A question about my Peavey Delta Blues 210
Discussion in 'Amp Central Station' started by fndrman, Mar 14, 2019.
  1. fndrman
    fndrman TDPRI Member
    Alberta, Canada
    Recently I bought a used Peavey Delta Blues 210. This thing is supposed to be a killer blues amp, but whenever I plug in my Tele or Epiphone Swingster (equipped with Gretsch style filtertrons) I can't get the clarity that I usually get with my HR Deluxe. Would a re-tube solve that? Or do those amps usually sound muddier than Fenders? Thanks.
  2. Musekatcher
    Musekatcher Tele-Afflicted
    meridianam altum centralis
    A few ideas: Small room? Double coils? Playing at low volumes? Forgot to bring the bass down, and the treble and mids up? Used to icepick, and now everything else sounds muddy?
  3. fndrman
    Alberta, Canada
    Well, I tried them side by side with pretty much the same settings. Maybe the DB just needs to be cranked a little more.....just maybe.
  4. Durtdog
    Durtdog Poster Extraordinaire
    Tennessee
    I've owned a Delta Blues and a Classic 30. In my experience, new tubes make a world of difference in these amps. Really woke them up.
    fndrman likes this.
  5. Mexitele Blues
    Mexitele Blues Tele-Meister
    Westminster, CO
    With my tele I have the bass at 11:00 and mids & highs at 2:00. Plenty of clarity. How is your's set?
    lineboat and fndrman like this.
  6. Henry Mars
    Henry Mars Tele-Holic
    Bucks Co. PA
    You might want to look at the speakers. A speaker change will greatly alter the character of this amp.
    Pre-amp tubes will influence it a bit as will pwr tubes. Tubes will make a difference initially ... after around 100 hrs you will notice little or no difference between different pwr tubes unless you find some top of the line NOS 6bq5's they tend to sound "new" longer at least in my experience. Be careful not all modern amps are compatible with NOS 6bq5 types. How beat up are the tubes? In my experience modern EL84's don't hold up well if you push them hard ... like most of us do.
    I would try a different set of speakers. and re tube it. This is a very good amp all by it's self. There are tendencies to compare it with similar Fenders which it ain't. So if you are expecting Fender buy a Fender.
    PU's of course are a big factor. Some amps don't like some PU's but that is something you find out when you test drive the amp. Which is one of the reasons I only buy an amp after a test drive with the axe I am going to use.
    Good luck.
    fndrman likes this.
  7. schmee
    schmee Friend of Leo's
    There's a big difference between 6L6's and EL84's. The HRD is a loud amp too. I think you may find your zone , but the settings may be quite different between the amps. If you are used to playing the HRD fairly loud, the DB may never get you there. Mine wouldn't get me there in a 5 piece blues band with 2 guitars. Today it would though I'm sure, but we were pretty loud 12 years ago.
    fndrman likes this.
  8. Chester Burnett
    Chester Burnett Tele-Meister Ad Free Member
    Palm Springs CA
    It's not a Fender and you can't set it on the same settings and expect them to sound the same. Turn those knobs. It's not muddy by nature.
    fndrman, bo and Marc Morfei like this.
  9. Marc Morfei
    Marc Morfei Tele-Holic
    Philadelphia, PA
    I have a DB210. It definitely EQs differently than a Fender amp. I found a speaker swap made a big difference in the Peavey. I put an EMI Ragin Cajun in there and it sounds awesome. Getting ready to stick a Weber in the other side.
    fndrman likes this.
  10. Mark the Moose
    Mark the Moose Tele-Meister
    Erie, CO
    Tweak those knobs. Treble/mid/bass all set on 7 is a very different sound than all set on 3. Lower settings tend to be thicker. Get some decent tubes and a pair of nice speakers. WGS Veteran 10's are very popular "American-voiced" speakers for only $50 a whack.
    fndrman likes this.
  11. wtk0315
    wtk0315 Tele-Holic
    Houston area
    I have one, I found it too dark/muddy with HBs but it should be good with a Tele.
    fndrman likes this.
  12. fndrman
    Alberta, Canada
    Thanks for the replies. I typically set my HRD with the Bass a 7, the Mid at 7, and the Treble at 7 or 8. I set the DB basically the same. Maybe I'll just have to tweak a bit more. Having said that, my guitar repair guy sold me a JBL K 140 15" speaker. I plan to try that out. I just have to make a new baffle.
