Amp feeds uncontrollable
Discussion in 'Amp Central Station' started by DucDone, Jun 12, 2018.
  1. DucDone
    DucDone TDPRI Member
    65
    Apr 9, 2011
    Bergen
    No, the build is not ok, I have gone over it many times, I have also checked the voltages and they are, maybe a bit high, but within limits. I suspect that there might be some issues withe the trafos to close or the leads not going in the best ways, so I'll go through that now.
    But thanks, much appreciated...
  2. Wally
    Pictures might help someone to espy a problem????
  3. dan40
    dan40 Tele-Afflicted Silver Supporter
    Aug 19, 2015
    Richmond Va
    Do you have the bypass capacitor that goes over the power tube cathode resistor installed correctly...negative end to ground? Be sure that this one and all others in the preamp are correct.
  4. DucDone
    65
    Apr 9, 2011
    Bergen
    Hi, just letting you know I found the problem. I changed the volumepot and resoldered a capacitor on the board. Works fine now, barely audible that it's on. Thanks for all help.
  5. corliss1
    Sep 13, 2008
    Lansing, MI
    Glad you were able to track it down!
  6. Silverface
    Mar 2, 2003
    Lawndale CA
    Glad you got it working, but for future reference -
    You should have STOPPED right here. Nothing else should have been checked until you did a complete voltage chart an d everything was within tolerance. You were confusing yourself and everyone else trying to do other things when one basic voltage measurement was *zero*.
    You posted this after saying the cathode read zero - so what changed, and what was the NEW reading, and how did it compare to the specified voltage?
    It sounds like it's not working fine. What is "barely audible"? If you still have hum is it constant no matter where the volume control is set; is it the same with and without an instrument plugged in? Have you changed cables (and guitars) to compare the difference?
    My point is this - you got the amp working but don't really know why/how if you randomly resoldered "a capacitor" - and why did you change the volume control? You will likely continue to have problems with this and any other amps you work on until you understand the *why* and *how* of what got this one working.
    If you do know the specifics it would be helpful if you posted them. Then others can learn from the problem. As-is nobody has any idea what actually happened.
    twr102 likes this.
