Anyone ever glue a Tele neck joint?
Discussion in 'Tele Home Depot' started by Blue Bill, Sep 18, 2017.
  1. Blue Bill
    Blue Bill Poster Extraordinaire
    Feb 15, 2014
    I just had a weird thought...What if you glued neck to the body? Brush on some Titebond, clamp the snot out of it, bolt it nice and tight, let it set up for a couple days. Maybe it would increase sustain. Anyone ever try this?
  2. TmyBmore
    TmyBmore Tele-Meister
    223
    Jul 10, 2016
    Baltimore
    I heard Ritchie Blackmore glued his Strat necks. Of course I really don't know if he did. I'm happy with the way they are but will be interested to follow.
  3. Chordophonic
    Chordophonic Tele-Meister
    253
    Oct 4, 2013
    Isle of Wight UK
    My thoughts are that it would be do-able with a few caveats, all surfaces would need to be bare wood and the neck joint would need to be quite tight, I'm planning on doing this on a future build, but without the neck screws.......it will be interesting to see how it goes....
    kkphoto likes this.
  4. Blue Bill
    Feb 15, 2014
    My first thought was wondering whether glue, without bolts, would be strong enough. Thinking about it though, a properly glued wood joint is wicked strong and should be fine. Let us know how it works out.
  5. Strebs
    Strebs Tele-Meister
    256
    Dec 24, 2015
    Michigan
    If you do it, you may want to drill out and dowel the screw holes through the body and neck. I'm not sure there would be much tonal advantage to a glued neck though.
    Blue Bill likes this.
  6. BigDaddyLH
    I think there might be a Murphy's Law phenomena at work: you glue your neck then the next day you see the perfect neck to swap with.
  7. RodeoTex
    Sep 14, 2005
    Nueces Strip
    I've considered it but all my Teles have heel adjusted truss rods.
    Mike Simpson likes this.
  8. ndcaster
    ndcaster Poster Extraordinaire
    Nov 14, 2013
    Indiana
    Sustain is testable, right?
    Test before and after and see if there are any measurable differences.
    That's a different question than whether there are any audible differences to a person who's listening.
  9. kLyon
    kLyon Tele-Meister Gold Supporter
    217
    Mar 21, 2011
    US
    Ovation Magnum basses - crazy advanced and crazy looking 70's basses - had necks that were both glued and bolted.
    (I don't know if it had any appreciable affect, but I've got one and it sounds great... there it is...)
    brookdalebill likes this.
  10. Dismalhead
    Feb 16, 2014
    Auburn, California
    I'm sure you could do it, and do it well. But as someone who traded all but one of his Gibsons for Fenders a few years back, a big selling point of Fender for me was that you got a bolt-on neck.
    If you really want maximum sustain, get a neck through. I had an Ibanez Musician with a neck through. It had sustain for days.
  11. Preacher
    Preacher Friend of Leo's
    Apr 17, 2007
    Big D
    I saw some GFS Teles with a set neck. Not sure if they were glued in or not.
  12. Blue Bill
    Feb 15, 2014
    Of course, the huge issue is the utter non-reversibility of the experiment. I was hopng somebody already tried it. Even if I knew for sure that it would be awesome and sustain way better, I might not ever try it on one of my Fenders. Yours though...
    I like the dowel idea! That would be bomber strong.
  13. magicfingers99
    magicfingers99 Tele-Holic
    775
    May 7, 2015
    atlanta
    Roman guitars has a nice write up on set neck vs bolt ons. Basically he says a bad or even average set neck wont sound as good as a bolt on neck. I'm thinking of converting some of my set neck acoustics to bolt on necks.
    Bolt ons are easier to referet, and swap out if you want to change scale or whatever. Plus with a set neck you only get once chance to get it right, then you have to debond it with solvents or steam depending on the glue, if you want to fix any problems.
    a bolt on with screw inserts in the neck should couple to the body quite well and conduct sound quite well, now if you start shimming it your at the mercy of the sound properties of your shims and how much they reduce or improve contact between all the surfaces in question.
    Blue Bill and Dismalhead like this.
  14. BigDaddyLH
    I've read stories here of folks with great sounding and sustaining Teles, then they remove the neck and find a shim! Maybe it was not so great after all :confused:
    Steve Holt, cnlbb and Blue Bill like this.
  15. Dismalhead
    Feb 16, 2014
    Auburn, California
    I would love a bolt-on acoustic.
  16. viking
    viking Friend of Leo's
    Jan 23, 2007
    Denmark
    Please dont
    All you will end up with is a tele that you can't swap out the neck on if this should ever be needed/wanted
  17. Blue Bill
    Feb 15, 2014
    Here's a solution to the truss rod access: :D
  18. magicfingers99
    775
    May 7, 2015
    atlanta
  19. magicfingers99
    775
    May 7, 2015
    atlanta
    don't that put a crimp in your cowboy chords?
  20. cnlbb
    cnlbb Tele-Holic
    871
    Jun 19, 2014
    United States
    A fair number of acoustics are bolted on, but they also use a slight bit of glue. All the variations of Godin's acoustic use this method. It's nice as they're easy to steam out and resnug, however in general I do love a good dovetail joint and if you know what you're doing it's not that hard to pull off. The tricky part are the jigs for adjusting tilt.
