Amp impedance question (Mesa studio 22)
Discussion in 'Amp Central Station' started by architele, Jun 16, 2019.
  1. architele
    architele Tele-Meister
    lewiston/auburn, maine
    816B5408-C287-446A-A684-B443A880E5EE.jpeg Help! My mesa studio 22 has a 4 ohm jack and an 8 ohm Jack. The internal speaker is 8 ohms, and I have an external cab with one 8 ohm speaker. How should I do this? Plug main into 8 ohm, external into 4? vice versa? Or find a way to plug into the 4 ohm with some kind of y speaker cable, if such a thing exists?
  2. Frodebro
    Seattle
    The manual isn't really clear, it says to use the 4 ohm jack if adding an extension speaker. What is confusing about this is that typically the output jacks are wired directly to the transformer taps, and it's bad to simultaneously use jacks for different impedances in that manner. However, Mesa may have used a switching jack that converts both jacks to 4 ohm when the labelled 4 ohm jack is used, meaning one 8 ohm speaker (or cab) in each jack. I would call Mesa directly and confirm things with them before trying anything, just to be safe. They're great about helping with stuff like this.
    architele likes this.
  3. architele
    Thanks Frodebro - great suggestion.
    Frodebro likes this.
  4. clintj
    clintj Friend of Leo's
    Idaho
    That's curious. I had a Studio 22 in for work last year, and it had three speaker jacks - a single 8 ohm, and two 4 ohm. What are yours labeled?
    Sent from my Pixel 2 using Tapatalk
  5. uriah1
    uriah1 Doctor of Teleocity Ad Free Member
    Around
    I had the 22caliber ver. Boogie said
    it felt confident on some mismatches but
    the tubes may not go as long.. fyi
    Wally likes this.
  6. architele
    I wish my external cab had two jacks as you show but it just has a single input jack
    uriah1 likes this.
  7. architele
    I think you had the studio 22+. Mine is plain old studio 22
  8. clintj
    Idaho
    You're right. I dug through my repair picture archive to find it, and it was a 22+.
    Someone handy with a soldering iron could make you a parallel "Y" adapter using speaker cable. Then, you could run both in parallel from the 4 ohm jack. Most of those splitters I've seen are 22 or 24ga instrument cable.
    Wally likes this.
  9. Wally
  10. Rowdyman
    Rowdyman Tele-Meister
    Eastern Canada
    Mesa's wording on this situation has always been confusing.
    The best way to be sure is to wire the two, 8 ohm speakers in parallel and run them from the 4 ohm jack.
    That's what I do, anyway.. Good Luck! RM
  11. hamerfan
    hamerfan TDPRI Member
    Germany, Bavaria
    Not that hard to convert a studio 22 to a plus - just change a resistor to a pot and resistor. I did that 20 years ago with a friend's amp.
  12. TelePunkJCM
    TelePunkJCM Tele-Meister
    US
    The point of the .22 is a gig worthy, small, lightweight, portable amp that does clean and overdriven.
    Why plug it into an extension cab ?
  13. Silverface
    Lawndale CA
    That's the point to *you* - but others look at amps like that as a mid-powered amp that's easily overdriven for club work.
    But adding an extension speaker can be very useful -
    I do it with similar amps to get better dispersion in a larger club (if not mic'd), for better sound balance on the stage, or to be heard by players across a large stage.
    IT has nothing to do with small. light, clean or overdriven. it has to do with sound balance or helping control band "tightness".
    Wally likes this.
  14. Wally
    I hav not made a comparative study of the two amps, but there is one big difference between the two models. The OT in the schematic app shows two independent taps that cannot be used at the same number ime. The Plus model schematic shows an OT that has three jacks which in a somewhat standard Boogie fashion allows for a single 8 ohm load in one jack or an option of running two 8 ohm loads through the other two jacks which work on a 4 ohm tap....while not using the 8 ohm tap’s jack.
    https://el34world.com/charts/Schematics/files/Mesa_boogie/Boogie_22calplus.pdf
    So, the plus model allows for a simple route for running two cabs at one time.
  15. architele
    Is that as simple as it sounds? A
    Without getting into a long response, I’m a gigging musician who does a lot of Fill-in work, And the extra oomph can come in handy sometimes. I. E. The studio 22 comes in to the gig, and if I realize halfway through that I need at the small extension cabinet is waiting in the trunk of the car
    TelePunkJCM likes this.
  16. architele
    Would this work? I’ve taken a speaker harness with a female end and plugged in to the open tabs on the 8 ohm internal speaker, which is plugged into the 4ohm output from the amp. Then, making sure +s and -s are coordinated, a speaker cable runs from the female end to the speaker input on the external cab, which also contains an 8 ohm speaker. No comments on the technology here - please, I know it’s Rube Goldberg as shown, and I obviously wouldn’t play gigs with wires hanging loose like this, but in principle would this wiring do the trick? If so I can put together a more permanent version EC568885-9150-4D43-889A-FE0E5611014C.jpeg
    Wally likes this.
  17. architele
    By the way I appreciate everyone’s patience. As you can see I clearly have no aspirations to being an amp tech. I just need help figuring this out from people much smarter than me regarding this stuff.
  18. Wally
    That works, archtele.
  19. architele
    Thanks so much Wally.
  20. Wally
