Join TDPRI Today
Bass through the PA?
Discussion in 'The BASS Place' started by atinder, Aug 8, 2008.
  1. atinder
    atinder Tele-Meister
    128
    Jul 14, 2006
    Iowa
    I posted this over at Talkbass, but I thought some of y'all might have good info too. See below.
    Sorry for the noob question, but I wasn't having much luck searching. I play in a trio, and we just got a fairly inexpensive PA - haven't had a chance to try it out at practice yet. We got two different opinions from two different employees of the shop: one said don't run the bass through the PA (just use the amp), and one said it would be fine. What's generally considered the "correct" way to go? Here's the basic info:
    Band: guitar, bass, drums and two vocal mics. Music is rock, but not hard rock (alt/country, Stonesy bar rock).
    PA: Behringer powered mixer (800 watts mono/ 2x 350), Peavey 12 inch speakers (rated at 400 watts). Not planning to mic drums, and our goal is small bars and perhaps parties.
    Help? Thanks, and let me know if you need more info.
  2. psychetelec
    psychetelec Tele-Holic
    514
    Oct 24, 2007
    Austin,Texas
    Run the bass thru the PA IF the speakers can handle it.
    Will you have a soundman? If so, with the bass thru the board he will have more control of the sound.
  3. atinder
    128
    Jul 14, 2006
    Iowa
    But how do I know if the speakers can handle it? (I mean, without doing some kind of damage)
  5. bobbybigmac
    bobbybigmac Tele-Meister
    343
    Jan 12, 2008
    West Coast Canada
    I'd like to suggest you only run vocals and acoustic guitars ( if any ) thru the PA.
    You described a scenario that was very similar to my last band .
    2 female lead vocals, both playing acoustics, yours truly on bass and
    vocals, guitar and vocals, and drums. We played mostly country rock in a small pub. I'd guess up to 125 patons. PA was 800 watts, a small 10 channel mixer board, and Ev's combo 1x15 + horn cabs. No monitors.
    We never DI'd the bass or miked the drums. I used my GK 4x10. Guitar player
    had a Twin. Always sounded fine.
  6. cantolina
    cantolina Tele-Meister
    119
    May 15, 2008
    Bemus Point, NY
    In most small-venue situations, it'll do more harm than good....
    The bass is generally something that can be heard without reinforcement in a situation like this...
    In a small room, with a small PA, less is more...
    "Correct", in this case, is more a function of necessity, than one of theory....
    As with ANY instrument in a scenario like this....if you can hear it fine without reinforcement, it doesn't need to be in the PA...
    As mentioned before....vocals FIRST....then, whatever you can't hear....
    If there's no soundman...keep it simple...
    For years, I did a little kick drum (sometimes), and vocals ONLY....
  7. Tim Armstrong
    Tim Armstrong Super Moderator Staff Member
    Mar 5, 2003
    Austin, Texas
    Admin Post
    I used a smaller amp and ran bass through the PA system for five years or so. Our main speakers are fairly heavy-duty Community Sound and Lights 15s, and they handled it just fine.
    Then, back in May, after accidentally sending a MUCH hotter signal to the PA than intended, I slightly damaged one of the speakers, and it buzzed like a cheap TV whenever a low frequency signal hit it. At about the same time, I bought a 400-watt head, and being too busy to replace the damaged speaker (which worked fine as long as I didn't run my bass through it!), I began just using my bass amp like, well, most bass players do!
    That's working for me just fine now.
    So, while I still think a large enough PA system ought to be able to handle bass without problems, I now realize how close to the edge I was operating! I'm on board with the idea that a proper bass amp that's big enough to carry the room is preferable!
    There, I said it! :oops:
    :D
    Cheers, Tim
  8. franchelB
    franchelB Friend of Leo's
    Sep 25, 2005
    Irving, United States of Texas!
    I use my bass amp as MY monitor. I run a "line out" to the P.A. to give the bass drum a fuller sound.
    BUT the only way I'd LOVE to run my bass through the P.A. is IF I had my OWN monitor mix!
    "atinder": If you guys are runnning everything through a P.A., I'd say go ahead, and maybe get someone to do the sound. On the other hand, if the guitar player has a 50/100 watt "stack", and you have a 400 watt bass head, I think you guys don't need to be "mic'ed"...just the vocals and the drums.
  9. broadcaster
    broadcaster Tele-Holic
    887
    Oct 16, 2003
    Joliet, Illinois
    I don't mind going through a PA if I can hear myself clearly in a monitor. I prefer having an amp on stage for a monitor and also sending a signal to the soundman for FOH.
