B5 Bigsby with standard saddles...
Discussion in 'Tele Home Depot' started by danbind, Aug 26, 2013.
  1. danbind
    danbind TDPRI Member
    94
    Feb 2, 2005
    Annandale, VA
    I got a B5 Bigsby to put on my project tele. I want to use the cutoff bridge plate and standard saddles--I never liked the look of the Bigsby plate, it reminds me of the ashtray, which I never used on my old tele.
    I built a jig to hold my dremel securely, to grind notches in the back of the plate:
    I set the height of the bridge plate with some scrap so that I could rock the tool up and down just enough.
    It turned out not crappy:
    It still needs some filing.
    My real problem now is that the B5 string spacing is way too narrow. Callaham sells a modified string bar (or whatever you call it) with the pins drilled out; I queried whether they had a version with wider spacing, so that you don't need notched saddles. They did not--said it really wouldn't fit. I am hereby consternated--I really don't want to notch my compensated saddles...
    I was thinking of having one machined locally, though not really sure if this is cost-effective...anyone have other ideas? Thanks!
  2. D_Schief
    D_Schief Tele-Holic
    978
    Apr 23, 2005
    Richmond, VA
    Do you think threaded steel saddles would help you get the proper spacing?
  3. danbind
    94
    Feb 2, 2005
    Annandale, VA
    I would think the threaded saddles wouldn't result in good Bigsby-ing; I would think I need wider notches. My compensated saddles are un-notched, but I guess the simple option is to just replace them instead--save'em for another project. They are some Callahams that sound terrific without the Bigsby, so I don't want to experiment with notching them myself.
    Maybe try the Rutters?
