Join TDPRI Today
Applying new decal to Squier headstock
Discussion in 'Telecaster Discussion Forum' started by alexgregg, Jan 13, 2011.
  1. alexgregg
    alexgregg TDPRI Member
    5
    Jan 13, 2011
    Hi there guys,
    Long time reader, first time poster so please bear with me =)
    I went out the other day and bought my first tele. An affinity Squier. It's beautiful, and I'm working on giving it a bit of an aged look (without touching the finish, I'll let nature take it's course there).
    I've Worn the hardware with the acid fume method, and added a few dinks by shaking in a container with gravel. Everything looks great!
    I really appreciate all the help I've found on the forums.
    I'm also hoping to add a custom decal (my name in the fender script) alongside the squier one. I've got the decal ready, and was wondering what I should do afterward to make sure it endures the test of time.
    The headstock is what I think to be a matted finish, there's certainly no huge shine to it, and not nearly as much as my satin SG.
    So, am I looking to apply the decal, allow to dry and cover with a clear, matte sealer?
    I really appreciate all the help.
    Cheers,
    Alex
  2. ledet
    ledet Tele-Holic
    823
    Jun 2, 2009
    Hjørring, Denmark
    I put a new decal on one of my Squiers. It has the satin neck finish too. I used Duplicolor gloss clear and gave it about 10 coats, alternating between light and heavy coats. Let it dry for a couple of days in between and used steel wool too. After the last coat I let it dry for a week and gave it some fine steel wool, gave it a very nice satin look that matches the rest of the neck.
  3. Hammerhead
    Hammerhead Tele-Meister
    225
    Jun 30, 2008
    Aberdeen
    Doing this right now. Runied the first decal by going in too heavy with the first coat of lacquer after it was applied - some nasty bubbles came up.
    Going to try again with a few light "mist" coats first...
  5. a.z.n
    a.z.n Tele-Meister
    124
    Jul 25, 2009
    Toronto, Canada.
    Related question -
    How does one go about removing the existing decal?
  6. SackvilleDan
    SackvilleDan Tele-Holic
    840
    Feb 8, 2009
    Sackville
    I removed mine with a razor blade... just kept back-scraping until the logo and surrounding finish was removed. You could likely just sand the whole headstock down and re-finish it if you wanted the best results.
  7. Hammerhead
    225
    Jun 30, 2008
    Aberdeen
    I used wet/dry sand paper.
  8. very important - after applying the decal, allow to dry for at least 48 hours before applying any finish.
    These things retain miniscule amounts of water and will result in bubbling under a finish that's applied too soon.
    Hammerhead, I think that's what may have happened to you. The thickness of the coat shouldn't (in my experience) make any difference.
  9. Hammerhead
    225
    Jun 30, 2008
    Aberdeen
    OK, will leave it a while this time to be on the safe side. But most of the posts I've read on here, and even the isntrictions that came with the decal said to give it a few light mist coats first.
    But who reads instructions? ;)
  10. alexgregg
    5
    Jan 13, 2011
    Thanks for all the help guys, as soon as the custom decal arrives, I'll get into it.
    So, from what I've read so far:
    If I were to remove the squier decal, I should use very fine steel wool, or wet and dry sandpaper.
    Then, because the headstock is in a matted finish, I need to apply a few coats of gloss before applying the decal.
    Wait 48 hours.
    Then hit it with a few light coats of laquer/sealer and build up to heavier coats?
    Is there a way I can maintain the matted finish and still have the decal applied?
    Thanks again for the help =)
  11. Five-O
    Five-O Tele-Afflicted
    Nov 2, 2008
    Huntsville, AL.
    Hitting the decal with that heavy (wet) coat first, will allow the clear coat to attack, for lack of a better word, the finish of the decal, results not pretty... as you know.
  12. banjohabit
    banjohabit Tele-Holic
    963
    Mar 17, 2011
    virginia
    c'mon man. ain't you got a sharpie?
