Join TDPRI Today
Acetone on finish blemishes
Discussion in 'Finely Finished' started by mcohenmcohen, Jul 6, 2013.
  1. mcohenmcohen
    mcohenmcohen TDPRI Member
    8
    Oct 27, 2009
    san francsisco
    In the process of trying to remove the sticker gum left from the pick guard plastic, I had the idea that some acetone nail polish remover would get rid of it. It sure did, along with some of the lacquer on the paint of the body surrounding it. Now I've got streaks of creamy, foggy matte in place of the shiny transparency of the wood beneath. Ugh. What can I do??
    Thanks much!
  2. piece of ash
    piece of ash Friend of Leo's
    Dec 29, 2010
    Sugar Land, TX
    Your finish is likely still OK.
    1) In the future, make acetone your last resort to cleaning anything. Mineral spirits, or lighter fluid is a better starting point... that assuming water and soap won't cut it.
    2) You simply need to polish the surface to restore the gloss, and the clarity will return. Get some automotive rubbing/polishing compound (not wax) start rubbing with a COTTON towel. I'll bet you can even get there with toothpaste. Toothpaste usually contains some mild grit.
  3. mcohenmcohen
    8
    Oct 27, 2009
    san francsisco
    Thanks much, I will give those a shot.
