Best to fill these?
Discussion in 'Tele Home Depot' started by Mdmoore255, Jan 12, 2019 at 1:20 PM.
  1. Mdmoore255
    Mdmoore255 TDPRI Member
    17
    Saturday
    Georgia
    6AFBF291-E8D9-4973-AA3D-F32FE5153025.jpeg hey folks,
    I’m putting a Bigsby in this tele and some of the old bridge plate holes are interfering with the Bigsby plate.
    Would you recommend filling with wood/glue or some form of epoxy so I can redrill them in the correct position.
    Thanks in advance.
    -Mike
  2. Itchyfeet1000
    Itchyfeet1000 Tele-Meister
    247
    May 9, 2018
    Plymouth, England
    I used wooden skewers and superglue when I did mine. It worked perfectly.
  3. guitarbuilder
    Mar 30, 2003
    I'd use unwaxed flat toothpick ends and some yellow glue. Pack them in and that'll give you some edge grain for the screw to bite into. Dowels and similar products are all end grain which has little holding power for screws. You need to let the glue dry probably overnight to get that to work for you though.
  4. Dismalhead
    Feb 16, 2014
    Sacramento, California
    Toothpicks and wood glue. Recently bought a cheap dremel kit at Harbour Freight and it works great for leveling and not screwing up the surrounding finish.
  5. Ronkirn
    May 1, 2003
    Jacksonville, FL
    Yes, I always fill old holes... if they are in close proximity to a new hole that must be drilled, the presence of the old hole can make the drill bit want to "wander" into it, creating a nice new crooked hole.
    fill 'em, fill 'em all..
    rk
    Newbcaster and Maricopa like this.
  6. 2blue2
    2blue2 Friend of Leo's Silver Supporter
    Jul 20, 2013
    Island of Oahu
    And welcome aboard.
  7. Mdmoore255
    17
    Saturday
    Georgia
    Thanks for the tips, I’ll use wood glue and toothpicks.
    Appreciate the welcome.
  8. Mdmoore255
    17
    Saturday
    Georgia
    I went the super glue route thinking it would dry super fast. It’s been in about half an hour and still wet at the top. I’m so impatient
  9. Ronkirn
    May 1, 2003
    Jacksonville, FL
    Yep, instant glue is many things, but instant isn't on the list... :p
    r
  10. Mdmoore255
    17
    Saturday
    Georgia
  11. schmee
    schmee Friend of Leo's
    Jun 2, 2003
    I use wood dowel/toothpick and ISO glue (5 second glue) but sometimes epoxy, if the fit isn't tight as it fills well.