    The PA needs to have sufficient juice and speaker capacity to handle bass along with everything else.
  10. unbridled
    unbridled Tele-Holic
    773
    Feb 28, 2008
    SW Mt.
    I'd say no. The behringer power amps generally don't have enough reserve power to handle bass notes with heavy attack. Once you hit a hard bass note, the power amp will clip and the "reserve power" won't come back fast and the entire mix will sound bad, not just the bass. Also, you gotta remember the speakers are only 12s.
    I'd do without for now and once you get gigging more, buy a crossover and some powered subs.
    What kind of bass amp are you running?
  11. atinder
    128
    Jul 14, 2006
    Iowa
    Bass amp I'm using is the new Acoustic 200 head through a Peavey BW 1x15. Not tons of power, but sounds pretty good. Any thoughts?
    Thanks for all the advice so far - as usual, this forum is very helpful.
  12. unbridled
    773
    Feb 28, 2008
    SW Mt.
    If the drummer is under control, I'd just run the amp for now. I don't think you'd gain much through the PA you have and would run the risk of creating more problems. If you do decide you can't live without running through the board, a compressor is your friend (on the PA, not just your bass compressor)
  13. Strawfields
    Strawfields Tele-Holic
    740
    May 13, 2006
    Stirling, Scotland
  14. Tim Armstrong
    Mar 5, 2003
    Austin, Texas
    Admin Post
    I'd run the amp as loud as needed, up to the point of diminishing returns, and run a line out to the PA system but only actually turn that up if needed, to augment rather than replace your amp...
    Cheers, Tim
  15. 4mal
    4mal Friend of Leo's
    Mar 18, 2003
    The Gorge
    you don't have enough PA to even consider it IMO. If you need more volume from the bass, add speaker area - a second 1 x 15. You're only seeing about 140 watts at 8 ohm's with the Acoustic from what I've been able to read. That's pretty light. 200 at 4 ohms is better - still light for my uses but better. The additionaly speaker area will help a bunch.
    If you stay with a relatively low powered head, then you might consider going to more efficient 15's.
  16. atinder
    128
    Jul 14, 2006
    Iowa
    You know, that brings up a related question: the 1x15 I'm using is a homebuilt job that has a Peavey BW speaker in it. It was built nicely, and works great - but I honestly don't know anything about its power handling (I acquired it as part of a trade). Is there any way to tell if it's 4 or 8 ohm? Or would it most likely be one or the other?
  17. robbysturgis
    robbysturgis Tele-Holic
    772
    Oct 24, 2007
    fairfax
    It's a frequency thing, don't you know.
    But seriously: If you want your bass line to push enough air directly to the ovaries in the audience, a normal PA speaker is not going to do that. First of all the PA speakers are directed at face level, to impact the ears. The bass needs to be at floor level, impacting the family jewels. Plus that is where the bass drum is driving the sound home.
    plus, a sweet range speaker for vocals and acoustic guitar is not made for the deep rumbles.
    If you are going for the deep sound, add a sub woofer to your PA gear, and try it that way, but the extra problem is, you can't shape the sound to match your guitar...face it, not all bass guitars are the same, so you have a volume and tone control on the guitar, but you have an equalizer on the bass amp, to shape your tone there.
    your thoughts?
  18. Tim Armstrong
    Mar 5, 2003
    Austin, Texas
    Admin Post
    First, I'd look and see if there's a label on it that says! :D
    If there isn't, a volt-ohm meter set to read the resistance in ohms will give you an idea. If it reads 3.2 ohms, that would be a 4 ohm speaker (speaker impedance is roughly resistance x 1.25).
    You can find out what the power handling is by Googling Peavey Black Widow 15. I'm sure it's considerably higher than your amp!
    Cheers, Tim
  19. atinder
    128
    Jul 14, 2006
    Iowa
    Yeah, no label. :rolleyes: Now for the embarrassing part: I own a meter, I just don't know how to use it for this kind of reading. What am I actually putting it on to check the impedance? (I guess it's better to ask than pretend I know what I'm talking about.)
    For what it's worth, I'm thinking that the Acoustic 200 head is 200 watts at 4 ohms - so I'm better off making sure that I'm getting the power out of it by running it into a 4 ohm cab, right? Whereas if my BW cab is 8 ohms.........
  20. unbridled
    773
    Feb 28, 2008
    SW Mt.
    Put it on the leads of the speaker. If it is 4 ohms, you're pulling all you can from that head, if it is an 8 ohm speaker, you can add another 8 ohm speaker cab. 2 seperate 8 ohm cabs would be better for you situation IMO.
