Andre's CNC
Discussion in 'The DIY Tool Shed' started by BluesBlooded, May 13, 2015.
  1. BluesBlooded
    BluesBlooded Friend of Leo's
  2. GunsOfBrixton
    GunsOfBrixton Tele-Afflicted
    Dec 9, 2011
    Rochester, NY
    Basically. and the shaft goes through a bearing which provides support
    BluesBlooded likes this.
  3. GunsOfBrixton
    Dec 9, 2011
    Rochester, NY
  4. GunsOfBrixton
    Dec 9, 2011
    Rochester, NY
  5. BluesBlooded
    you are right, the best solution is finlelineautomation. If I cannot get ahold of them, I'll make my on with a rod. This will be the closest to the original setup
    Thanks I will check for that term as well
  6. sergiomajluf
    sergiomajluf Tele-Meister
    401
    Sep 26, 2015
    Santiago, Chile
    I would call it deep maintenance that wouldnt have done otherwise :)
  7. nickhofen
    nickhofen Friend of Leo's
    Or find someone who do aluminium casting!
    Rick do you know anyone ?:D
    BluesBlooded and R. Stratenstein like this.
  8. nickhofen
    Yeap just see it...sorry guys I had the kids jumping in my head when I was posting that message and did check clearly.
  9. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    Well, as a matter of fact . . . .
    But the runout is more likely to be 1/6 of an inch rather than 1/16 of an inch! And Andre would be too old to use a CNC by the time I got a decent casting pattern made, then poured the metal! :eek:
  10. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    Do you have a drill press vise? What about if you used a 1/2" drill bit in your drill press to open up the female end of the adapter to the right size, and then shimmed the rod end of the adapter to fill into a 1/2" hole?
  11. BluesBlooded
    Sergio, it was long overdue. It was not a bad exercise and one that should do more often. Does not need to wait until it goes bad.
    I kind of remember some video with an old guy melting some beer can. I would have to dig it up.
    No worries, it is a great idea.
    :D
    That is a great idea Rick, thanks. I have a drill press vise and an 1/2" bit. I think you solved my problem. :)
    How hard is stainless steel to drill?
  12. GunsOfBrixton
    Dec 9, 2011
    Rochester, NY
    Andre,
    I looked but I don't have (or couldn't find) an extra shaft coupler. Keep trying to get a hold of Nate at fineline.
  13. BluesBlooded
    Thanks Robert for looking, I appreciate it.
    I've ordered the 12mm shaft coupler from amazon, but it will take a few weeks before it gets here. If I hear form Nate, I will order one as well.
  14. GunsOfBrixton
    Dec 9, 2011
    Rochester, NY
    Andre, what issue were you having ordering on the fineline site? I had no problem getting up to the payment page.
  15. BluesBlooded
    I am getting 500 oops error all the time. I've tried with Firefox, IE, on two separate Windows 10 machine, Chrome and Safari on macbook.
    Maybe he fixed it, I will check it again
  16. BluesBlooded
    Nope still the same issue. Of course, I'm putting Canada to get a shipping quote. Maybe that's where the problem lies.
  17. GunsOfBrixton
    Dec 9, 2011
    Rochester, NY
    Want me to order one (or 2) for you then ship them to you from my place?
  18. BluesBlooded
    Thanks Robert, very kind offer. I will wait and see if he comes back to me or if the other coupler I ordered does the job.
    I'll keep your offer in mind and if I decide to go this way will contact you.:)
    GunsOfBrixton likes this.
  19. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    OOH, that may be the rub. Stainless steel is VERY hard, period. You'd need a high quality drill bit, be sure to clamp your drill press vise securely to the table, and I'd keep it flooded with WD-40 or cutting/drilling oil, if you have any. I did not realize it was stainless steel, all the previous talk about aluminum. On the plus side, you'd only be removing a small amount of material, so hopefully, it won't be too hard of a time for you.
  20. BluesBlooded
    I do have cutting oil and a good drill bit.
    The funny thing is today is the city annual garage sale event. So I went around trying to score some rods of the proper side. Did not find any.
    But then a brief moment of clarity hit me. I remembered I had some aluminum shafts somewhere.
    Went to dig and found these
    The larger one are 1 inch and the longer one is 3/4 in.
    Tomorrow, I will try to build myself a shaft coupler.
    RollingBender likes this.
