Best way to measure Pickup height.
Discussion in 'Tele-Technical' started by Digiplay, May 18, 2019.
  1. Digiplay
    Digiplay TDPRI Member
    Birmingham, Alabama
    I'm going to adjust the pu's on my Tele, and I'm wondering the best tool (not my ears :) ) to measure the distances with.
    Equally important is where to purchase said tool :)
  2. RodeoTex
    Nueces Strip
    Hate to say but it really is your ears.
    Play the neck pickup for a bit, then the bridge, then both. Tweek as necessary.
    If you already have definite ideas about what the heights should be then just get any 6" machinest's scale. Starrett is the benchmark.
  3. bftfender
    bftfender Friend of Leo's
    York PA
    Spot on !! Ear's & the fine line of balance between the 2(3) for the blend tend. An investment in time that can make a guitar go to the next level. very neglected aspect of guitar set up.
    aerhed, TokyoPortrait and Teleterr like this.
  4. tessting1two
    tessting1two Tele-Meister
    Southern California
    While your ears are the final judge, measurements are the starting point and the ending point. Get a 6" machinist ruler.
    1. Set the pickup heights to typical recommended specifications for the type of pickups you have (these measurements are typically taken at the bass and treble ends of the pickups by measuring the gap between the pole piece and the bottom of the string while the last fret is being pressed down)
    2. Play through an amp at realistic gig volume and judge the results
    3. Make small, incremental adjustments and test again
    4. When you reach the point that your ears are happy measure the end results and write them down somewhere. You may change other aspects of the guitar's setup down the road that affect pickup height so having a reliable measurement will save you from having to start from scratch.
    bblumentritt and LutherBurger like this.
  5. Digiplay
    Birmingham, Alabama
    How about the angle adjustment?
  6. Vanzant
    Vanzant Tele-Afflicted
    United States
    Stew Mac String Action Gauge is what I use. Works with many applications for guitar.
  7. Vanzant
    United States
    Geo likes this.
  8. Digiplay
    Birmingham, Alabama
    That's cool!!!!
    What about the proper angle for the pu?
  9. tessting1two
    Southern California
    The angle is determined by the two measurements. For example, the bass side may be 2 or 3 64ths lower than the treble side. The manufacturer spec will have measurements for both sides and that will get you in the ballpark. Then you fine tune with your ears and some patience.
    I use a tool similar to the Stewmac tool made by Fret Guru because the contrast of the white markings on black is easier for me to see.
  10. Matthias
    Matthias Tele-Afflicted
    I tend to use the ruler end of my set square when I’m setting to factory specs (carefully as it’s metal).
  11. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    I don't think it matters much, but I lay the ruler's edge on the pickup's bobbin between the D and G strings and adjust until it's parallel to the unfretted strings -- just because I'm a fan of parallel lines and right angles.
  12. Digiplay
    Birmingham, Alabama
    Anal...........................................just like me :) :) :) :) :) :)
    LutherBurger likes this.
  13. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    Ears.
  14. bullfrogblues
    bullfrogblues Friend of Leo's
    Southeast Florida
    Easy place to start is the nickel settings.
    2 nickel thickness for the bass side, 1 nickel for the treble side.
    measure those with a good ruler and use those as a starting point, or use the nickels themselves. then tweak by ear.
  15. Lonn
    Lonn Friend of Leo's
    Indiana
    I have never heard of anyone actually measuring pickup height. That makes no sense to me, you're making an aural decision, not a visual one.
  16. fender4life
    fender4life Friend of Leo's
    los angeles
    Using anything but your rears makes no sense IMO except for one purpose. that being getting the height back to where your ears decided it was best is anything was changed. For example, take the pickups out to try others. With the new pickups you'd want to use your ears, but say you decide you preferred the old ones and u put them back in. if you had measured the height where you liked them and recorded that before you removed them them you can easily put them back to where they sounded good without having to go thru the same ear tweaking you already did. Thats the only thing measuring is good for. But to determine the pickup's best height by setting it to a given height suggested to you by some article or the manufacturer is ridiculous. Ever heard even one person gush about how good the stock patches are on ANY modeler? Plain and simple, there's no pickup height thats perfect for everyone because they sound different depending on the height and the difference between one height and the next is not good or bad, its 100% subjective. You set them where they are best to YOU, and the only tool that is capable of that is on the sides of your head.
  17. ricknbaker
    ricknbaker Tele-Holic
    Watford, UK
    Just set them so they're not too close to the strings and not too far away.
    bb_matt likes this.
  18. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Start with the pickups flush to the pickguard or pickup rings and raise until they sound bad then back them off until they sound better.
    If you need to measure, two US nickels stacked up is the usual starting point.
    As Joe says about setting pickup height "... they don't have the great tone like I do."
    theprofessor likes this.
  19. bb_matt
    bb_matt Tele-Meister
    Chipping Norton, Oxfordshire, United Kingdom
    Heck, I love this answer, made me laugh :)
  20. bb_matt
    Take an A4 size piece of paper and fold it in half and in half again 8 times to try to get that perfect paper height for reference.
    When you've failed to do that, toss the paper in the trash.
    Plug your guitar into the amp, dick about with the height whilst smashing out some riffs or chords.
    Pretend to yourself, at some point, that you've reached pickup height nirvana. You are done.
    CCK1, Ricky D. and Tezuka27 like this.
