Bandmaster Reverb With 2 Ohm Secondary?
Discussion in 'Glowing Bottle Tube Amp Forum' started by robrob, Nov 13, 2017.
  1. robrob
    Dec 29, 2012
    United States
    I just noticed that the back plate of my AA270 silverface Bandmaster Reverb says "TOTAL LOAD 2 OHMS" at the speaker jack. All of the Bandmaster Reverb schematics (AA768, AA1069, AA270) say, "TOTAL LOAD 4 OHMS". I have always run this amp with a 4 ohm load.
    A 2 ohm output is normally for 4 eight ohm speakers in parallel but the Bandmaster Reverbs were supposed to push 2 eight ohm speakers in parallel.
    Is the 2 ohm plaque simply listing the amp's minimum load?
  2. Wyatt
    Wyatt Tele-Holic
    917
    Nov 3, 2004
    That's a SF Super Reverb back panel. 2 ohms; 45 watts
    Maybe it was put on stock by mistake (both amps used the same chassis)? Or found its way on along the way?
  3. corliss1
    corliss1 Tele-Afflicted Gold Supporter
    Sep 13, 2008
    Lansing, MI
    Here's a shot of one I had. This was a drip edge from 69. No such label on mine, but I'd suspect you're right about it being the minimum load.
    RoscoeElegante likes this.
  4. corliss1
    Sep 13, 2008
    Lansing, MI
    Ooooooh good call on the possible Super Reverb rear panel, @Wyatt
  5. Andy B
    Andy B Tele-Afflicted Silver Supporter
    Mar 16, 2003
    Colorado
    Rob,
    My ‘73 BMR says “Total load 4 ohms”
    “45 Watts RMS”
  6. robrob
    Dec 29, 2012
    United States
    Thanks Andy, I'm thinking maybe Wyatt is right and it's a replacement rear panel or maybe it was a factory mistake. All the Bandmaster Reverb rear panels on Google say 4 ohms or don't list the load at all.
    Andy B likes this.
  7. Staypuft1652
    Staypuft1652 Tele-Meister
    321
    Mar 7, 2017
    ND, USA
    Lovely pic.
    RoscoeElegante and robrob like this.
  8. Wally
    Rob, what is the output rating below those output jack? If it reads 45 watts, then one could think that Wyatt is correct about the subbed back panel.
  9. Wyatt
    Wyatt Tele-Holic
    917
    Nov 3, 2004
    Not sure we can go with that.
    I just checked my '66 Super Reverb and it says 40 watts (not that I can guarantee it's original, but I think it is). And @Andy B's SFBR apparently says 45 watts.
  10. corliss1
    Sep 13, 2008
    Lansing, MI
    It does saw the 45 watts, @Wally
    The Super Reverb panel makes even more sense because of Fender only using the 8ohm speakers in most situations, athough it would likely need to be an early panel.
    @robrob - does that panel look original? What about the OT connections?
  11. Wally
    Hmmmm....and here I have always thought the SR was a 45 watt amp while the Bandmaster/Pro Reverb/and other 2 x 6L6 amps with the small OT were 40 watt amps. The Bassman with a SS rectifier versus the tube is a 50 watt amp, is it not? Ah well....... mysteries abound.....
  12. Wyatt
    Wyatt Tele-Holic
    917
    Nov 3, 2004
    To my knowledge that is so, I was surprised to see 40 watts on my back panel.
    But here are two more '66 SR's that say "40 watts"...
  13. Andy B
    Mar 16, 2003
    Colorado
    To my understanding the 40 watt amps changed to 45 watts sometime around 1971. The My Pro Reverb which dates 12/70 is 40 watts while my ‘73 BMR is 45 watts. I’ve never paid that close attention to the back nameplates on all the amps I’ve serviced.
  14. Joemayline
    Joemayline NEW MEMBER!
    Portland, OR
    Just dropped my '71 Bandmaster Reverb off to have the ohms verified. It also says 2ohms total load and 45 watts on the back panel. It's all original. I'll report back when I find out what's up.
  15. Dacious
    Dacious Poster Extraordinaire
    Mar 16, 2003
    Godzone
    My friend's 74 VR says 45 watts. I think it's a paper/marketing claim only. My 78 VR had no wattage marking.
  16. trouserpress
    trouserpress Tele-Meister
    394
    May 4, 2015
    Leipzig
    Here's a pic of my 1974 Bandmaster Reverb's backside.
    BobbyZ likes this.
  17. radiocaster
    radiocaster Friend of Leo's
    Aug 18, 2015
    europe
    Have you measured the resistance at different points of the OT and compared it to other similar OTs?
  18. RLee77
    RLee77 Friend of Leo's
    May 15, 2016
    Silicon Valley
    Can you get a part number off the OT and look up the spec?
    BobbyZ likes this.
  19. zook
    zook Friend of Leo's
    Aug 6, 2003
    Cochise, AZ
    Why don't you check the OT's winding and see what the actual impedance is?
