Anyone using an aby pedal to run 2 amps simultaneously?
Discussion in 'Bad Dog Cafe' started by Cheap guitar guy, May 13, 2019.
  1. studio1087
    studio1087 Telefied Silver Supporter
    Near Milwaukee
    I use the Radial Big Shot. The 180 and lift switches are great for when two amps are not in phase with each other.
    There about $50 used.
    Playing with a sparkling clean amp behind a dirty amp sounds gigantic. It’s a lot of fun if you’ve never tried it.
    Huuuuuge!
    eddy b. likes this.
  2. Cheap guitar guy
    Cheap guitar guy Tele-Meister
    PA
    What about playing both dirty but different dirty. If you know what i mean. And say one with chorus and one with a touch of wah.
  3. Ironwolf
    Ironwolf Poster Extraordinaire Gold Supporter
    Boise, Idaho
    This is so true.
    rze99 likes this.
  4. Ironwolf
    Boise, Idaho
    It can be done. It just depends on where you put the switcher in the signal chain.
  5. kafka
    kafka Tele-Afflicted
    Maryland
    Yeah, I've done it a lot over the years. I like to take two totally different amps and play them at the same time. A big crunch amp with a huge clean is a lot of fun to play.
    That said, I don't do it all that often, and I actually find it kind of limiting to play like that. It's sort of a special effect.
    As to devices to accomplish this, usually I just used a Y-cord. At one time I had a little junction box that I made to do the same thing. I think at some point I must have used some kind of stereo pedal with the effect off. Maybe a chorus or something. I suppose the right way would be to use some kind of buffer. You can buy all kinds of stuff these days. I just did it using whatever was at hand.
    rze99 likes this.
  6. gobi_grey
    gobi_grey Tele-Holic
    clinton, ia
    Old age set in overnight at the ripe age of 34 and now I'm too lazy to lug two amps around so my Radial ABY goes untouched these days. I sometimes use it at home just messing around with sounds but for playing live, easier has won and one amp is more than enough sound anyway.
  7. gusfinley
    gusfinley Tele-Holic
    SLC, UT
    You may own a cheap AY pedal aready!
    The Boss pedal format tuners have two outputs, one which mutes the signal when the tuner is engaged and one that bypasses the mute function.
    Plug the input of the amp you want on all the time into your BYPASS and engage the tuner. Plug the input of the amp you want to switch in the OUTPUT. Disengage the tuner when you want to run both amps.
    kafka likes this.
  8. meric
    meric Tele-Holic
    Vancouver
    I use the Radial BIGSHOT with DRRI and a Peavey Bandit. Endless variations. I really like the Peavey dirty and the Fender clean and sparkly...what a glorious sound. I love the versatility and the sound but I have never dragged both amps out to play...too much work and most likely not enough of a difference in a band setting to justify the extra work.
  9. rze99
    rze99 Poster Extraordinaire
    South London UK
    It's worth it. I haven't gigged using just a single amp for about 20 years. That said, much of that was as the only guitarist in the band where you really notice it filling out the sonic spectrum. It also helps stage spread and singer's pitching.
  10. Telesavalis
    Telesavalis Friend of Leo's
    Deep in the Heart O Texas
    Whirlwind AB Selector works good for two amp set up
  11. eddy b.
    eddy b. TDPRI Member
    New Orleans
    I use the Radial aby box with ground lift and polarity switches and all that goodness. I use a Deluxe Reverb clean and A Blues Jr. Tweed III and yes it is awesome and worth the extra effort.
  12. blackbelt308
    blackbelt308 Tele-Holic
    Columbus, Ohio
    I play through two amps - 1964 PR and 1978 DR - simultaneously. I use a Voodoo Labs Amp Selector and it works great. No noise, no hum. Have been using this rig without issues for several years. The Amp Selector is part of my pedalboard, last component before the amps. I also use the Voodoo Labs Pedal Power units.
    Ciao,
    Rick
  13. Paul in Colorado
    Fort Collins, CO
    I just do it with my stereo effects pedal. I'm running a Peavey Backstage Plus and a '52 Silvertone "Champ" type amp with an 8" speaker and a single volume knob. I don't seem to be getting any noise.
    I used to run a DR with an AC-15 using a Roland Space Echo to split the signal. If I still had the DR, I'd still do it.
  14. Doctorx33
    Doctorx33 Tele-Afflicted
    Atlanta
    I do it all the time. In fact, right now I have a four amp setup.
    • AC30 and a traynor YBA1a in stereo for dirt
    • Bassman 100 for clean with chorus and delay
    • Blackface bassman driving a Leslie 16.
    I have morley a/b/y and an A/b pedal I built.
    With this rig I can get:
    • The stereo dirt rig alone
    • The Leslie alone
    • The clean rig alone
    • The dirt rig with the Leslie
    • The clean rig with the Leslie
  15. ClashCityTele
    ClashCityTele Tele-Meister
    Washington, UK
    A friend of mine, Neil, the singer/guitarist in the charmingly named 'Bastardface', does this with 2 Marshall 100 watters & 2 4x12's...at bar gigs!!!
    Uses one amp & kicks in 2nd when needed, or uses both...just because he can.
