Join TDPRI Today
Best Tolex glue
Discussion in 'Shock Brother's DIY Amps' started by Powdog, Sep 28, 2009.
  1. Powdog
    Powdog TDPRI Member
    28
    Jul 31, 2009
    Cool, CA
    Hi all. I'm seeking opinions about success with different Tolex glues. I began with Weldwood contact cement in a can (not the water based stuff), which worked well, but had to be brushed on and caused some stretching. I then started using 3M Super 77, which sprays on. Much faster and less stretching, but after about 6 months starts to let go and gets gummy. I'm thinking about getting a hot glue pot and using hide glue, but don't know much about it. Any tried and tested long term success stories? I sure appreciate any input.
  2. Mightyaxeman
    Mightyaxeman Tele-Afflicted
    May 12, 2007
    Pennsylvania
    I've used the 3M Super 77 with no problems or streching. Are you following the directions?
  3. spankdplank
    spankdplank Tele-Afflicted
    Jan 19, 2007
    Houston, Tx.
    Ive tolexed a bunch of cabinets with 3M Super 77 with no problems. Living in a swampy climate (Houston), Ive found that I need to cut the tolex ends a little long so there is more to glue and tuck in the inside walls of the cabinet. Then I put a few staples in the tolex on the inside of the cabinet to keep it from curling up or pulling.
  5. Southpaw Tele
    Southpaw Tele Tele-Afflicted
    Jun 30, 2008
    The Golden State
    +1 on the long ends...I just did my second covering job and used shorter ends...the 3M 77 needs the length.
  6. Powdog
    Powdog TDPRI Member
    28
    Jul 31, 2009
    Cool, CA
    I'm not having the stretching problem. The glue tacks up well and the initial hold is fine. After about 6 months, the glue seems to get gummy and let loose. I live in a pretty dry climate, the California Sierra Footholls, and I'm not sure that's the problem. I've done alot of cabinets with the Super 77, and even though I'm not the sharpest pencil in the box, I follow directions pretty well, but unless I use alot of hidden staples, sooner or later that Tolex is comming up.
  7. trip20
    trip20 TDPRI Member
    59
    Aug 3, 2009
    Baltimore, MD
    Anyone ever tried the Mojo TruGlu?
  8. shadowfan
    shadowfan Tele-Meister
    203
    Dec 13, 2008
    Atlanta, GA US
    I've used solvent based contact cement (Weldwood or DAP); it works well but can be messy (one throwaway brush per side). I would think 3M 77 adhesive would also work but it's expensive and you probaby need two coats on both the wood and on the Tolex because of porosity.
    Does carpenter glue (white or yellow) work?
    edit: I read the posts below (under "Similar Threads"), lots of ideas there. I like the vinyl adhesive (automotive) idea.
    How about a woodie with a tweed top for surfers?:D
