Are guitar necks made so there’s more relief on the low side?
Discussion in 'Bad Dog Cafe' started by 8barlouie, Mar 22, 2019.
Tags:
  1. 8barlouie
    8barlouie Friend of Leo's Gold Supporter
    Seekonk, MA
    It’s a question that I’ve had for a while but never until now remember to ask. The vast majority of guitars that I’ve owned have had slightly more relief on the sixth string side than the first string side. Is this something the builder does, or is it a function of string thickness, or some other cause? It does make sense to me since the bottom string bounces more especially when hit hard.
  2. ale.istotle
    ale.istotle TDPRI Member
    Pennsylvania
    I did it by mistake. When I did the radius on the fretboard I was a little off center. Fretboard crowns under the g. Plays great.
    Danjabellza and 8barlouie like this.
  3. D_W_PGH
    D_W_PGH Friend of Leo's
    Pittsburgh
    The one neck that I made with a compound radius (I planed and scraped the fingerboard radius out) is made like that.
    It's not technically the correct thing to do with a radius, though - the idea is that the compound radius allows the string height to be the same at the first and 14th fret in relative terms across the fingerboard.
    Planing a compound radius the way I mentioned is actually planing a neck with twist in it, which isn't really that bad as the effective twist built into the neck is actually a little nicer in ergonomic terms. But you'd have to point it out for someone to see it or notice it. You wouldn't want the twist going the other direction.
    8barlouie likes this.
  4. darren7
    darren7 Tele-Holic
    Toronto
    A radius being off-centre isn't the same as having different relief along the length of the string.
    Some basses and extended-range guitars have two truss rods that allow for dialling in slightly different relief on high vs. low strings.
    ale.istotle and 8barlouie like this.
  5. Chunkocaster
    Chunkocaster Friend of Leo's
    In space with Ziggy
    Many necks are slightly twisted like this. Sometimes it works in your favour.
  6. radiocaster
    radiocaster Friend of Leo's
    europe
    I thought it was to take the extra pressure of the longer scale. In any case, I usually set up guitars and basses with higher action on the bass strings by having the bridge higher there.
  7. 8barlouie
    Seekonk, MA
    It does seem that the overwhelming majority are set with more relief on the bottom side however.
    DugT and Chunkocaster like this.
  8. 8barlouie
    Seekonk, MA
    Right. Higher action is one thing. I’m asking about having more relief on the bass side.
  9. Danocoustic
    Danocoustic Tele-Meister
    SE lower Michigan
    Perhaps because the thicker strings exert more pull on the bass side---?
    backporchmusic and 8barlouie like this.
  10. 8barlouie
    Seekonk, MA
    I like that. Sounds plausible.
    Danocoustic likes this.
  11. Chunkocaster
    In space with Ziggy
    You mean the wound low e side?
    I just received 2 new never fitted necks this week. Two different makers and both have slightly more relief on the wound low e string side. I think nearly every neck I have bought has been the same.
  12. backporchmusic
    backporchmusic Friend of Leo's
    The more tension from the bass strings has more back bow, that's always been my conclusion. And if the treble side has more back bow, then I don't buy it.
    boredguy6060 and 8barlouie like this.
  13. 8barlouie
    Seekonk, MA
    That’s it!
    Chunkocaster likes this.
  14. Chunkocaster
    In space with Ziggy
    Yes, string tension has nothing to do with the necks when they are new and have never been fitted to a guitar. Maybe it's intentional? I don't know. I do know that I can get a low action with no buzz within certain tolerances including the slight difference in relief from low to high e side. Looking down the necks of all my guitars they all vary from low e to high e side though even after being played in for years.
  15. 8barlouie
    Seekonk, MA
    I’m pretty fussy about neck relief so I rarely leave the relief on a neck as is. Come to think of it, the only guitar I can remember not having to adjust relief on was the Tele I bought from @Ronkirn, which was dead nuts on.
  16. Chunkocaster
    In space with Ziggy
    I will adjust one of the necks before fitting but the other looks close with a slight back bow so will leave that until I string it up. I adjust all my guitars actions by feel and eye.
    These are both all maple but one is roasted so will probably react differently under tension.
    I'm a little fussy but I play acoustic lead runs a lot too so i'm also comfortable with a higher action and stiffer strings.
  17. philosofriend
    philosofriend Tele-Holic
    Kalamazoo
    Having a little more relief on the bass side is a very fine point. The amount of difference is very little compared to how hard it is to just reliably make necks that will have acceptable action for a non-discriminating customer after the wood of the neck and the fingerboard do their inevitable warping in the first couple of years. There is a fight between the fine points of how the truss rod applies its forces to the neck and the forces trying to warp the neck. After a couple of years, when refretting, a luthier who has a customer who cares enough to pay for it can shape the fretboard for a little more relief on the bass side. The more likely explanation in practice is just that the bass strings have mor tension.
    Classical guitar maker Hauser was famous for paying attention to the fine points of action like this. Segovia played one of his guitars for decades.
  18. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    I’ve noticed this on all my guitars. What appears to be happening is that the greater tension of the thick strings very slightly twists the neck resulting in slightly higher action on the E and A string side. You maintain low action for the soloing strings while the higher action if the 5th and 6th strings minimizes the dreaded fret buzz. The action seems to be highest around the 12th fret where the amplitude of the vibration is greater. I see this less on my SG with its very thick neck.
  19. ale.istotle
    Pennsylvania
    Tension's not necessarily highest on the bass side of the neck. sample of guitar and bass tensions.
    DugT, scelestus, 8barlouie and 2 others like this.
  20. Danocoustic
    SE lower Michigan
    There goes my theory!
    Thanks, that's useful info.
