Best way to fix neck angle?
Discussion in 'Tele Home Depot' started by ChickenTele, May 17, 2018 at 12:26 PM.
  1. ChickenTele
    ChickenTele TDPRI Member
    4
    Thursday
    I recently built my first kit guitar (cheap tele style), and I seem to have made a mistake when attaching the neck. It sits slightly crooked in the pocket. If I remove the screws, I can easily put it into the right position where it sits square with the body. I'm wondering if any of the more experienced builders here can advise on the best way to correct this. These are my ideas so far:
    1. Enlarge the holes in the body to get enough play to reposition the neck. They probably should be enlarged anyway because they grip the thread on the screws.
    2. Use a shim
    3. Fill holes and re-drill.
    I'm wondering if one of these approaches is better than the others? The neck is just slightly crooked enough to cause the strings to be a bit off from the bridge (maybe 3mm). As result, the low E lines up really close to the edge the neck while the high E has more space than it should. I don't have access to advanced tools, so I'd like to be able to fix this with my drill and hand tools. Any advice will be appreciated.
  2. guitarbuilder
    Mar 30, 2003
    If you loosen the screws a bit, can you shove it into position and retighten?
    mistermikev likes this.
  3. Hobs
    Hobs TDPRI Member
    63
    Sep 16, 2011
    Nashville, TN
    Absolutely enlarge the holes. Having the body holes engaging the threads makes it hard to get the neck to seat properly, causing all sorts of problems.
    That will probably let you get the neck aligned. If not, look and measure carefully to see what will need changing.
  4. ChickenTele
    4
    Thursday
    I've tried to finagle it but it seems to be locked in at that angle. I might try enlarging the body holes when I get home from work tonight and see where that gets me. I'll do a follow up post either way.
  5. jackal
    jackal Tele-Afflicted Silver Supporter
    Jun 14, 2010
    mojave desert
    Enlarging the body holes would be my first step.
  6. mistermikev
    mistermikev Tele-Meister
    107
    Feb 20, 2018
    phoenix
    look at it this way: enlarging the holes would probably be the first step in filling them with dowels anyway... just a thought. best wishes and fingers crossed for you.
  7. Ricky D.
    Ricky D. Poster Extraordinaire
    Oct 22, 2006
    Garner, North Carolina
    Holes in the body should be 11/64" for standard neck screws. That should give you enough clearance to line up the strings.
    The screws must not bind in the body or they will prevent the neck from pulling in solidly against the floor of the pocket.
  8. guitarbuilder
    Mar 30, 2003
    Metric screws tend to be skinnier than standard Imperial sized screws. I'd measure the diameter of the screw threads and drill that size hole.
  9. jimgchord
    jimgchord Tele-Meister
    226
    Apr 3, 2018
    victor,ny
  10. ChickenTele
    4
    Thursday
    I enlarged the holes until I could slip the screws in without threading, and sure enough, I was able to reposition the neck enough to get the angle right. It’s not perfect, but it’s much better than it was.
    Thanks to everyone for the great advice!
  11. ChickenTele
    4
    Thursday
    As Ricky and Hobs predicted, the neck seems to be pulled tighter to boot.
  12. 2blue2
    2blue2 Tele-Afflicted
    Jul 20, 2013
    Island of Oahu
    Good stuff.
  13. Vizcaster
    Vizcaster Friend of Leo's
    Sep 15, 2007
    Glen Head, NY
    When you say it's not perfect, how are you assessing the neck alignment? Try to get the high and low E strings to run a consistent distance from the edges of the frets. Don't worry about the pickup polepieces or the pickguard or the lip on the body - the way to align the neck depends on the strings.
    A shim would not be a solution to a neck alignment problem - that's only for issues with the saddle height.
