Join TDPRI Today
antiquity bridge replacement
Discussion in 'Just Pickups' started by micky!, May 11, 2013.
  1. micky!
    micky! TDPRI Member
    8
    Aug 8, 2011
    Nantes - France
    Hi to all teleholics,
    I am looking for an advice. I would like to replace the bridge pickup of my Navigator:
    The stock pickups are SD Antiquities. I really like the neck PU, but the bridge is way too thin and bright for me. It's like if the PU itself was adding some twang. At the end it's quite caricatural...
    I would like something more fat but not high output. I have a 50 black rope in my telemaster, but it would have a too strong output.
    Any sugestion is welcomed ;)
  2. eat myshorts
    eat myshorts TDPRI Member
    39
    Apr 16, 2013
    VT
    Could lowering the bridge pickup perhaps help? might as well toy with it until someone can offer a better suggestion :cool:
  3. tjalla
    tjalla Friend of Leo's
    I've had the 50s flatpole antiquity - that pickup can indeed be bright.
    You can spend alot of money and not do much better than the Duncan Jerry Donahue - especially if your description is fat but not high output. Another plus is that it will be in-phase with the neck Antiquity.
  5. SPUDCASTER
    SPUDCASTER Friend of Leo's
    2nd the Donohue.
  6. micky!
    micky! TDPRI Member
    8
    Aug 8, 2011
    Nantes - France
    @ eat myshorts: I already lowered the PU, it helps but it's not enough to my hear.
    @ Tjalla & SPUDCASTER: OK I will have a look to Donahue PU, but I am not a huge fan of SD PUs. Moreover they are quite expensive in Europe (89€ at my local dealer)
    I will have holiday i few week in NYC, is there a shop where I can find a lot of PUs?
    I am also wondering if it was not a good opportunity for buying a handwound US set without shipping cost...
  7. In Tune
    In Tune TDPRI Member
    87
    May 27, 2009
    Nevada
    Thanks for posting this! You just answered a question I had, as I just installed a Fender Custom Shop Bridge pickup(got used on the bay) (staggered pole) and it was sounding out of phase with the existing Duncan Antiquity Neck and driving me nuts thinking I'd wired it up wrong...It sounded like a cocked-wah when in the middle position.. The bad news is I like the new brigde Pup and also the neck SD. So I'm out of luck for the Mid position. I did'nt know anything about the phase issue I'd be getting with the pickup install.
    I don't understand why it is NOT in phase with the Duncan..:confused:
  8. uriah1
    uriah1 Doctor of Teleocity Ad Free Member
    Feb 12, 2011
    Around
    Yea, Fender and SD have always done that reverse scheme. Really gets bad
    when you do a strat and have 3diff mfg..
  9. In Tune
    87
    May 27, 2009
    Nevada
    How do you resolve the issue? Can you just switch the Black and White leads/Connections? :confused:
  10. YoGeorge
    YoGeorge Tele-Holic
    933
    Mar 16, 2003
    Michigan
    It is no problem with a strat because you can just flip the wires...
  11. YoGeorge
    YoGeorge Tele-Holic
    933
    Mar 16, 2003
    Michigan
    In theory, you can just switch the leads but tele pickups ground the bottom plate on the bridge pickup and the cover on the neck pickup, so you need to remove the jumper that grounds one of these and flip it to the white wire or run a separate ground wire. Like I said, on a strat there is no issue as the pickups do not have a bottom plate or metal cover.
    George
  12. Dr. Bill
    Dr. Bill Tele-Afflicted
    May 1, 2003
    Upstate, SC
    Well put! That's exactly the problem. It's easier just to buy another pickup that matches polarity.
  13. YoGeorge
    YoGeorge Tele-Holic
    933
    Mar 16, 2003
    Michigan
    No, it takes a wire clipper and a separate piece of wire to ground the cover, which is easier for many people than spending the money to replace a pickup that they otherwise like. I could change the ground in less time than it would take me to drive to a store and buy another pickup....
    It is easier to INITIALLY buy a pickup that you know will match in polarity.
    For what it's worth, I have found Duncan, Rio Grande, and Dimarzio all match in polarity. Fenders are opposite.
    George
  14. In Tune
    87
    May 27, 2009
    Nevada
    Thanks for this info all! I need a bit of help though, can you tell me exactly where I need to run this new ground? Yes, I'm new to pickup installing, but have plenty of wire and solder!
  15. YoGeorge
    YoGeorge Tele-Holic
    933
    Mar 16, 2003
    Michigan
    As with pickups like the Texas Special neck pickup which comes with 3 wires (2 coil wires and a separate wire for the cover ground), you need to clip or unsolder the little jumper that connects the cover or base plate (if the bridge pickup) to the black coil wire. Then you can solder a separate ground wire to either the cover or the base plate, and ground that to the back of one of the pots. Or redo the jumper wire from the cover or plate to join the white wire--but soldering onto the spot where the tiny coil wires join the leads, you can mess up a connection. (And on that pickup, you would solder the black wire to the pickup switch and the white wire to the pot ground.)
    The separate ground wire on the neck pickup would be my preference--and note that it is also essential to have a separate ground wire on the neck pickup if you want to use a 4-way switch. (The Tx Spls are natively designed for the 4 way switch.) Alternatively, a neck pickup without a cover (either a removed cover, something like a Rio Grande Tallboy/Muy Grande, or a strat pickup in the neck) would let you simply reverse the black and white wires at the switch and pot ground and you'd be good right there.
    George
  16. tjalla
    No lie - in the time it took me to read this:
    to come back to this thread and read this:
    ...I had added a ground wire and flipped the leads on my Klein Fatman, so it's now in-phase with the neck Antiquity mini. 500k pots. The combo is most excellent.
  17. Dr. Bill
    May 1, 2003
    Upstate, SC
    You can do that too! :lol:
  18. In Tune
    87
    May 27, 2009
    Nevada
    NOW FIXED!
    UPDATE>>>> Holy Toledo, I pulled this off! It works like a charm, the guitar sounds stellar! The combined sound is the best I've had on this guitar('63 tele), Thanks to all you Kind Sirs for the technical input.
    Next up>> some new compensated Saddles. Im looking at the J.R. Kohler sets.
    And Glendale of course.
  19. micky!
    micky! TDPRI Member
    8
    Aug 8, 2011
    Nantes - France
    Instead of just replacing the bridge pickups, I am more and more thinking about replacing the set.
    The guitar is quite balanced, it has just enough of treble and medium. Just a little extra bass would be welcome.
    I would like a set balanced, that let woods sing. It would be for blues /rock sounds (let say clean sound to JCM800 overdrive). I am lot not looking for extra twang, and I am not a big fan of country music.
    I was looking at Lollar Special T or Fralin stock , but I do not know if it could feets.
  20. Dr. Bill
    May 1, 2003
    Upstate, SC
    I thought you said that the bridge pickup is "way too thin and bright." As I read your first post again I'm thinking that the SD Broadcaster might be just the ticket. Should play well with the Antiquity in the neck.
  21. micky!
    micky! TDPRI Member
    8
    Aug 8, 2011
    Nantes - France
    Yes I appreciate Broadcaster like PU, I already have my telemaster equipped with 1950 Black-Rope, which are Broadcaster PU.
    My idea with the navigator is to have a less ballsy Tele. So I do not know how sounds the SD Broadcaster, but I do not want both of my tele sound the same.
