Amp simulator pedal with a combo amp. In front, or effects loop?
Discussion in 'The Stomp Box' started by Bluego1, Apr 20, 2019.
  1. Bluego1
    Bluego1 Tele-Meister
    So I recently received a Joyo American Sound amp sim pedal and I put it between the guitar and the front of the amp. It sounded pretty cool. Like using a regular pedal, eq knobs on the pedal changed the sound as did the amp eq controls. I’d read about hooking the pedal straight into the return jack of the effects loop. In other words. Guitar-pedal-return jack. So I tried it and had my amp volume controls all the way off and that sucker made a hella noise anyway when I engaged it. Ended up loving it, but was surprised that the amp controls were rendered useless. Everything was controlled by the pedal and the guitar. I’m a newbie to these amp simulator boxes and I’m not the brightest bulb in the room anyway. Does what I described sound right?
    tele-bastard likes this.
  2. galaxiex
    galaxiex Tele-Holic Silver Supporter
    Edmonton, Alberta Canada
    Yes, the return jack on your amp goes to the power amp section of your amp.
    The pre-amp in your amp is where all the tone and volume controls are,
    so basically, the return jack by-passes the tone controls.
    perttime, JustABluesGuy and Bluego1 like this.
  3. JustABluesGuy
    JustABluesGuy Friend of Leo's
    Houston, TX
    ^^^ This. It can also be used in place of your amp, direct to the PA.
    galaxiex, tele-bastard and Bluego1 like this.
  4. tele-bastard
    tele-bastard Friend of Leo's
    Lowell, Mass
    It's a great pedal I always put it in front of my amp even though some people say it's the wrong way you can use it either way... definitely one of my favorite pedals if not favorite FB_IMG_1555766437947.jpg
    galaxiex and Bluego1 like this.
  5. perttime
    perttime Tele-Afflicted
    Finland
    Whichever way works for you is right.
    There's preamp pedals that let you do both, with some extra cables and switching wizardry.
    Bluego1 likes this.
  6. wulfenganck
    wulfenganck Tele-Holic
    Seligenstadt, Germany
    This variety of uses is really the big advantage of the Joyo's (or the original design: Tech21 character series), they work like a common dirtpedal in front of the amp, directly to mixing-desk or as a separate preamp. Tried the latter as well with a small loop-switcher with my AC Tone and the Tech21 Blonde. I have a different pedalboard now, but I still use the Joyo from time to time on a session board.
    Bluego1 likes this.
  7. perttime
    Finland
    Yep. Some amps might have a Master Volume, and/or some other control, after the effects return. Depends on what amp you have.
    Plugging the pedal into the Return jack bypasses your amp's preamp section. You are using the pedal preamp instead of the amp's preamp.
    Bluego1 likes this.
