Any recommendations for Squier CV Tele Custom pickup upgrade for authentic 60s sound?
Discussion in 'Squier Tele Forum' started by Gogogoch, Apr 17, 2019 at 11:53 AM.
  1. Gogogoch
    Gogogoch TDPRI Member
    Hi,
    I'm playing in a 1960s covers band that prides itself on replicating the original recordings (as far as possible) when we play live. However, buying original 60s gear is neither practical or manageable. We play Kinks, Beatles, Manfred Mann, Searchers, etc (so not Hendrix, Clapton, etc.) and I'm using a Classic Vibe Tele Custom.
    Any recommendations for pickup upgrades to replicate a more authentic 60s sound?
    I mostly use the bridge pickup and I'm playing through a Mesa f-50 (I know, that's not a 60s amp.....but, that's another story!)
    Cheers!
    nojazzhere likes this.
  2. fasteddie42
    fasteddie42 Tele-Meister
    Tip of the Mitt
    Isn't the CVC a low output 60's spec pickup?
    Gogogoch and nojazzhere like this.
  3. viking
    viking Friend of Leo's
    Denmark
    Should be..
    What do you want it to do differently ?
    Gogogoch likes this.
  4. The Angle
    The Angle Tele-Meister
    Seattle, WA
    I'd say you'll have less anguish and more success by looking at different amps before swapping pickups.
  5. bgmacaw
    bgmacaw Tele-Afflicted
    Near Athens GA USA
    What amp are you using? That will play a lot bigger role than a pickup swap.
  6. BorderRadio
    Phoenix, AZ
    Those pickups are great, the neck p/u is perfect, I'd play them as is. If you compared them to a AV '64 set, you'd only be changing the bridge a little, and then you have to adjust them and might find it sounds---the same :)
  7. VintageSG
    Yorkshire
    The Classic Vibe Custom stock bridge pickup is great as it is and is so close that you'd be splitting hairs over the differences.
    Hie thee to the nearest Vox stockist and avail oneself an AC30, or go nuts and get a WEM. A cheap alternative may be the Joyo ACTone Vox-in-a-box-not-a-fox-in-socks pedal and run your amp fairly clean, just doing the lifting while the pedal does the tone.
  8. hrstrat57
    hrstrat57 Tele-Afflicted
    Rhode Island
    I thought my CVC nailed 60’s tele tone, especially after I put on a heftier Fender Vintage Bridge plate.....
    Other than the mandatory electro socket mod I thought she was perfecto
    The alpha pots were a wee bit stiff but still worked for volume swells.
    I play thru mostly Vox and Marshall
  9. mimmo
    mimmo Friend of Leo's
    Paris France - Rome Italy
    Before stupidly selling mine, I esquired it and since I wanted a little less highs I out a cavalier fat lion.
    It became one of the best sounding teles I have ever owned. Period.
    But the amp is a big factor also :)
    ftbtx and nojazzhere like this.
  10. nojazzhere
    Foat Wuth, Texas
    I like your material list A LOT.....but those are not what I think of as Telecaster-based bands. I play a lot of "British Invasion" material with my Tele, but I also use a middle pickup and Fender and Vox amps. It's been said here MANY times, but it's gospel truth.....your sound is largely in your hands and playing.
    I've never played through a Mesa amp, but I suspect it's a great amp.....try using your bridge and neck pickups together......I don't really think equipment is your issue here. ;)
    fasteddie42 and Gogogoch like this.
  11. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Lower the pickups, a lot. Turn up the amp/etc.
    For the Hendrix stuff ... his bridge pickup has a reverse angle on it, plus when he played a Strat it's more like a Tele having wide open picking range because the volume knob was not in the way.
    Different music style than you seek, but watch through the first three or four minutes.
    BorderRadio and nojazzhere like this.
  12. Gogogoch
    I'm using a Mesa Boogie F-50. Though there is a Twin at the rehearsal room that I love (loud though). The band's other guitarist uses a Blues Jr.
    VintageSG suggested a Vox ac30. That would be lovely.
  13. Matthias
    Matthias Tele-Afflicted
    Your pickups are probably fine. Vox tube amp, a delay and a decent verb will go a long way. A Fender tube amp next.
    I run a Donner Yellow Fall delay and an Electro Harmonix Holy Grail to get my sixties noises, plus a Joyo Tremolo and AC Tone.
    nojazzhere and Gogogoch like this.
  14. Gogogoch
    Is the AC Tone noisy? My Mesa f-50 sounds great, but it hisses horrible when turned up, so I'd hate to make that worse by putting a noisy pedal in front of it.
    Second question...do you put the AC Tone into the fx loop?
    Lastly, any thoughts on using an AC15? The other guitarist uses a Blues Jr, so I'm guessing 15w might be sufficient, but it needs to stay clean and be able to keep up with a drummer.
    Can anyone school me on Vox amps?
    Is an AC10 sufficient?
    Thanks again for the help.
