Join TDPRI Today
Any tricks for elevating Tele neck p/u
Discussion in 'Just Pickups' started by uriah1, Dec 28, 2012.
  1. uriah1
    uriah1 Doctor of Teleocity Ad Free Member
    Feb 12, 2011
    Around
    As you realize, most tele neck p/u have those long 1-way thread screws.
    no rubber placer, like strats, that as you screw down, p.u goes up.
    As I screw down p/u goes down..as I screw up, screw comes out....
    I tried a matchbook under it...that helps...but only last a little while..
    until it is useless.
    thoughts?
  2. SPUDCASTER
    SPUDCASTER Friend of Leo's
    Longer screws and longer rubber tubing or springs.
    Assuming this pickup is mounted to the pickguard like a Strat?
    If it's standard mounted, again longer screws. Becareful if you lower the pickup. You don't want the longer screws going through the back of the guitar.:eek:
  3. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
    You need rubber tubing or springs beneath the pickup.
  5. uriah1
    Feb 12, 2011
    Around
    Dont think so...nothing sticks through..you have to remove black guard to get at neck vintage pu
  6. H. Mac
    H. Mac Friend of Leo's
    May 26, 2012
    Atlanta, Georgia
    Sponge rubber under the pickup and longer screws work for me.
  7. Ron Garson
    Ron Garson Friend of Leo's
    May 18, 2003
    There should be springs on those screws.
  8. uriah1
    Feb 12, 2011
    Around
    This is a mid 80' 52 ri.....maybe they did not think about it...the screws are pointy
    and go right into wood block..skinny screw too...where would you put rubber...
    there are no springs like a strat on the neck..
  9. Ricky D.
    Ricky D. Poster Extraordinaire
    I used surgical tubing on mine.
  10. Tonetele
    Tonetele Friend of Leo's
    Jun 2, 2009
    South Australia
    I prefer springs as tubing is usually unevenly cut and can lead to an imbalanced p/up.
  11. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
    You can substitute springs for the surgical tubing.
  12. Rob DiStefano
    Rob DiStefano Poster Extraordinaire Vendor Member
    Mar 3, 2003
    NJ via TX
    any pickup can only be raised up as high as the bobbin/cover height will allow. with a tele neck pup that's screwed to the body, the process is different that if the pup was pickguard or ring mounted. either increase the height tubing/springs or remove them and replace with a thick bed of pickup neoprene rubber - trim down the rubber as need be if it's too thick.
  13. uriah1
    Feb 12, 2011
    Around
    That is what I am thinking.
