Best Delay Pedal with Modulation (Repeats Only)
Discussion in 'The Stomp Box' started by tedtan, Sep 27, 2017.
  1. tedtan
    tedtan TDPRI Member
    53
    Nov 18, 2015
    Kansas City
    I have several analog delays that I like, but none give me the option of modulation (e.g., chorus, phasing, flanging) on the repeats. What's the best analog delay with the option to add modulation to the repeats?
  2. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oct 24, 2012
    Oklahoma, USA
    I love the modulation on the MXR Carbon Copy. (Around the 1:26 mark it indicates that it's only on the delayed signal.)
  3. ICTRock
    ICTRock Tele-Afflicted
    Jul 31, 2014
    ICT
    malekko has external modulation controls ... so do some of the way huge delays ... I'm a fan of the modulation of the deluxe memory man
  4. Strato50
    Strato50 Tele-Holic
    905
    Mar 30, 2017
    Port Arthur TX
    TC Flashback mini...with the toneprints you can do anything your heart desires.
    Striker6 likes this.
  5. tedtan
    tedtan TDPRI Member
    53
    Nov 18, 2015
    Kansas City
    Cool, I'll check these out. Any others I should put on my list?
  6. BorderRadio
    Apr 2, 2014
    Phoenix, AZ
    Another vote on the Malekko, they come in a few varieties as well.
  7. Golem
    Golem Tele-Meister Silver Supporter
    Montavillian. It's unique. May not be to everyone's tastes.
  8. waparker4
    Nov 9, 2011
    Philadelphia, PA
    I had one. It's not analog, and it doesn't have modulation. Sounds good though.
  9. Strato50
    Strato50 Tele-Holic
    905
    Mar 30, 2017
    Port Arthur TX
    The Malekko sounded horrible to me I bought one and played it once...no offense the TC is 10 times the pedal...I didn't dig their trem pedal either...JMO..Sorry Border you know I love ya..lol.
  10. MitchJ89
    MitchJ89 TDPRI Member
    81
    Jul 13, 2017
    Kalispell, MT.
    I was really into modulated delays a couple years ago and did a fair amount of hunting.
    The best thick and lush modulation came from the older big box deluxe memory mans (there was some variation between the 3 or 4 units I owned, and they're pretty pricey now days.
    My second favorite was Diamonds Memory Lane Jr. EXCELLENT modulation in my opinion. While in most lower priced delay units the depth and rate are usually pre-set, the MLjr is just about right; most manufacturers just can't get that right.
    Chip.Lindsey likes this.
  11. nic'o'caster
    nic'o'caster Tele-Afflicted Silver Supporter
    Apr 10, 2004
    Middle Earth
    I've got a DMM and a DMMTT1100 and the modulation of the DMM is superior to any other delay I've heard. Not that the DMMTT is bad but the settings go way too far into special fx... I like subtle modulation in my delay. One pedal that can come close to the DMM mod is the Ibanez Echo Shifter. Very underrated pedal btw...
    I also like the tape modulation you get with the Strymon El Capistan. It's not a modulation per se but the added movement and imperfections are very musical. Not the best alone but perfect in a band mix.
    Chip.Lindsey and jondanger like this.
  12. Golem
    "The PT2399 has a lot of unique features. It’s a digital delay that mimics analog delays quite well, giving a warm bassy filter to the overall delay repeats. This is no accident, as the PT2399 has a lot of high-frequency digital noise that has a way of getting into the audio path and is tamed through filtering courtesy of the on-chip op amps.
    If you use the PT2399 Echo Application’s Pin 6 resistor-potentiometer configuration"
    Looks like you are right. Sounds as good as my favorite analog pedals though hence why I thought it was analog. Well, you learn something new everyday.
  13. tedtan
    tedtan TDPRI Member
    53
    Nov 18, 2015
    Kansas City
    Thanks for the input. You guys were a big help when I asked about Vox in a Box pedals a while back (I ended up with a Wampler Ace Thirty), so now I'm off to check out your delay recommendations.
    One last question: is there a significant difference between the "vintage" Deluxe Memory Man and the current DMM?
  14. nic'o'caster
    Apr 10, 2004
    Middle Earth
    Take a listen to this comparaison :
  15. MitchJ89
    81
    Jul 13, 2017
    Kalispell, MT.
    So, it's a bit of a rabbit hole.
    With the older big box memory mans you have those with 2 MN3005 chips,
    And those with 4 MN3008 chips (which are apparently also installed in the current versions if my memory serves me right).
    Some swear by the older ones with those MN3005, but I've had a few with the newer chips that sounded great.
    It's really in just finding one that sounds good to you. Of course there are some negatives with these units, such as larger voltage requirements, some units are noisey
  16. tedtan
    tedtan TDPRI Member
    53
    Nov 18, 2015
    Kansas City
    After watching that, I do prefer the older DMM - it's darker and dirtier, which I prefer. Thanks for posting that.
  17. jdkr
    jdkr TDPRI Member
    22
    Jun 16, 2017
    Vancouver
    I just bought a used Alter Ego X4 and really like what it can do.
  18. jondanger
    jondanger Friend of Leo's
    Jan 27, 2011
    Charm City, MD
    I've had a couple and have a friend that has one too. I think that you just have to find a good one. Haven't heard two that sounded exactly the same, and I think it must have to do with the calibration. Right now I have one of the transitional ones with four IC slots, but just two of them have MN3005s in them. Analogman can mod those to double the delay time but I haven't sprung for the mod yet.
    Nothing sounds quite like a big box DMM, IMO.
  19. Mikecito
    Mikecito TDPRI Member
    85
    Dec 11, 2007
    Bellingham WA
    Check out the Way Huge Supa Puss. Lush and very tweekable modulation.
  20. Strato50
    Strato50 Tele-Holic
    905
    Mar 30, 2017
    Port Arthur TX
    A fellow member has a TC Flashback for sale ...new in the box...I would grab it....change to whatever you want on the fly with your phone...I love it.
