Affinity Squire Tele Pick Ups Update
Discussion in 'Squier Tele Forum' started by telcarl, May 21, 2018.
  1. telcarl
    telcarl TDPRI Member
    4
    May 21, 2018
    Denver CO
    I have a 2017 Affinity Squire Telecaster with the stock (production) neck and bridge pick ups. Removing the pick guard, I can see that both pick ups have a white and black wire. I purchased a set of Dimarzio Twang King pick ups (neck and bridge) and they too have a white and black wire. I am thinking that the installation of the Twang Kings would be to simply remove the stock pick ups and wire in the Twang Kings to the same black and white wires, correct?
    Also, I have read and watched You Tube videos on the orange capacitor upgrade. Although this is a simple mod, I have not heard that there is any noticeable difference that anyone could recognize? Your thoughts?
    Many Thanks
  2. Solszewski1963
    Solszewski1963 TDPRI Member
    6
    Apr 21, 2018
    Missoula MT
    Hi Telcarl. I have a 2018 Affinity that I love. The stock electronics are more than decent, and the orange capacitor upgrade will help get that hot country quack. It is an easy mod, but you'll need to do some simple soldering. I definitely hear the difference between orange and not orange. I usually do my own mods, but for my new, incredibly orange Affinity, I ordered the vintage Tele harness from Stewmac - better pots, switches, capacitors- including the orange cap. it's easy to install, and sounds great. Disclaimer: I have no relationship with StewMac, other than being a satisfied customer.
    RE: Twang King installation - Yes, you just have to wire the Twang Kings to the same solder points as your original pickup. I hope that this helps.
  3. 24 track
    24 track Poster Extraordinaire Silver Supporter
    Nov 6, 2014
    kamloops bc
    my 2017 affinity , I loved the pickups but the wiring , pots and switch were very cheap, I replaced the wiring with shielded pull back wire and the pots with CTS pots and a real fender switch , the tone cap is called a chicklet ( for obvious reasons) I did replace mine with an Orange drop , the sound of the guitar did not change but I have the piece of mind that the parts wont fail prematurely or wear out sooner than not, the only other thing to consider is a good switchcraft jack.
    parts list for this kind of mod:
    CTS pots 250K ( X2)
    Switchcraft jack
    .022 Uf orange drop cap
    Fender stock 3 way switch
    cloth covered shielded pull back wire ( fender stock wire)
    you should be able to get these at any major music store that sells fender as well as Stewmac
    wiring is straight forward
