Advice to upgrade Squier Bullet FSR Tele
Discussion in 'Squier Tele Forum' started by jgmouton, May 11, 2018.
  1. jgmouton
    jgmouton Tele-Meister
    439
    Jun 21, 2009
    Europe
    Hi,
    I've just ordered this guitar (https://goo.gl/DU98qf) and plan to upgrade it. Here are my ideas:
    - Change the pickups for Fender CS 51 Nocaster pickups.
    - Change the 3-position control plate but don't know what to choose.
    - Change the tuners for Fender locking tuners (but will the guitar remain balanced?)
    - Change the bridge for a modern bridge.
    What do you think? I'd like to have a modern, versatile Tele to play blues/rock/country music. Thank you for your ideas and comments.
    Cheers
  2. CK Dexter Haven
    Jun 7, 2017
    GCDB
    I would play it before doing anything, I have the BSB and it's surprisingly good, the most obvious cost cutting measure is the neck; the finish is the "barely there" satin, and it feels somewhat unfinished. Some folks have reported rough frets, the rosewood may be better in this regard, but If you are gong to put money in, a thorough dressing and leveling might be the place to start,
    The pick ups are very good, the bridge is nice and spanky, and not overly bright, rolling down the tone actually works and has noticeable results, the neck is great, very jazzy w/o being muddy. Would No-casters be better? depends on many things, they might be 'different" and more to your liking, but the stock set is very usable. Before I sprung for new ones I would be thinking "for $100 more I could get a new neck..
    Not sure what you mean by the control plate? The stock unit is very nice, sturdy, w/ even chrome; the switch is perhaps a weak spot, but doesen't cry out for immediate replacement, nor do the pots.
    Tuners are fine, if you prefer lockers, you will of course need to change them, have never had them on a Tele, so can't comment on neck dive.
    Not sure what you mean by "modern bridge", the bridge is a modern 6 saddle design, I suppose it might be worth while to up grade the saddles to a compressed or composite material. This is somewhat in the back of my mind "to do"
    jemiba, tele-bastard and jgmouton like this.
  3. CK Dexter Haven
    Jun 7, 2017
    GCDB
    Oh and if you are going to gig it regulary I would consider an "Electrosocket" I haven't had trouble w/ mine but the stock jack cup is a long time problem area.
    Chuckster and jgmouton like this.
  4. jgmouton
    439
    Jun 21, 2009
    Europe
    Thank you CK Dexter, good ideas. Sure I will first try it to see what needs to be done. If the nut has problems I also may replace it with a bone nut although I don't know the impact on the sound.
  5. jgmouton
    439
    Jun 21, 2009
    Europe
    Any other ideas?
  6. Ira7
    Ira7 Poster Extraordinaire
    Jan 8, 2008
    Coral Springs, FL
    I have locking. Do that last, if you still feel the desire. They don't hold tune any better; they just make string changes easier.
    The first mod I would do is a 4-way switch, so you can run both pups in series. Just a few bucks/pounds/euros and an easy mod, but what an option.
    That 4th position makes it sound like a totally different guitar, like a powerful humbucker.
  7. nicod98
    nicod98 Tele-Afflicted
    Jul 7, 2014
    Belgium
    +1 on the 4-way switch
    +1 on the play it first, mod later, it might not need an upgrade
    +1 on fretwork and setup (or did nobody mention this yet?), unless it is OK (depends on specific guitar and local humidty situation I suppose)
  8. mbell75
    mbell75 Tele-Meister
    304
    Mar 21, 2014
    california
    I bought a used one from a shop that had upgraded the electronics, smoothed out the fret edges and polished them up and gave it a pro setup. Sounds and plays great IMO.
  9. jvin248
    jvin248 Poster Extraordinaire
    Apr 18, 2014
    Near Detroit, MI
    +1 play it first
    +1 fret level (it's $100 most places where fifty of that is the setup so the extra is a super value as the guitar will play like one ten times the price afterward).
    +1 leave the pickups (don't be afraid of ceramic)
    Bourns volume pot (you can leave the tone or swap that too), Oak-Grigsby 4-way switch, Switchcraft jack. If you need to tweak your guitar's tone, measure pots and caps and find differently measured value ones to swap. A tenth the cost of pickup swaps.
    A 'Bubba Mod' to install three traditional brass saddles can get you the vintage look.
