Any Telecasters weighing max 6.6 lbs / 3 kg with humbuckers?
Discussion in 'Telecaster Discussion Forum' started by HansHR, May 17, 2019 at 7:30 AM.
  1. HansHR
    HansHR TDPRI Member
    Copenhagen
    Hi
    Due to a shoulder injury, I'm really hoping I can find a Telecaster that weighs max 6.6 lbs or 3kg, and also has humbuckers and a string spacing at the saddles of about 2-1/4" or 2-1/5" or 56.5mm.
    Is it possible to find one with these specs?
    (the light models I know of are the American Elite Thinline but it has single coils, and the Squier 72 thinline but its string spacing is too narrow. The Fender 72 thinline has humbuckers and great string spacing but it's too heavy).
    Thanks!
    Hans
  2. hellopike
    hellopike Tele-Afflicted
    Philadelphia
    I’m sure anything is possible, but with such specific prerequisites you’ve narrowed your field down considerably. And you realize that Fender doesn’t categorize or factor in weight at all when producing guitars, right? Each piece of wood is unique, and weights will fluctuate because of it. The best you’ll get is anecdotal information (one owner has a standard that weighs 6lbs, but the next guy has the same and it weighs 8lbs) and common sense answers- ie thinlines are generally lighter than solid bodies...
    At this point, I’d say your options are to hope you luck upon a guitar that meets your specs, or build/have one built. Get a Pauwlonia body, I hear they are pretty light. Or a chambered body.
    Tim S and nojazzhere like this.
  3. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    You will need to have a custom guitar made if you want all of those things. 3kg is unusually light for a guitar - that's about the weight of my hollowbody.
  4. Danzego
    Danzego TDPRI Member
    Sandy, OR
    elihu likes this.
  5. KC
    KC Friend of Leo's
    Missoula, Montana
    my MIM '69 RI weighs in at 6 even. No reason a '72 should weigh more if you find a light one -- but there's a lot of variation from instrument to instrument. Could be a tough search.
  6. HansHR
    HansHR TDPRI Member
    Copenhagen
    Thanks Danzego: Unfortunately, it's got single coil pickups...
    KC: Yeah, I will try to ask about the '72s I can find for sale.
  7. hemingway
    London, UK
    G&L ASAT deluxe is v light, but I'm not sure it's 3kg light.
  8. ejphotos
    ejphotos Tele-Meister
    New Jersey
    Build one. My thinline that I'm putting together is going to be right around 6 pounds when finished.
  9. ppg677
    ppg677 Tele-Meister
    WI
    Route out the cavities to fit humbuckers?
  10. MojoTrwall
    MojoTrwall TDPRI Member
    Paris
    Check out Warmoth avaibility ?
  11. HansHR
    HansHR TDPRI Member
    Copenhagen
    ejphotos - building one sounds intriguing, but I've got no experience doing so, so maybe it's a bit too complicated?
  12. nojazzhere
    Foat Wuth, Texas
    Did you ever play with TinkerToys as a kid?.....same kinda thing.
  13. ejphotos
    New Jersey
    You can always purchase the parts separately based on weight, then if you aren't comfortable putting it all together you can have your luthier do it.
  14. HansHR
    HansHR TDPRI Member
    Copenhagen
    He, ok - that doesn't seem too intimidating. How would one go about something like that?
  15. Danzego
    Sandy, OR
    Oh, sorry! I read your post right when I woke up and missed the humbucker part. Oops! :)
