2006
    Near Athens GA USA
    By not using the tree, it changes the tension across the nut. The effect of this depends a lot on the string gauge you use. If you use 9's or 8's you might find the tension too weak and you get a buzzy sitar like sound. That, I suspect, is the reason they have this on the Squier since beginners typically prefer lighter gauge strings. Heavier strings usually get better tension at the nut.
  3. rodeoclown
    22
    Sep 30, 2018
    glad you mentioned the lighter strings,
    I switched to the Earnie ball 9's two string changes ago and playing has become much improved and easier on my hands, I'm pushing 60.
    the off center string tree certainly created unneeded tension on the nut itself,
    otherwise this guitar is perfect, not sure how they can offer a guitar like this for under $300,
