Ash firewood
Discussion in 'Tele Home Depot' started by Hollywood691, Dec 25, 2018.
  1. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    I had that same problem with that same router.
    I went to Harbor Freight and bought their equivalent current model and I can't believe how much better it runs the same tools and same projects. Probably twenty bodies with it by now.
    I also replaced the same vintage quarter sheet pad sander with the HF random orbital palm sander and holy cow! so much better results.
    Newbcaster and SheldonP like this.
  2. moosie
    on the roof
    Make a square or rectangle of the same material, ideally grain matched. I used the offcut from my alder blank. It can be any shape, really, just straight edges. Lay it over the offending area with a small bit of double stick tape, just so it won't move while setting up the template. Lay some straight-sided 3/4" MDF scraps against all four (or more?) sides, and stick these down very well. Lift out your patch block, and rout using a top bearing bit. Glue block. Lay out, and re-cut. Don't screw it up this time. :twisted:
    Here's my body with the block prepped for the do-over.
    And here's the result:
  3. Hollywood691
    Hollywood691 TDPRI Member
    East Texas (Livingston) & (Huntsville)
    Experience as a woodworker is minimal, I've built alot of stuff ie...tables, benches, cabinets etc. but nothing like this. This is my first attempt to build a guitar (I've wanted to for a long time). I am trying to patch it up to fix it. I certianly dont want to trash it haha.[/QUOTE]
    El Tele Lobo and GPlo like this.
  4. unfamous
    unfamous Tele-Meister
    North Georgia
    Lutherie is quite a bit of repairing one's screw-ups. I read that on the internet, but learned it first-hand before I 'd read it.
  5. Hollywood691
    Thank you everyone for the encouragment on my first build, and to moosie for the example pics!
    I still need a little fixing on the control cavity, but did fix the neck pocket today and have a question.
    The ole tele neck I have is a tad loose in the pocket, what do i need to do about that?
    El Tele Lobo likes this.
  6. El Tele Lobo
    El Tele Lobo Friend of Leo's
    Be encouraged, brother! We all mess up… Especially when you’re learning. That’s when you learn the most. And somehow, it’s that much more satisfying, when you hang on and make it work anyway.
    Sent from my iPhone using TDPRI forum mobile app
    Hollywood691 likes this.
  7. Bergy
    Bergy Tele-Meister
    Denver
    Nice save! Really like that grain. How ya gonna finish it? I’ll be interested to hear some remedies for a loose neck pocket, myself.
  8. Jupiter
    Osaka, Japan
    I wouldn’t do anything if it’s only a little loose; I like that wiggle room to help me adjust for any failures in geometry with my bridge. :rolleyes: Especiallyokay if you are assembling the guitar in a dry season.
    If you do want to tighten the pocket a bit, I have used tape on the template walls for that.
    Edit: but now I see you’ve already cut the pocket, in which case I’d just say “onward!” :)
    Newbcaster and Hollywood691 like this.
  9. moosie
    on the roof
    I hoped mine would give a little sucking sound as the air was pushed out, but alas, it's a bit loose, too. Just enough for a 1/32" maple shim to fix. You can see it if you look close, but it's glued in permanent. (I'm not talking about the StewMac shim - that was needed because the WD Music neck was a little bit off. Had the same need on a couple of actual Fender bodies I tried it with, too.)
  10. Hollywood691
    Shooting for Blonde Butterscotch nitro lacquer I got from reranch. I wanted to try to build this as close to a 1950 Broadcaster as I can....on a thin to no Budget LOL. And yes I thought this was a beautiful slab, I bought 2" x 14" x 60" in Houston for $55, I know I can custom paint and airbrush it, but wanted to go vintage on it. Next body I'll try something exotic on it.
    I tried witch doctoring some urethane kandies on these scrap pieces, the thin strip has a clearcoat on it.
  11. guitarbuilder
  12. Hollywood691
    And that is just what I have on this one.....that makes me feel better, haha, still may shim it like moosie did.
  13. Bugeater281
    Bugeater281 Tele-Meister
    Omaha
    I didn’t see this mentioned. For the router issue, make sure your bit is sharp! And don’t take out too much material at once. My first few experiences with a router were terrible. I split I neck down the middle, gouged deep holes from bits coming loosed ect. I was always too excited to get the project done and would rush, the vibrations for being aggressive can cause stuff to come loose. I own 4 routers now, I’ve had mishaps with all of them. I thought a better router would help, nope... it was my technique. I’ll even take a rasp on any points after driller to avoid tear out.
  14. moosie
    on the roof
    I just noticed in my earlier pic (post #22), I'd already glued the shim in place on the bass side of the neck pocket. See it?
    And here's the finished guitar. Sure, builders can tell it's a first effort, but my mom would think it's amazing! :lol::lol::lol::lol:
  15. Hollywood691
    Yes, I see the shim and thats what I may do also........this is my very first build so I certianly couldn't tell it's a first effort LOL! Like your mom, I think it looks Great! Like the color and the binding.
  16. moosie
    on the roof
    Aww, thanks mom :D
    My point being ... don't feel like you've screwed the pooch. Lots of room to still end up in the win column. Even if you blow a few more things, like I did. :rolleyes:
    Hollywood691 and El Tele Lobo like this.
  17. Crafty Fox
    Crafty Fox Tele-Afflicted
    Perth Australia
    I made the neck pocket too long on my most recent Thinline but glued in a similar block of ash and re-routed the pocket.
    By the time I stained and finished you can hardly see it.
    grooveht, Tonetele, Frankito and 4 others like this.
  18. Hollywood691
    All fixed and neck fits almost like a glove, haha
    Crafty Fox, moosie and GPlo like this.
  19. GPlo
    GPlo TDPRI Member
    Netherlands
  20. Mike Simpson
    Gilbert, AZ (PHX)
    Just needs the right pickguard shape
