Join TDPRI Today
Best Modification you have ever done, to any guitar?
Discussion in 'Other Guitars, other instruments' started by Dave1234, Dec 2, 2012.
  1. Dave1234
    Dave1234 Tele-Afflicted
    Mar 4, 2012
    Leicestershire
    I did something I had been meaning to do for a long time; I changed the stock tuners in my SG special to Grovers. Best thing I ever did.....more sustain, stays in tune, even when getting a bit OTT with bends. Simple, but oh so effective.
    Anyone else made a simple mod that just worked better than you ever thought it would?
  2. twangking
    twangking Tele-Afflicted
    May 10, 2010
    Central Connecticut
    Changed the pickups. Brought a whole new life and voice to my telecaster.
  3. Leo1951
    Leo1951 Tele-Meister
    439
    Oct 20, 2012
    Nashville
    Installing a Dimarzio Evolution in one of my Kramer SuperStrats.
  5. charlie chitlin
    charlie chitlin Poster Extraordinaire Ad Free Member
    Spring City, Pa
    Put finger grease on the strings...as often as possible.
  6. GigsbyBoyUK
    GigsbyBoyUK Friend of Leo's
    Apr 30, 2008
    Peterborough, UK
    Neck blend on Strats for neck and bridge in series.
  7. burtonfan
    burtonfan Tele-Afflicted
    Feb 16, 2010
    michigan
    The mods I've done here are just for looks. A way to personalize two of my guitars.
    On the '52 Hot Rod I added a leather pickguard, angled slot control plate with knurled knob, and a pin-up girl neck plate.
    The Jag I posted two months ago. It was a project to commemorate 30 years since my 1st gig in 1982 (at which I played a borrowed Jaguar). It's a Fender Japan Jaguar HH Special I snagged off ebay. I painted the pickguard white, added old school control knobs, a pinstripe, removed the bridge pup cover, and an "82/30" sticker a friend designed for me. I had a local jeweler engrave the logo in the neck plate as well. The final touch was the '12 on the back of the head stock.
    Here are some pix!
  8. burtonfan
    Feb 16, 2010
    michigan
    And The Jag pix.
  9. Telemarkman
    Telemarkman Doctor of Teleocity Ad Free Member
    Norway
    Doing the wiring update on my '52RI, and not least, changing the pickguard on my MIM 60's Classic from a 3-ply mint to a 1-ply white! ;)
  10. jammers5
    jammers5 Tele-Afflicted
    Nov 21, 2009
    Mount Pearl NL
    Changing the bridge on my FSR Black Paisley to a Wilkinson Compensate Brass Barrell one made a big difference to the sound o the guitar.
    J5
  11. Toto'sDad
    Toto'sDad Telefied Ad Free Member
    Jun 21, 2011
    Bakersfield
    I modified a nice mandolin once by transferring ownership to someone who could actually play it. Seemed like a successful mod.
  12. jamieorc
    jamieorc Tele-Meister
    356
    Apr 22, 2011
    Virginia
    Hands down best tele mod was Bill Lawrence / Wilde Microcoils.
  13. el cheapo
    el cheapo Tele-Afflicted
    Jan 13, 2011
    Southcentral Pa
    A good setup!
    The bottom line is, a guitar has to be playable or you won't play it.
    For me, the most important part of that is usually a new bone nut. My fingers are short and fat, so wider string spacing helps a lot. I just replaced the original nuts on my best sounding tele, and my acoustic. Now my best sounding guitars are getting played a lot more!
  14. charlie chitlin
    Spring City, Pa
    Yeah...a good set-up...definitely.
    And either the Fezz/Ted mod or treble bleed are critical for me because I almost never use pedals.
    When I twist the vol knob, it's really important that the tone doesn't change drastically.
  15. wired to go
    wired to go Tele-Meister
    371
    Aug 22, 2010
    Bridgeport,NY
    Straplocks on ALL my guitars.
  16. Tony474
    Tony474 Poster Extraordinaire
    North Bushey, England.
    Most successful mod I've done is dead simple and I've applied it to several guitars - get hold of some Micromesh (hi-tech abrasive material) and flat down the gloss on the neck to a satin finish. Improves playability very considerably. I've also used it experimentally to give a slight roll to the edges of one rosewood board. The result was encouraging but I'm a bit nervous about doing the same to other guitars, because unlike the finish mod it's irreversible.
    A 4-way switch mod in one Tele has worked well for me, though I've left my others stock for now.
  17. Toto'sDad
    Jun 21, 2011
    Bakersfield
    Hmm, actually installing a Cavalier "Lion" pickup by Rob DiStefano really improved my 2011 AS Tele quite a lot. That's an honest to goodness mod not requiring any owner transfer. Plenty of good stuff, none of the bad. If you like twang but don't like ice pick, it's a good choice.
  18. Telemarkman
    Norway
    A good setup is cruxial, but I wouldn't call it a mod though ...
  19. Uncle Joe
    Uncle Joe Friend of Leo's
    Aug 5, 2012
    New Jersey
    Changing the bridge on my MIM Cabronita to an American Standard hardtail.
  20. musicalmartin
    musicalmartin Poster Extraordinaire
    Aug 8, 2007
    Norfolk UK
    Learning to to play it.After a few months I gained a small but significant upgrade ,the chord A .I later modded out the A to a D and even an E .I stopped after that as I didnt want to guild the lily.:D
  21. chippertheripper
    chippertheripper Friend of Leo's
    Dec 26, 2010
    Fhvn ma
    This is the obvious winner, but to play along: rolling the fb edges. The rounder, the better.
