Acoustic build
Discussion in 'Tele Home Depot' started by printer2, Apr 10, 2013.
  1. orangedrop
    orangedrop Friend of Leo's
    New York
    You can do an awful lot with a Drem-mill:D
    A decent cross slide table, a few hold downs and some creativity on the jig thang will get any one set up for cooking up nifty wood parts that are highly accurate.
    That bridge is cool looking...
    With the flowing contours, it reminds me a bit of a licorice gumdrop.:lol:
  2. printer2
    Just inspiration, I like the look but doubt I would try a copy.
    Now for some of the good, the bad, the ugly. Spent some time on the guitar today. You know when things do not go right they can really go wrong. Last time I bolted on the neck the fretboard was a little high off the top. Tried adjusting it, shaving the neck joint, it just was not cooperating. Also noticed the neck is now angled so a straightedge ends up well above the bridge. When I put in the bolts they did give me trouble, maybe I have to open up one of the holes. Took a bit slightly bigger than the hole in the neck block and proceeded to drill. Knew I should have used the Dremel.
    Well if the couple years where I tried my hand at flying RC models taught me anything it was how to fix things. Patched it up and nobody would know the better. Still ending up high on the bridge, chalk it up to this being my first ashtray in pottery class. Won't be perfect but might be playable. If not I can always take the bridge off and put a thicker one on, this one was a little thin anyway.
    Speaking of the bridge, should have shaped it while it was off the guitar. Thought I could just tape off the top with duct tape and it would protect from any slips of the file I used to shape it. Boy cedar is soft. A few more dents to add to the other ones. My version of relicing a guitar.
    Onward and upward I determined where the bridge pins should be and drilled the holes. Of course I do not have a 3 degree reamer for the pin holes, so what else could I do but make my own. I took some 1/16" steel, drew a 6" triangle on it with a 3 degree taper, cut it out and sanded it on the belt sander to the right shape. More of a scraper than a cutting tool but worked fine.
    Cleaned it up some and gave it a swipe of the wipe on poly. Wish I knew where my bridge pins are, will have to pick some up tomorrow.
  3. Glen Smith
    Glen Smith RIP
    The positive side is that you are gaining invaluable experience at problem solving. That doesn't happen when you don't have any problems.
  4. orangedrop
    New York
    you can say that again!:lol:
    When shaping the bridge you could use what we used to call a "Cheater", which was a good sized piece of thin sacrificial scrap with a hole for the object to be worked to poke through.
    I vaguely recall Ron Kirn writing that he uses dampened paper to place between the guitar and a template to avoid scratches.
    So maybe a little distilled water on a piece of acid free paper, drop this on the top, a slice of 1/16" masonite with a cutout for the bridge?
    I dig your tapered scrapered:cool:
    Did you chamfer the edges into a parallelogram cross section to create cutting edges?
  5. printer2
    Next time just shape the bridge before it gets glued on.
    The profile of the reamer is square, not like you need much of an edge to remove wood, it just takes a little more force.
  6. guitarbuilder
    The bridge looks very nice!
  7. printer2
    Thanks, turned out better than I hoped.
    Now for my Charley Brown Christmas tree. Quick, take a picture before it implodes.
  8. Glen Smith
    Glen Smith RIP
    Hey, it looks great in spite of the hiccups.
  9. guitarbuilder
    Excellent!
  10. Bentley
    Bentley Friend of Leo's
    Kelowna B.C, Canada
    Wow, one of the most beautiful and elegant acoustic guitar I've seen. Stunning job.
  11. printer2
    Thanks guys. Just happy it is done, warts and all. I rushed it and screwed up the fit and finish because I have some things coming up in the New Year. I knew if I did not finish it this week it may sit for a long time an it was worth it to me to have it to play.
  12. printer2
  13. Glen Smith
    Glen Smith RIP
    Hey, it sounds like a geetar !
  14. crazydave911
    East Tennessee
    Sounds promising! :D
  15. guitarbuilder
    Very nice. I'll bet the video doesn't do it justice and commend you for an anti-norm build. It warms my heart!
  16. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Long Island NY
    Nice , looks good , sounds good :)
  17. printer2
    Thanks all of you, you helped me get through it. When I started this a bunch of acoustic builders did not think it was a good idea given the woods involved and that I should buy a real guitar set. Heck, up until I strung it up I didn't know if I spent half a year building a wall hanger. In the end it sounds like, well a guitar. Nothing really jumps out at you as wrong tone wise, heard cedar top guitars might be more suited to finger picking rather than strumming but this one doesn't care.
    I still have to take down the nut and saddle to make it more playable, haven't even touched the truss rod or given it a fret job. Wonder if I could have gotten away without a truss rod, the neck has enough meat to it. It would be interesting to make a stripped down quickie build with one of the other sets I have. The niece's husband was wondering if I was going to make another on. He said he liked it.
  18. Engraver-60
    Engraver-60 Friend of Leo's
    Brentwood, TN
    Nice kind of Taylor-esque sound. Great accomplishment.
  19. Big tuna
    Big tuna Tele-Holic
    east side
    man I think it looks and sounds great! nice work.
  20. orangedrop
    New York
    the bottom end is quite good for the small body and I think it sounds snappy.
    Would love to hear a really good recording of it.
    Did you have any concern about inducing "crappy" overtones into the camera body by placing it on a stool?:D
