Anybody fixed ground hum in a tele like this?
Discussion in 'Tele-Technical' started by broadcasterite, Dec 21, 2013.
  1. broadcasterite
    broadcasterite TDPRI Member
    19
    Oct 31, 2010
    Washington D.C.
    My friend has a Mexican Fender tele that has been in his home for a long time. A few friends, including myself, regularly play this guitar.
    My buddy fixed a grounding problem causing hum by drilling a new hole in the metal plate and soldering the ground wire. It seemed to get rid of much of the hum. Any remaining hum might be further reduced by adding foil and/or replacing the pups with less noisy pups.
    Here is a 3 part video on the fix and testing the guitar:
    http://youtu.be/k-Ucca-L2aY
    http://youtu.be/PQ9DYhrUs-k
    http://youtu.be/BM8bTPG_IJ0
  2. waparker4
    Nov 9, 2011
    Philadelphia, PA
    There is no reason to have to drill a new hole in a Mexican Tele to install or fix a bridge ground wire
  3. dsutton24
    dsutton24 Poster Extraordinaire Ad Free Member
    Dec 29, 2010
    Illinois
    **** Warning: Curmudgeon Content! ****
    I mean no offence whatsoever, but not everything needs to have a YouTube video dedicated to it, let alone three. It looks to me like the ground wire for the bridge is missing, and replacing it was all that is needed. The lug under the pickup spring was never going to be a permanent fix, the screw through the bridge plate is better, but unnecessary.
    I freely admit to overcomplicating things on a regular basis, but there's no reason to go to extremes when grounding a Telecaster bridge plate, soldering, brazing, bolting aren't necessary, just sandwich the bare ground wire between the body and the control plate. It's a time tested method.
  4. broadcasterite
    19
    Oct 31, 2010
    Washington D.C.
    Thanks dsutton24 and waparker4 for your comments.
