Join TDPRI Today
Bandmaster reverb vs twin reverb
Discussion in 'Amp Central Station' started by flag72, Mar 3, 2012.
  1. flag72
    flag72 Tele-Afflicted
    Aug 20, 2009
    Canada/venise-en-quebec
    well on my long search for a vintage amp 2 model have come up, a 1973 fender twin reverb in good but not great condition cosmetic is ruff a few scuff on tolex and grill as darken some wath and internals are good but caps and tubs might need to be adresse to latter on.the Bandmaster reverb is a 1979 head and speaker cabinet both are fender piece in great cosmetic condition and very good internal condition as no issue, twin is going for 650.00 and the bandmaster 750.00. Im not familiar with the bandmaster is this a good amp these amp are big I know so dont mention it but how do they compare...
    thanks for the advice guys and gals;)
  2. Dr. Bill
    Dr. Bill Tele-Afflicted
    May 1, 2003
    Upstate, SC
    If the Bandmaster Reverb is a 70-watt ultralinear transformer model, I'd get the Twin instead.
  3. twangplank
    twangplank Tele-Afflicted
    May 29, 2010
    Valliant Okla
    I prefer the twin in this situation. I have a bMr and had a twin. I loved the twin for big clean sound. The bandmaster is a good amp but I don't like head and cab deals.
  5. CoolBlueGlow
    CoolBlueGlow Tele-Afflicted
    Nov 20, 2011
    Arkansas
    If you want my opinion (like the forum rules state I should only give...:)
    I would without hesitation go for the Twin.
  6. robt57
    robt57 Telefied Ad Free Member
    Feb 29, 2004
    Portland, OR
    Me, I'd take the BMR if I had to have only one of those two. It is a calm 40 watts though I should say [IMO] as compared to the big head room the twin will provide.
    if you need a Big Block, get the twin...
    "1979 should be too early for a UL BMR, weren't the UL amps more like 76?"
    EDIT: What? Boy I re-read that and it make no sense at all.... Brain musta moved on already....
  7. Chris Winsemius
    Chris Winsemius Tele-Meister
    234
    Aug 5, 2009
    Netherlands
    The use of UL transformers did start in '77 (70 and 135 Watt models); the VibroluxReverb, DeluxeReverb, Princeton(Reverb) and (Vibro)Champ did keep "regular" transformers.
    In this case I would also go for the TR. Spend a bit on TLC and you have a great (clean) gigging amp imo.
  8. Delta63
    Delta63 Tele-Holic
    515
    Nov 20, 2010
    Hands down: twin reverb (tonewise)
    but: its LOUD
    and if its too loud: get a good attenuator.
  9. robt57
    Feb 29, 2004
    Portland, OR
    I have not played a UL BMR, but had a SFSuper UL. I'd say the BMR UL should have the head room, guess on my part. But if the UL super is an indicator, it may not have quite the sweet spot.
    Did they drop the Tube Rectifier in the UL BMR? I am thinking [scary I know] that was the case, thus totally different animal from the 73 BMR I had.
    I would sure miss the 73 MBR more if not for the 63 Brown Pro that I got to replace it... Reverb, schmeverb. ;)