    Always 'tune up' your guitar and you won't need locking tuners. if you re-string by anchoring the ball end at the bridge, bring the string up and wrap 3-4 times around the tuner post to thread the cross-hole and pull that tight, you'll only have a few turns machine head turns to get up to tension. Any tuning issues I've ever seen are the nut unless someone dropped the guitar and broke/bent a tuning machine.
    tfarny likes this.
  10. jgmouton
    439
    Jun 21, 2009
    Europe
    Thank you all for your advice. Will keep you informed here when I have the guitar.
  11. jgmouton
    439
    Jun 21, 2009
    Europe
    Update: I've just received the guitar. It is surprisingly light, which I like. The sound of the pickups is good although a bit on the trebley side. I'm not sure at this stage I want to change them.
    The neck is comfortable but I need to have it checked by my luthier. I lowered the strings to the height I like but they buzzes too much and when I bend the E and B strings the sound stops. I'm not sure about the cause but the luthier will know.
    The whole aspect of the guitar is rather pleasant and feels solid. The volume knob is slightly higher than the tone knob to the control plate. I was surprised that the truss rod was not very hard to turn when I straighten the neck, I was expecting more effort.
    I will keep you updated after I see my luthier...
  12. hrstrat57
    hrstrat57 Tele-Afflicted
    Nov 21, 2016
    Rhode Island
    You’ll be shocked at how good it sounds, plays and stays in tune.
    Bag the body and steel wool back of neck, wipe and then scotchbright to finish. Doesn’t change appearance and changes playability completely. Change jack to Allparts or stewmac electrosocket.
    That seriously might be enough.
    For new control plate suggest a high end rig for endless 5 minute pickup swaps. Kelling Sound, obsidian wire are 2 quality eBayers and there is also a British seller that doesn’t come right to mind.
    Have fun!
    Chuckster likes this.
  13. jgmouton
    439
    Jun 21, 2009
    Europe
    I'm back from the luthier and he adjusted the neck (re-seated it and adjusted the truss rod) and the bridge. I do not have any more problems now with strings chocking out during bends. It's very comfortable to play and I like better than my Baja (satin neck, lighter). My luthier was surprised by the good overall quality.
    Only the pickups do not sound as good as the ones in my Baja but I think they are surprisingly good for the price. I might change them later with the control plate when I have the budget. This Squier is now my number one and I'll play it at the next gig :)
    Mat likes this.
  14. littlebadboy
    littlebadboy Tele-Afflicted
    Jun 25, 2016
    Midwest, USA
    I agree on playing the heck out of it first and then upgrade as needed to make it your own.
    I have a Squire CV bsb. It was good with everything stock! But it couldn't do what I wanted since I play hard rock/metal. So, I changed the pickups to a rail humbucker on bridge, overwound on neck, electronics to 500k vol pot and no load 250k tone pot. It does what I want now! It's a hard rawkin grampa tele now! I still kept the original pickups in case I want to put it back on in the future.
    By the way, Guitar Madness has great affordable pickups and other parts! Knowledgeable seller too!
    https://ebay.com/usr/guitarmadnessguitarmadness
    jgmouton likes this.
  15. whoanelly15
    whoanelly15 Tele-Meister
    430
    Aug 30, 2017
    Congrats! Glad you're enjoying it. Time for pics though, now. Please and thank you.
  16. jgmouton
    439
    Jun 21, 2009
    Europe
    Yes you're right, time for pics :)
    Chuckster and VintageGearMan like this.
  17. whoanelly15
    430
    Aug 30, 2017
    Awesome! That surf green with rosewood color combo is so slick.
  18. archetype
    archetype Fiend of Leo's Silver Supporter
    Jun 4, 2005
    Williamsville NY
    Absolutely right on the 4-way switch, but measure the switch and body cavity depth, first. It may not fit without bending the solder lugs to the side.
  19. tele-bastard
    tele-bastard Friend of Leo's
    Mar 27, 2011
    Lowell, Mass
    I had the surf green model for a little bit unfortunately lost it in a Craigslist deal I raise the neck pick up a little bit and the pickups were pretty responsive was it decent guitar for the money
  20. jgmouton
    439
    Jun 21, 2009
    Europe
    Update again: I played many gigs with it already and there are only 2 things that bother me:
    - The tuners are OK but I have to retune the guitar much more often than with my Baja. They are not accurate enough. Do you know any drop-in replacement tuners?
    - The jack socket keeps getting loose and I have to re-tighten it regularly. Not a big deal but what replacement part would you recommend?
    Thanks a lot for your advice.
    Slim Chance and Chuckster like this.
