Join TDPRI Today
Bass Project
Discussion in 'Tele Home Depot' started by Hodgecraft, Jan 25, 2013.
  1. Hodgecraft
    Hodgecraft TDPRI Member
    69
    Aug 4, 2011
    Bristol, UK
    Howdy, I'm starting a bass project (It's not a scratch build but I'm slowly working towards that)
    I currently play a Westone Thunder III bass: [​IMG]
    But despite being a fantastic studio bass it's really quite heavy for playing live.
    I'm thinking I'll just go for a simple P-bass, maybe wind my own pickups for it, have a go at getting that classic sound.
    I managed to score a decent 2-piece alder body on eBay. The body has been CNC'ed and was reduced due to two small knots on the rear side. This is fine as I'm planning a solid finish anyway.
    [​IMG] [​IMG] [​IMG]
    It also hasn't had the edge rounded over or the belly/arm rest contours done, so this gives me a good opportunity to do a bit of woodwork whilst knowing that all the difficult stuff has already been done (less for me to bugger up!)
    I'm thinking I'll start by chucking a roundover bit in my drill press and have a go at the edges but I'm not quite sure what size bit to go for.
    Any thoughts? Any advice on stupid mistakes to avoid would also be greatly appreciated. :lol:
  2. Hodgecraft
    69
    Aug 4, 2011
    Bristol, UK
    (Apologies for pictures sizes, won't happen again:oops: )
  3. mojoatomic
    mojoatomic Tele-Holic
    687
    Dec 28, 2011
    Horn Lake, MS
    I'll bet a belly contour would remove the upper knot completely, and make it lighter and more comfortable on the stage. I'd add a arm contour on the front as well, and a 7/16" roundover Melt the edge and Finish it out.
    Epoxy will take care of the lower knot nicely.
    The drill press won't give you what your looking for though, that's the part I'd watch out for and the mistake you mentioned :) Gotta have a router to spin a 7/16" bit for sure (to have it cut anyway).
  5. fluid69
    fluid69 Tele-Holic
    755
    May 13, 2010
    usa
    +1 buy or borrow a router. A drill press will not turn the same rpms. Arm & belly cuts arent bad, but do some research first. Read a few threads. I use a grinder with a sandpaper flapper wheel. I draw lines on the body as guides and never go to them. Leave some "meat" on there to block sand into shape. My favorite block for this is a paint stick. And on the arm contour, start @ the top and roll down to the edge. I see some flat arm contours. Fenders are not flat. Best of luck! That's a real nice looking body.
    P.S. 7/16th" round over bits are hard to find and usually have to be ordered from some place like stew mac. 1/2" will work too.
    "If you want rules, read the IRS tax code. If you want to build guitars, make some sawdust." -Colt W. Knight
  6. Hodgecraft
    69
    Aug 4, 2011
    Bristol, UK
    Ok, thanks for the advice, I suspected the drill press might not cut it for routing because of not being designed for horizontal pressure, I hadn't even considered the fact that it just wouldn't get up to speed!
    Are the arm and belly cuts usually done after rounding over the perimeter?
  7. Rich Rice
    Rich Rice Poster Extraordinaire
    Jul 15, 2005
    Chicago 'Burbs
    That's the easiest way. That way you can see where and how much you need to blend from the contours to the "straight" edges.
  8. Hodgecraft
    69
    Aug 4, 2011
    Bristol, UK
    Awesome, thanks for the advice. I am thinking I will probably keep an eye out for a half decent router, I hope to pursue many projects like this in the future and most of the guys here seem to rinse through their builds fairly easily with the help of a router.
    Any suggestions of a decent router to buy on a budget? Although I do recall someone saying you only need to buy expensive tools once.
  9. Rich Rice
    Jul 15, 2005
    Chicago 'Burbs
    Lots of options, but solid, smaller one I use constantly is the Bosch Colt. You can get them on sale quite often via Amazon, but check around. My bigger ones are plunge routers, but for a few guitars those get pretty expensive. You can do a ton of work with the Colt, and it's easy to handle.
  10. fluid69
    fluid69 Tele-Holic
    755
    May 13, 2010
    usa
    Id probably splurge on a spiral bit.
  11. Crafty Fox
    Crafty Fox Tele-Holic
    857
    Nov 25, 2011
    Perth Australia
    You may be able to use the workshop/tools in you local tech college. And if you import any routers remember the US is not 240volts. I use an big old Makita for all the larger cuts and a Makita laminate trimmer for more delicate jobs. I've heard good things about the Bosch Colt, and I saw a new small Dewalt last week which caught my interest for future possibilities.
    I've been using my Makitas regularly for over 25 years (I'm a carpenter) but wouldn't necessarily buy them again now they're made in China.
    Will you also put a Jazz pickup at the bridge? I did that on my Telecision Bass.
    Have fun with the build.
  12. Bentley
    Bentley Friend of Leo's
    Jul 25, 2012
    Kelowna B.C, Canada
    ooh, square edges.. do some binding!
  13. Moldy Oldy
    Moldy Oldy Tele-Meister Ad Free Member
    338
    Jun 25, 2012
    Mission Viejo, CA
    The spiral bit requires a 1/2" collet. I don't think any of the compact routers have one that size, so bear that in mind while shopping. For a budget router, Skil makes one or two full sized routers with the big collet. I don't think many of the other budget brands (Ryobi, Ridgid, etc.) do. But I'm saving my money for one of these.
    http://www.homedepot.com/h_d1/N-5yc...yword=Bosch+router&storeId=10051#.UQzHMHy9KSM
    http://www.homedepot.com/webapp/wcs...R=100341666&catEntryId=100341666#.UQzIR3y9KSM
  14. nosmo
    nosmo Friend of Leo's
    Jan 31, 2012
    Lake Jackson, TX
    Don't be so quick to limit yourself to a solid color. The grain on the front (top) is beautiful. You have square edges. You could put binding on the top and color the sides & back. Or.....you could round over top & back and burst from a transparent top to a solid back. Or......
    You get the idea ;)
    Edit: What do you need a spiral router bit for?
  15. Hodgecraft
    69
    Aug 4, 2011
    Bristol, UK
    I think nosmo is right. Here's what I'm thinking:
    2-tone burst on back and front. Hopefully something like this one:
    Standard p-bass body contours with white binding on front.
    Initially I only have a few problems/questions. First of all alder is darker in colour than ash (which is what I think the strat above is made of). Am I going to have difficulty getting a light amber colour to match the strat? Should I be prepared for it to come out much darker?
    Secondly, is putting binding around the front arm contour gonna be a complete pain in the proverbial?
  16. RogerC
    RogerC Poster Extraordinaire Vendor Member
    Mar 30, 2011
    Oklamerica
    Yes. If you're going to bind it, don't do an arm contour.
  17. Hodgecraft
    69
    Aug 4, 2011
    Bristol, UK
    Dagnabbit! What would be the main problem of mixing binding with a contour? Routing the binding channel or bending the binding?
