beginning a beautiful friendship
Discussion in 'Tele Home Depot' started by Bellybuster, Oct 1, 2012.
  1. Bellybuster
    Bellybuster Tele-Meister
    447
    Aug 29, 2012
    Wasaga Beach, Ontario
    I have a crap tele knockoff that I can't intonate, another thread, and a largish sum of 4/4 cherry boards. I was thinking.
    1 crap Tele that has a good neck and sounds nice plus 1 largish stash of cherry boards......
    front
    back
    each of these is 3/4" and need to be joined. I may go with the 1 1/2" as final thickness or I may add in a 1/4" between them. Need to measure the switch on my crap guitar.
    Plan is to go traditional as I already have a tort pick guard to use. Only part I need to buy is a control plate but may make that out of a scrap of walnut I have.
  2. Bellybuster
    447
    Aug 29, 2012
    finish will be tung oil, I want the cherry to age the way cherry does. Or wait, maybe ebonised would be nice?? I shall experiment with the scraps
  3. Bellybuster
    447
    Aug 29, 2012
    I need to flat sand both halves before gluing together. Cherry is quite hard, I see a few beers going down range tomorrow while sanding.
  4. crazydave911
    Feb 23, 2010
    East Tennessee
    Why not replace said "crap"? :D (STD wiring kit)
    LINK
  5. Bellybuster
    447
    Aug 29, 2012
    that's an option, I really don't have a problem with the electronics though. I may have a problem mounting the switch if I stay 1.5" thick tho
  6. frankentele
    frankentele Tele-Meister
    143
    May 8, 2006
    Viva Osh Vegas
    Nice looking guitar idea you have there! The color is really cool.
    You're right about the switch and body thickness issue, I have one of those switches here and I think it's almost 1 7/16" tall. You could try a switch for a Les Paul instead and see if that works.
  7. OpenG Capo4
    OpenG Capo4 Friend of Leo's
    Aug 4, 2010
    Athens, GA
    Cherry is good stuff.
    The finish on this one is Watco "Cherry" Danish Oil (I guess they squeeze it out of Cherry Danishes) as a stain, with Tru-Oil sprayed on as a clear coat. The Danish Oil has a little pigment in it that ads to what is already in the wood, rather than making it look dyed.
    Cherry is one of my favorite woods to work with. Its so closed grained and smooth.
    I've done a few 1-1/2" thickness guitars. Use this style switch and you should be alright. You can get them from "Bezdez" on E-bay for cheap:
    If you're mounting it in a traditional control plate that sits on top of the cavity, you're good. I've even done a rear routed cavity and mounted it thru the top wood, and still had room. This guitar is 1.5" thick
  8. Bellybuster
    447
    Aug 29, 2012
    wow, thanks, I believe I shall go with the 1.5" then. as far as a control plate I think I'll do one out of cherry too just to match up with the pick guard, although I do like the no PG idea too to show off the cherry.
  9. Bellybuster
    447
    Aug 29, 2012
    switch ordered, and he's Cdn too!!
    thanks again
  10. OpenG Capo4
    Aug 4, 2010
    Athens, GA
    I think most TDPRI builders in the US get their parts from Bezdez too. Even with the shipping from Canada, his prices are better than the US vendors that carry the same parts. :eek:
  11. bullfrogblues
    bullfrogblues Friend of Leo's
    Jun 5, 2011
    Southeast Florida
    Yes, cherry is a great wood for a tele! This one is 1 1/2" thick, no problem with the electronics. Nitro top coat.
  12. Bellybuster
    447
    Aug 29, 2012
    very nice, have you found the cherry ages at all thru the nitro?
  13. bullfrogblues
    Jun 5, 2011
    Southeast Florida
    Yes it will. This one doesn't get much sunlight yet, but I made a vanity at the same time, and it is considerably darker due to the window in the bathroom. The tele will get there, I just need to reposition it near a window.
  14. Bellybuster
    447
    Aug 29, 2012
    got a bit of work done on the body this morning, the new Rigid ROSS is an amazing tool. I'm not even gonna bother routing with the template, the sander can easily take the body to the lines with only hand sanding to finish.
    The grain in the cherry is surprising considering I just grabbed a couple boards from the pile. The dark stripe shows more even when wetted with naphtha, this was pretty much dry.
    I staggered the seams from the back half to the front half by about an inch to add a bit of strength.
  15. Bellybuster
    447
    Aug 29, 2012
    why oh why have I lived so long without one of these Rigid sanders?
    just had to toss the PG on to see.
  16. Bellybuster
    447
    Aug 29, 2012
    a while ago I aquired a bundle of 12X12 walnut veneer pieces, probably 100 at least. I've had them for years and think they will make a great control panel if I can get them glued up nicely. They are in the clamps now drying. We will see.
    I may have to stiffen it with epoxy but I'll find out once the glue dries.
  17. Bellybuster
    447
    Aug 29, 2012
    OK, changed my mind. I don't want to use the pick guard, it would be a shame to cover up the cherry.
    To do a rear route how much wood needs to be left on the top for switch and pot mounting?
    I may still do a faux tele control panel with the walnut but it would be inlay'd into the front. Might be beyond my skills so will have to practice on some scrap first.
  18. David_Frey
    David_Frey TDPRI Member
    10
    Aug 5, 2012
    Orlando, FL. USA
    Yes, I agree. Forego the pick guard and show off that beautiful grain.
    @OpenG - that's a great looking guitar.
  19. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    I love working with cherry
  20. Bellybuster
    447
    Aug 29, 2012
    options time, threw together a control plate of walnut, what do you think? Go with it or just plain rear rout mounting? I have no intention of doing a front rout as I don't think the walnut plate would be durable enough to hold the pots and switch. It would be surface mounted bbut rear routed cavity.
    Opinions appreciated.
