Join TDPRI Today
Best adhesive for tolexing an amp?
Discussion in 'Shock Brother's DIY Amps' started by Lloyd89, Jan 23, 2013.
  1. Lloyd89
    Lloyd89 TDPRI Member
    53
    Dec 27, 2009
    Georgia
    Any suggesting out there on the best way to go about tolexing a cabinet as far as adhesives are concerned?
  2. TeleTim911
    TeleTim911 Friend of Leo's
    Sep 28, 2009
    Calera, Alabama
    I've always used contact cement. Brush or roll it on. Difficult to work with though if you are new to doing this and contact cement. I have done quite a few cabs this way.
  3. motor_city_tele
    motor_city_tele Tele-Afflicted
    Apr 25, 2005
    motor city
    "Best" is a subjective term with many variables to consider.
    What's "best" for some may not be "best for others.
    "Best" adhesion might not be very forgiving.
    "Best" can be what's easiest to work with and still produce satisfactory results.
    "Best" can be what is the least expensive to purchase.
    "Best" might be what is even practical given the tools available.
    "Best" for me is a little bit of each.
    I use a Latex Contact Cement. (tweed fabric)
    I have a system that I use that I like but may not be practical for others.
  5. Dave1234
    Dave1234 Tele-Afflicted
    Mar 4, 2012
    Leicestershire
    Your thread showing the method you utilised for covering your collection of beauties is possibly the most informative on the subject I have ever read!
  6. Fatknuckle
    Fatknuckle Tele-Holic
    981
    Jun 28, 2012
    Gainesville FL
    I would agree with the notion that contact cement (DAP weldwood, for instance) can be really good, or really bad. It's a mess if you mess up and have to redo it. I have had good luck with it with in the last several projects, but there was a dissapointment and redo that was a challenge.
  7. Commodore 64
    Commodore 64 Friend of Leo's
    Mar 1, 2010
    Kent, OH
    That gallon on the right is the TOlex GLue from AES. It's water based and awesome. I've tried hide glue, high voc contact cement, 3M spray 77. Nothing compares to this stuff. I will never use anything else.
  8. telex76
    telex76 Doctor of Teleocity
    Jun 24, 2006
    Fort Worth,Tx.
    +1, I'd never think of using anything else.
  9. mefgames
    mefgames Tele-Afflicted
    Oct 31, 2010
    North Bay, Ca
    I used vinyl adhesive from Home Depot. I researched it online, and that was the choice of many. It gives you a bit of time to move the tolex around then sets up really well. I think it was a Roberts product.
    I used it for these
  10. Me 3, I used this for the first couple then tried a couple other choices & now I'm back to the stuff from AES, just bought another quart as a matter of fact.
  11. JCSouthpawtele
    JCSouthpawtele Friend of Leo's
    Apr 28, 2009
    Middlebury,Indiana
    I use the tolex glue from the supplier of the tolex. 3M super 77 it great for getting tight corners,but it is an immediate stick, there is no ease of adjustment or movement.
    Some recent projects.
  12. JCSouthpawtele
    Apr 28, 2009
    Middlebury,Indiana
    Be sure to clean the cabinet well before glue. I sand the wood and clean it with isopropal alcohol and a rag. Spray paint it flat black with a decent paint. Take your time and use a fresh sharp razor blade every chance you get. A metal straight edge for the seems. Act as if you are doing wallpaper. Overlap the seem and cut through both layers. Pull back and remove the cuts,laying back a perfect butt seem.
  13. BobbyZ
    BobbyZ Poster Extraordinaire
    Jan 12, 2011
    Snellman MN
    I think it was a Permatex spray I used on a BFTR I picked it up in a craft store in town. Read the label and it looked like it would work.
    When I redo it next summer I won't be useing it. While it was nice because I could reposition the tolex as I worked. Only problem is I can still reposition the tolex!
  14. jeffG
    jeffG TDPRI Member
    14
    Jun 24, 2003
    Lenexa, KS
    The water based Tolex glue is good stuff, except for one area: where you have tolex on tolex, as in a BF Fender on the top (or bottom) lap seams with the sides. Those areas will start to 'lift and separate' (to borrow Playtex's phrase) over time...
  15. telex76
    Jun 24, 2006
    Fort Worth,Tx.
    I've done 2 blackface style cabs using water based Tolex glue, one was over 3 years ago. No lifting where it overlaps yet.
    My brother built a cab for me about 5 years ago and used the 3M spray, it is coming all unglued.
  16. Savman
    Savman TDPRI Member
    68
    Dec 22, 2012
    Nottingham, UK
    I used water based solvent free vinyl adhesive from B & Q, the UK hardware chain. I followed the advice here http://jam4jmessageboard.websitetoolbox.com/post/retolexing-project-2378719 with this result [​IMG][​IMG]
    I'll use the same glue next time, because it gives 10 minutes or so to move the tolex around before the adhesive grabs.
    It's too early to tell, but it seems to be lasting well.
  17. Lloyd89
    53
    Dec 27, 2009
    Georgia
    Thanks everyone for the suggestions!
  18. JohnnyCrash
    JohnnyCrash Doctor of Teleocity
    Mar 12, 2005
    Fullerton, CA
    The generic stuff from AES is THE BEST.
    I just finished a cab last week (thread and pics soon). A thin coat and within a few seconds it's already tacky. You can still adjust the tolex, but it's still sticky enough to get things in place. A few seconds later and you can cut the edges/corners without worrying about the tolex sliding around.
    PS
    Super 77 SUCKS. Never again.
  19. blues bondsman
    blues bondsman Tele-Holic
    527
    Feb 12, 2012
    Indiana
    I have this 69 Bassman Drip edge head that someone goobered up
    Where can I get a pattern ???
  20. Commodore 64
    Mar 1, 2010
    Kent, OH
    What do you need a pattern for? Just cut a piece and stick it on, fold the excess inside the cab.
  21. blues bondsman
    527
    Feb 12, 2012
    Indiana
    Well.......
    Kinda thought I would refinish the entire head so that it matches
