Anyone make a bass using GFS body/neck?
Discussion in 'The BASS Place' started by El Hefe, Nov 3, 2012.
  1. El Hefe
    El Hefe Tele-Meister
    338
    Oct 19, 2011
    co
    Has anyone made a bass using GFS body/necks? tell me how it came out and what you think of it..
  2. El Hefe
    338
    Oct 19, 2011
    co
  3. El Hefe
    338
    Oct 19, 2011
    co
  4. Boundforglory07
    Boundforglory07 Tele-Holic
    675
    Jan 26, 2011
    Oshawa
    I'll bump this too. I would like to know as well
  5. 20721
    20721 Former Member
    446
    Sep 28, 2012
    San Diego
    I bought one of the Jazz bodies two years ago, had to leave on business travel before it arrived (this will be important later). Came back a month later, opened the box, and found that they use a non-standard neck pocket size (2 and 7/16" instead of 2 and a half inches) and a non-standard Jazz pickup routing. They don't sell Jazz pickups that fit their Jazz bodies, BTW. I haven't found anyone who does. As for the neck pocket, fine if you use their necks, not so great if you're trying to replace a Fender body.
    In addition to discovering the non-standard fit (fine, that's fixable) I discovered the neck pocket was routed far too deep into the body AND was routed at an angle that would have put the side of the bridge within one inch of the volume control.
    They wouldn't take it back as it was outside their time period for returns, in spite of the grossly obvious defect. While I understand the time limit was stated in the terms of the purchase, and it is on me for not returning it in time, it speaks volumes about their non-existent commitment to customer satisfaction that they would not even consider doing so in spite of obvious defects.
    The body ended up in the trash. There was simply nothing else to be done.
    Here's the deal with GFS: their prices are possible because they buy the lowest quality product from the lowest cost vendor and have outsourced their quality control to you. There's a place for that kind of vendor, if you're good enough to deal with fixing defective merchandise and have the time to do so. I've used them since. I will use them again. But they don't get the same benefit of the doubt that I routinely give other vendors. I don't buy from them unless I absolutely have to - and I rarely have to.
    I'll say this: they're the only reasonably priced source for paulownia bodies, one of my favorite solidbody woods, so if you're up for mortal combat with ****ty body routing or their returns people, I'd give it a shot. I plan to do so for a tele build in 2013. I'll buy my hardware off Amazon or from bezdez (eBay) as I usually do.
  6. fidopunk
    fidopunk Tele-Meister
    339
    Nov 23, 2008
    Charleston, WV
    I've built three paulowina tele's from them with similar results. One was routed by someone who was drunk, the other two were absolutely perfect. I have had excellent results with the GFS branded pickups but am split 50/50 on hardware.
    It's been brought up before that a bass with a paulowina body might suffer from severe neck dive (it's present on the tele's and they have much shorter necks). I'm surprised Tim hasn't chimed in-- he built a short scale bass from a tele guitar body. If I recall, he had to use lightweight tuners to fight the neck dive.
  7. Rob DiStefano
    Rob DiStefano Poster Extraordinaire Vendor Member
    Mar 3, 2003
    NJ via TX
    never used gfs bass wood, body or neck. i'd expect the usual hit or miss with fit and finish. no big deal for me, but could be anything from a speed bump to show stopper for others. considering the uber lightness of paulownia, do expect the neck to permanently dive whilst on a strap.
  8. El Hefe
    338
    Oct 19, 2011
    co
    Wow well I am very close to buying a maple neck for my squier pbass. I thought that they are all made to fender spec at the heel? They say that in the description.
  9. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
    Actually, they state the heel width as 2 & 7/16" whereas Fender spec is 2 & 1/2".
  10. El Hefe
    338
    Oct 19, 2011
    co
    These have industry standard 2 7/16" wide neck pockets- and can accept fender® licensed necks.
    So i don't get it?
  11. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
    This is from Warmoth website:
  12. fidopunk
    339
    Nov 23, 2008
    Charleston, WV
  13. fidopunk
    339
    Nov 23, 2008
    Charleston, WV
  14. 4mal
    4mal Friend of Leo's
    Mar 18, 2003
    The Gorge
    I've had success with Mity Mite. If I were looking at an inexpensive neck, I would start there.
  15. TimboZ
    TimboZ TDPRI Member
    27
    Sep 27, 2011
    South of Buffalo
    The stew-mac necks are Made by Mity Mite.
  16. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
    The topic is going off subject. The initial discussion involves specifically GF Bass bodies and GFS Bass necks. Looking for pros and cons on this specific matter.
  17. Tim Armstrong
    Tim Armstrong Super Moderator Staff Member
    Mar 5, 2003
    Austin, Texas
    Admin Post
    No, being given alternatives isn't off-topic. Pictures of kittens or discussion of motorcycles would be, though.
    I did build a short-scale bass using one of their Pawlownia Tele bodies, and didn't run into any problems except for the aforementioned neck dive, which was solved by using Hipshot Ultralite tuners. However, with the longer upper horn of a P or J body, I wouldn't expect neck dive to be an issue on a full scale bass, unless the neck was particularly heavy.
    I think the lesson from the earlier posts is pretty simple: carefully examine any GFS body for correct specs, and be prepared to return defective merchandise until you get a good one.
  18. Thinlineggman
    Thinlineggman Tele-Afflicted
    Jan 15, 2011
    Oregon City, OR
    I made my main P bass with one of their bodies and a mighty mite neck about a year and a half ago. Everything else except the bridge saddles and paint is from GFS.
    (pic is from just after I finished making it)
    I use it for everything. Jazz, rock, funk and P&W. She's been played hard and put up wet, and definitely shows the wear and tear since I used lacquer and the paulownia wood is so soft
    Not too much neck dive since I use a leather strap.
    EDIT: There was a lot of work that had to be done to make everything fit well and I still ended up with pickguard screws floating in the cavity routes. If you're good at creative problem solving and take your time, these bodies can turn into great instruments. If you rush and get frustrated, you're not gonna have any fun with it.
  19. teleforumnoob
    teleforumnoob Tele-Afflicted
    May 25, 2010
    North Alabama
    I did a tele(guitar) with a GFS raw paulownia body, and it went together clean as a whistle with an Allparts neck.
    No neck dive, but another ounce of neck and it would.
    A bass, no way. You'd have to add an anchor for ballast.
