Join TDPRI Today
Accurate Instrument Tube Tester Model 157 Manual and Vacuum Tube Substitution Guide
Discussion in 'Amp Central Station' started by Thundersleet, Oct 18, 2011.
  1. Thundersleet
    Thundersleet Tele-Afflicted
    Jan 29, 2009
    Wisconsin
    I have uploaded these files to a new location. They will no longer be available on the rapidshare account I had uploaded them to previously.
    By the way if you test with this tester don't throw tubes out because they seem like they test low. New Sovtek EL84 and 12AX7 tubes only go to around 70 on mine. This is the same as NOS tubes that I have bought.
    Manual for Accurate Instrument Tube Tester Model 157. This includes the June 68 Supplement Chart.
    Accurate_Instrument_Tube_Tester_Model_157_Manual.pdf - 39.1 Mb
    Accurate Instrument Model 157 Supplement Chart June 68, this file is the supplement chart only.
    Accurate_Instrument_Model_157_Supplement_Chart_June_68_.pdf - 2.6 Mb
    This is a handy Vacuum Tube Substitution Guide.
    Vacuum_Tube_Substitution_Guide.pdf - 3.0 Mb
    This is the manual for Schumacher E-Z MIG and 105 Turbo MIG FLUX WIRE FEED WELDERS MODELS 90775 90778 90779. I'll include this link because it's not available from Schumacher anymore and to safely use a welder you should have the manual.
    Schumacher_E-Z_MIG_and_105_Turbo_MIG_FLUX_WIRE_FEED_WELDERS_MODELS_90775_90778_90779_MANUAL.pdf - 12.7 Mb
    These files seem to be useful to people. Here's the download count from rapidshare since February 2nd, 2011.
    Model 157 Tube Tester Manual 142
    Supplement Chart 60
    Vacuum Tube Substitution Guide 23
    Schumacher Welder Manual 84
  2. Thundersleet
    Jan 29, 2009
    Wisconsin
    Updated File Locations
    I have uploaded these files to a new location. They will no longer be available on the rapidshare.com or oron.com account I had uploaded them to previously.
    Here's the download count from oron since October 18, 2011.
    Model 157 Tube Tester Manual 11
    Supplement Chart 6
    Vacuum Tube Substitution Guide 7
    Schumacher Welder Manual 3
